  3. Multi-Binary Switch Sketch
3 Posts 2 Posters 3.5k Views 1 Watching
    mikeones
    Anyone have a working example of a multi-switch sketch? I have started to modify the BinarySwitchSensor.ino sketch but I am not sure how to get the debouce settings per switch or if it is needed. I have attached my sketch and error that results when I try an compile this. Any suggestions?
    BinarySwitchSensor.ino: In function ‘void setup()’:
    BinarySwitchSensor:39: error: request for member ‘attach’ in ‘i’, which is of non-class type ‘int’
    BinarySwitchSensor:40: error: request for member ‘interval’ in ‘i’, which is of non-class type ‘int’
    BinarySwitchSensor.ino: In function ‘void loop()’:
    BinarySwitchSensor:54: error: request for member ‘update’ in ‘i’, which is of non-class type ‘int’
    BinarySwitchSensor:56: error: request for member ‘read’ in ‘i’, which is of non-class type ‘int’
    BinarySwitchSensor:61: error: lvalue required as left operand of assignment
    This is the code so far.
    // Simple binary switch example
    // Connect button or door/window reed switch between
    // digitial I/O pin 3 (ZONE_1 below) and GND.
    #include <Sensor.h>
    #include <EEPROM.h>
    #include <RF24.h>
    #include <Bounce2.h>
    #define ZONE_1  14  // Arduino Digital I/O pin for button/reed switch
    #define NUMBER_OF_ZONES 6
    Sensor gw;
    Bounce debouncer_1 = Bounce();
    Bounce debouncer_2 = Bounce();
    Bounce debouncer_3 = Bounce();
    Bounce debouncer_4 = Bounce();
    Bounce debouncer_5 = Bounce();
    Bounce debouncer_6 = Bounce();
    int oldValue_1 =-1;
    int oldValue_2 =-1;
    int oldValue_3 =-1;
    int oldValue_4 =-1;
    int oldValue_5 =-1;
    int oldValue_6 =-1;
      gw.begin();
      for (int i=0; i<NUMBER_OF_ZONES;i++) {
       // Setup the button
    	pinMode(ZONE_1+i,INPUT);
    	// Activate internal pull-up
    	digitalWrite(ZONE_1+i,HIGH);
    	debouncer_1+i.attach(ZONE_1+i);
    	debouncer_1+i.interval(5);
    	// If S_LIGHT is used, remember to update variable type you send in below.
    	gw.sendSensorPresentation(ZONE_1+i, S_DOOR);
    	debouncer_1+i.update();
    	// Get the update value
    	int value = debouncer_1+i.read();
    	if (value != oldValue_1+i) {
    	   // Send in the new value
    	   gw.sendVariable(ZONE_1+i, V_TRIPPED, value==HIGH ? "1" : "0");  // Change to V_LIGHT if you use S_LIGHT in presentation above
    	   oldValue_1+i = value;
    • M mikeones
      #include <Sensor.h>
      #include <EEPROM.h>
      #include <RF24.h>
      Sensor gw;
      int oldValue_1 =-1;
      int oldValue_2 =-1;
      int oldValue_3 =-1;
      int oldValue_4 =-1;
      int oldValue_5 =-1;
      int oldValue_6 =-1;
        gw.begin();
         // Setup the button
      BulldogLowellB
      BulldogLowellB
      BulldogLowell
      wrote on last edited by BulldogLowell
      #include <Sensor.h>
      #include <EEPROM.h>
      #include <RF24.h>
      Sensor gw;
      int oldValue_1 =-1;
      int oldValue_2 =-1;
      int oldValue_3 =-1;
      int oldValue_4 =-1;
      int oldValue_5 =-1;
      int oldValue_6 =-1;
      gw.begin();
      // Setup the button
      yeah, you are trying to add an integer to a string
      the Bounce2.h library complains about that syntax, I cannot find good examples with multi pushbuttons.
      bounce.h seems a little more friendly to your needs, and a better set of instructions.
        mikeones
        I did get this code to compile... I am going to test with this over the weekend.
        #include <Sensor.h>
        #include <EEPROM.h>
        #include <RF24.h>
        Sensor gw;
        int oldValue_1 =-1;
        int oldValue_2 =-1;
        int oldValue_3 =-1;
        int oldValue_4 =-1;
        int oldValue_5 =-1;
        int oldValue_6 =-1;
          gw.begin();
           // Setup the button
        	switch (1+i) {
        	  case 1:
        		debouncer_1.attach(ZONE_1);
        		debouncer_1.interval(5);
        		break;
        	  case 2:
        		debouncer_2.attach(ZONE_1+i);
        		debouncer_2.interval(5);
        		break;
        	  case 3:
        		debouncer_3.attach(ZONE_1+i);
        		debouncer_3.interval(5);
        		break;
        	  case 4:
        		debouncer_4.attach(ZONE_1+i);
        		debouncer_4.interval(5);
        		break;
        	  case 5:
        		debouncer_5.attach(ZONE_1+i);
        		debouncer_5.interval(5);
        		break;
        	delay(1000);
        	int num = 1+i;
        	switch (num) {
        	  case 1:
        		  debouncer_1.update();
        		  int value_1 = debouncer_1.read();
        		  if (value_1 != oldValue_1) {
        		   gw.sendVariable(ZONE_1+i, V_TRIPPED, value_1==HIGH ? "1" : "0");  // Change to V_LIGHT if you use S_LIGHT in presentation above
        		   oldValue_1 = value_1;
        		  break;
        	  case 2:
        		  debouncer_2.update();
        		  int value_2 = debouncer_2.read();
        		  if (value_2 != oldValue_2) {
        		   gw.sendVariable(ZONE_1+i, V_TRIPPED, value_2==HIGH ? "1" : "0");  // Change to V_LIGHT if you use S_LIGHT in presentation above
        		   oldValue_2 = value_2;
        		  break;
        	  case 3:
        		  debouncer_3.update();
        		  int value_3 = debouncer_3.read();
        		  if (value_3 != oldValue_3) {
        		   gw.sendVariable(ZONE_1+i, V_TRIPPED, value_3==HIGH ? "1" : "0");  // Change to V_LIGHT if you use S_LIGHT in presentation above
        		   oldValue_3 = value_3;
        		  break;
        	  case 4:
        		  debouncer_4.update();
        		  int value_4 = debouncer_4.read();
        		  if (value_4 != oldValue_4) {
        		   gw.sendVariable(ZONE_1+i, V_TRIPPED, value_4==HIGH ? "1" : "0");  // Change to V_LIGHT if you use S_LIGHT in presentation above
        		   oldValue_4 = value_4;
        		  break;
        	  case 5:
        		  debouncer_5.update();
        		  int value_5 = debouncer_5.read();
        		  if (value_5 != oldValue_5) {
        		   gw.sendVariable(ZONE_1+i, V_TRIPPED, value_5==HIGH ? "1" : "0");  // Change to V_LIGHT if you use S_LIGHT in presentation above
        		   oldValue_5 = value_5;
        		  break;
        	  case 6:
        		  debouncer_6.update();
        		  int value_6 = debouncer_6.read();
        		  if (value_6 != oldValue_6) {
        		   gw.sendVariable(ZONE_1+i, V_TRIPPED, value_6==HIGH ? "1" : "0");  // Change to V_LIGHT if you use S_LIGHT in presentation above
        		   oldValue_6 = value_6;
        		break;
