  3. 110v-230v AC to Mysensors PCB board
269 Posts 63 Posters 346.1k Views 68 Watching
  • J
    J
    Jan Gatzke
    Most SSRs cannot be checked this way because they can only switch AC and not DC. See https://en.wikipedia.org/wiki/Zero_cross_circuit
    • Cliff KarlssonC
      Cliff KarlssonC
      Cliff Karlsson
      I don't know if this has been answered already. But I have some major problems soldering the thermal fuse to the board. It always blows. Any tips ?
      m26872M 1 Reply Last reply
      • sundberg84S
        @Cliff-Karlsson Be quick :)
        I have the same problem - dont know any better sollution atm... solder for 0.5 sec and remove - then you need to let it cool down before adding more solder.
        • Cliff KarlssonC
          Cliff KarlssonC
          Cliff Karlsson
          I read something before about low temp thermal sensors usally being crimped to place. Do you know how this works and if it is usable on the pcb?
          Also the last times I tried to assemble the parts on the pcb I noticed that the holes for one of the fuses are too narrow for the standard brown(?) auto reset fuse. I have managed to destroy the solderpads every time I tried to drill the holes a little bigger.
          Can I use a standard glass fuse for this one with the same value?
          • C
            C
            csa02221862
            Just a couple of questions. Most of the components are 240V, are these the same as used for 110/120v in the US? Also one of the varistors is not available, suggested alternative?
            • V
              V
              vil1driver
              wrote on last edited by vil1driver
              #226
              thanks for your great work..
              great to have chosed a pwm output for the relay (ssr can be used as a dimmer)
              but is it possible to add a fuse on the ssr output too ?
              and a second switch
              and imho relay's trace is too near a nrf trace..
              and return the draw of le33 :p
              sry for my english
              thanks
              • Sefi NinioS
                Sefi NinioS
                Sefi Ninio
                wrote on last edited by Sefi Ninio
                #227
                I love your design!
                However, I must have missed something. Considering I want to retain the ability to turn the light off with the wall switch, this board does not allow to connect the relay as a 3-way switch.
                Also, considering it could be mounted inside the wall (and not only in the lamp base) - having 2-3 relays would be very functional! In my house, it is very common that a single wall mount has 3-4 switches that control 3-4 separate lamps. It will probably make the board bigger, more so if we support 3-way switches (see above comment), but it will be very versatile, especially for 4-way switches (see http://forum.mysensors.org/topic/3173/3-4-way-switch-with-a-relay )
                • toabhishekvermaT
                  toabhishekvermaT
                  toabhishekverma
                  Hi Sefi Ninio,
                  There are two ways you can do it, Either change relay to SPDT Relay which is two way relay. this option is not feasible with this pcb. But if you are not using same PCB you can try SPDT relays.
                  Second option which can work with this setup is ,
                  Your light switch has two pins, connect them with gpio and 3.3 power .
                  when switch turn on/off gpio pin input goes high(when on) and low (when off).
                  You have to write a code to monitor this gpio and if its state changes, you have to toggle the relay state.
                  This is my idea, I havent tried it yet. and I am newbie too, Please comment.
                  I hope I am clear enough
                  Regards,
                  Abhishek
                  Sefi NinioS 1 Reply Last reply
                  • toabhishekvermaT toabhishekverma
                    Hi Sefi Ninio,
                    Regards,
                    Abhishek
                    Sefi NinioS
                    Sefi NinioS
                    Sefi Ninio
                    Hi, @toabhishekverma
                    Well, your suggestion might work, I am not sure a switch that is meant to be connected to 220v mains can be connected to the gpio pin.
                    I think, adding an additional relay to the pcb and allowing them both to behave like a 3way switch will allow for maximum flexibility.
                    1. It could control 2 separate lamps
                    2. It could behave like 2 3-way switches
                    3. It could behave like a single 4-way switch
                    I would have done it myself, but I have no clue 😀
                    • Cliff KarlssonC
                      Cliff KarlssonC
                      Cliff Karlsson
                      I have several lamps where I have done something similar. The bulbs are wireless wemo-bulbs and I have connected the wires behind the lampswitch so that the bulbs are always powered. The I have placed a battery powered arduino witch is connected to the wall switch pin3-gnd.
                      Every time I flip the switch the arduino wakes up and the controller sends a toggle command using REST
                        m26872M
                        m26872M
                        m26872
                        #231
                        Raise the temperature of your soldering iron, and you'll be able to do it quicker with less propagating heat. You could also add some extra bend and length to the fuse legs.
                        • Sefi NinioS Sefi Ninio
                          Sefi NinioS
                          Sefi NinioS
                          Sefi Ninio
                          @aproxx , what do you think about adding another relay (for a total of 2 on board) and making them 3-way?
                          • Cliff KarlssonC
                            Cliff KarlssonC
                            Cliff Karlsson
                            Another question about the thermal fuse. I might be wrong on this, but I guess its purpose is to break the power if the HLK overheats. But If placed in the intended place would not the PCB need to be on fire to have the thermal fuse be warmed up to 73 deg C?
                            HenryWhiteH 1 Reply Last reply
                              HenryWhiteH
                              HenryWhiteH
                              HenryWhite
                              I guess you're supposed to glue the thermal fuse to the hlk and run wires from this point to the designated footprint of the fuse on the pcb.
                                Sefi NinioS
                                Sefi NinioS
                                Sefi Ninio
                                #235
                                OK Guys,
                                I've decided to try and use the original V3.2.3 plans and add another relay to them (with your permission, @aproxx).
                                The board will have to be a bit bigger, I will have to make room for another relay along side the existing one, and I will have to also make room for its connectors.
                                Not a big problem, I think, as it is already very well designed and has a small footprint, but still.
                                I need a bit of help from you guys, though - I am a complete noob when it comes to the wiring and electricity. I can handle the coding, no problem, but the electricity is very new to me.
                                I am assuming that besides adding the second relay, no other components need to be added - no resistors, capacitors, varistors etc.
                                Is my assumption correct?
                                Thanks!
                                  OK Guys,
                                  Thanks!
                                  HenryWhiteH
                                  HenryWhiteH
                                  HenryWhite
                                  Thanks!
                                  You need at least a second transistor.
                                  • V
                                    V
                                    vil1driver
                                    maybe a fuse to protect relay output.. ?
                                    and plz add a second switch, to control an other node or anything..
                                    • Sefi NinioS
                                      Sefi NinioS
                                      Sefi Ninio
                                      So basically, I should duplicate the current circuit for the new relay...
                                      • J
                                        J
                                        Jan Gatzke
                                        I am facing a little problem with the fuses. I am using these:
                                        230V AC: http://de.aliexpress.com/item/TRF250-300U-line-resettable-fuses-0-3A-300MA-250V-Tyco/32368739339.html?detailNewVersion=2
                                        5V DC: http://www.ebay.de/itm/321697892220?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
                                        When I connect the pcb to power the LED on the Arduino flashes and then the 500 mA Fuse in the 5V circuit dies. I am now using the 300 mA resetable Fuse for the 5V part as well, which seems to work without problems. How can it be, that the 500 mA fuse dies and the 300 mA fuse does not?
                                        • TmasterT
                                          TmasterT
                                          Tmaster
                                          wrote on last edited by Tmaster
                                          #240
                                          Jan Gatzke; chinese brand electronics... who knows what can happens....
                                          i ordered all stuff needed to make my pcb with maximun 4x4cms to use inside wall switches (like zwave fibaro modules). i will try to reduce that board by not using connectors and solder the cables directly etc..
                                          Something that i don't know is why use a varistor and fuse on secundary??? arduino already have an polyfuse PPTC Resetable fuse, and someting bad that happens with nrf24 will burn the 3.3V regulator.. its that varistor and fuse realy needed?
                                          i'm a arduino fan .Even sometimes don't undestanding how to use it :P
