  3. IR Blaster (progress)
99 Posts 32 Posters 89.5k Views 24 Watching
  • blaceyB
    blaceyB
    blacey
    @gloob, @john, @notYetRated and everyone else - Here is an update on IR Blaster project
    The first dev boards are working well but not as good as they should IMHO. My 0.5 LED circuit design uses a separate voltage-regulated parallel IR LED emitter circuit. After a lot of technical research into the depths of IR Emitters and collaboration with others, I can greatly improve the IR performance by moving to a constant-current (not constant-voltage) serial IR LED emitter circuit. I have been scouring the net for constant current regulators and/or LED drivers that can handle 7 IR LEDs @100ma & 1.6FV and have a few candidates under review for prototyping.
    I have also been in touch with the AnalysisIR guys to ensure compatibility of our board with their offerings because users have successfully decoded long IR encodings, using the advanced AnalysisIR decoding software, such as HVAC units popular in the EU/UK - for example Panasonic AC and Mitsubishi AC. The goal being that any Analysis IR decodes, will be directly compatible with our board so we can leverage the enthusiasm and prior work of the AnalysisIR community at large. In addition, I would like to advance our board to be able serve as a full spectrum IR decoder to ensure maximum decoding performance when using AnalysisIR on the board. Compatibility requires running the MCU at 16MHz or great to improve the IR mark/space decoding which also requires additional changes to the original circuit design.
    All of that said, the reason for the recent silence by me has been due to my personal life - I have had a hectic family pursuit requiring multi-month travel from home and work has heated up again.
    Fear not though, this is an extremely important project for me and I will get it done! While it is taking a bit longer than I had hoped, I firmly believe it will be well worth the wait.
    N RJ_MakeR 2 Replies Last reply
    • JohnJ
      JohnJ
      John
      @blacey No problem! As long it is possible to have all the IR codes be able to store on the server i'm very interested ;) Take all the time you need to get it to your requirements
      • blaceyB blacey
        N
        N
        NotYetRated
        @blacey Let me know if I can be of any help. Mostly in the use-case testing area probably, as I am no electrical engineer or software genius. :)
        • G
          G
          gloob
          Any update on this project? Do you need any support to finish this PCB?
          • blaceyB blacey
            RJ_MakeR
            RJ_MakeR
            RJ_Make
            @blacey How is the project progressing? I can't wait to get my hands on this. (even though HomeSeer may not be able to incorporate it yet ;-) )
            RJ_Make
            • blaceyB
              blaceyB
              blacey
              Apologies everyone but progress has been much slower than I had planned/wished for two reasons. 1) Work obligations and 2) a special automation from my wife that has usurped my MySensors cycles that required helping the FreeCAD open source project to advance my cause. My plan is to hit IR Blaster hard within the next 4-6 weeks.
              • korttomaK
                korttomaK
                korttoma
                @blacey
                Did you abandon this project? We are heading for darker times again and I was really hoping that your blaster would be available to turn on those candles in the night.
                Just let me know if you stil have plans to realize this or not so that I know if I should make something for my self on a perfboard or something.
                • Tomas
                • korttomaK
                  korttomaK
                  korttoma
                  Any news on this?
                  • Tomas
                  blaceyB 1 Reply Last reply
                    I know that @scalz have a blaster project going as well
                    • korttomaK korttoma
                      Any news on this?
                      blaceyB
                      blaceyB
                      blacey
                      @korttoma Apologies to you and others; I wouldn't say that I have abandoned this project but it is fair to say that I haven't had the time to devote to this either so it is woefully stalled. @scalz is working on something similar that may fit but bill nicely after which I will decide whether this warrants further development or not.
                      • scalzS
                        scalzS
                        wrote on last edited by scalz
                        #91
                        @korttoma
                        guys are true :)
                        I'll order next week my pcb. i'm taking the weekend to think about my design. perhaps will do a dhl :blush: as i have other things to order and i'm an impatient child..
                        Of course, i'll share my workn and hope to work with @blacey . this will be a Mysensors project ;)
                        • E
                          E
                          emc2
                          @blacey @scalz
                          I'm thinking of starting to do an IR blaster on my own, any chance to get a glimpse of what you are cooking on your side to either wait / see what kind of function you plan?
                          On my side I'm thinking of:
                          • Eventually esp8266 based (probably using a WeMos mini Pro) to allow a wide range of usage even out of MySensors.
                          • Micro usb powered (using the WeMos' port)
                          • SMD nrf24L01, eventually RFM too if it fits on the PCB.
                          • optional ATSHA.
                          • IR leds on the side (roundish PCB?)
                          • Optional IR receiver
                          • E emc2
                            @blacey @scalz
                            • optional ATSHA.
                            blaceyB
                            blaceyB
                            blacey
                            @emc2 That pretty much sums up the above sans ESP8266 vs. Atmel 328p... My next iteration, albeit delayed, uses an SMD footprint compatible with both NRF and RFM. I had originally included an Si7021 temperature and humidity sensor but that isn't really necessary. @sparkman had requested a barrel connector to drive external IR LEDs.
                            • scalzS
                              scalzS
                              #94
                              @emc2 "almost" same specs on my side, except i'm gonna use esp32 :)
                              • E
                                E
                                emc2
                                @scalz Cool! Let me know when you have some details on that. I may stick to esp8266, esp32 seems to be overkill for what I'm thinking, but if you have any tips let me know.
                                @blacey I saw this request, I can see the use of it, will see if I end up with a spot for one. One thing still, are these standard in term of where is ground and where is VCC on the mono 3.5mm jack? (I assume GND is "outside" and VCC is the "tip" but I may be wrong)
                                korttomaK scalzS 2 Replies Last reply
                                • E emc2
                                  korttomaK
                                  korttomaK
                                  korttoma
                                  #96
                                  Googling this gives some different results but this one seems most reasonable:
                                  Picture was taken from here.
                                  Maybe one jack can be used for both purposes? In learning mode you could have a sensor in the jack and otherwise you could have a IR Blaster in the same jack? Just a thought.
                                  • Tomas
                                  • E emc2
                                    scalzS
                                    scalzS
                                    @emc2 hehe. i don't think this is overkill ;) depends on what features. well let's see how it will work. mine is already designed but i won't have lot of time before beginning of the year now :grin:
                                    E 1 Reply Last reply
                                    • scalzS scalz
                                      E
                                      E
                                      emc2
                                      Agreed, depends on the features, in my case I did not really think of any additional features, just IR stuff. PCB was designed yesterday, I will play with a protoboard to check if everything works and then will see how to improve everything before ordering.
                                      • Simon T.S
                                        Simon T.S
                                        Simon T.
                                        For info, Luminara works with USB-UIRT with windows (Eventghost)
                                        Code IR ON:
                                        0000 006F 0000 000A 01DD 0054 00F1 0053 002C 007B 002D 007B 002C 007B 007C 002B 002D 007C 002C 007B 007B 002C 007B 0FF1
                                        Code IR OFF:
                                        0000 006F 0000 000A 01DD 0054 00F2 0053 002D 007B 002D 007B 002C 007B 007C 002C 002C 007B 002D 007B 007B 002C 002D 09F6
                                        With Eventghost you can create request HTTP to Trigger IR signal
                                        I learned code IR with LM Remote KeyMap beacause EventGhost don't learn signal
