  3. Reliability ?
Reliability ?
7 Posts 4 Posters 3.1k Views 2 Watching
  • Sander TeunissenS
    Sander TeunissenS
    Sander Teunissen
    Getting started with this great product !
    I have an rf node which has a led attached to it which I want to switch on and off.
    When doing so 9 out of 10 times it works flawlessly. Is this acceptable or should I get 10 out of 10 times ? Node and gateway are 2 metres apart and I use the capacitors.
    I have the following setup:
    • rf node with temp sensor and switchable led.
    • rpi rf gateway with mosquitto broker and websockets enabled. (all connected through node-red)
    • polymer web app with websocket connection to switch the led on and off...
    Sander.
    • rvendrameR
      rvendrameR
      rvendrame
      Do you have any wall or any RF interference (such as microwave or hi-power appliances) in between or very close (<10cm to) the two radios?
      ESP8266 GW + mySensors 2.3.2
      Alexa / Google Home
      Sander TeunissenS 1 Reply Last reply
      • A
        A
        andriej
        Show the code. :-)
        • rvendrameR rvendrame
          Sander TeunissenS
          Sander TeunissenS
          Sander Teunissen
          My sensor is next to my home cinema system and a light dimmer. Could that be a source of the error ?
          • A andriej
            Show the code. :-)
            Sander TeunissenS
            Sander TeunissenS
            Sander Teunissen
            @andriej said:
            Show the code. :-)
            What code would you like to see ? (It is all very experimental anyway..)
            • rvendrameR
              rvendrameR
              rvendrame
              @Sander-Teunissen , a light dimmer may cause some noise. How are you powering your nodes & gateway?
              Alexa / Google Home
              • Sander TeunissenS Sander Teunissen
                @andriej said:
                Show the code. :-)
                BulldogLowellB
                BulldogLowellB
                BulldogLowell
                @Sander-Teunissen said:
                @andriej said:
                Show the code.
                in addition to the radio noise possibility pointed out by @rvendrame , your code may be "blocking" and affecting good data transmission.
