  3. 110v-230v AC to Mysensors PCB board
269 Posts 63 Posters 345.6k Views 68 Watching
  • toabhishekvermaT toabhishekverma
    @HenryWhite why do we need D1 Diode (if i am write) in that circuit? do this circuit will not work without diode?
    (sorry dont know much about electronics)
    HenryWhiteH
    HenryWhiteH
    HenryWhite
    wrote on last edited by HenryWhite
    #213
    @toabhishekverma https://en.m.wikipedia.org/wiki/Flyback_diode
    in short: It is needed to protect the NPN transistor from damage.
    The circuit will work without diode, But eventually damage the transistor.
    • m26872M
      m26872M
      m26872
      @GertSanders Have you breadboarded your 3.3V design? I'm a bit worried that removing linear converter will impair the performance of the our fussy nRF clones due to less power supply ripple rejection. I think those going for the ESP8266 are better off.
      • T
        tomkxy
        Anyone has an idea where to source the 5.5V varistor? I received a bunch from AliExpress following which seem to be broken.
        I found this link http://www.farnell.com/datasheets/575651.pdf. However, there seem to be a bunch of 5.5 V varistor. Can anybody help me figuring out the right ones?
        icebobI 1 Reply Last reply
        • T tomkxy
          icebobI
          icebobI
          icebob
          @tomkxy I'm using this one: http://hu.farnell.com/multicomp/mcvz1206m050agt/varistor-multilayer-4vac-0402/dp/2462756
          • m26872M m26872
            GertSandersG
            GertSandersG
            GertSanders
            #217
            @m26872 I have not used the 3V3 version of the Hilink converter, it was just shipped today (ordered last week). It will take a few more weeks to reach me. But then I will test it on my ac board. We will see.
            23/FEB: Update: the converters are here. I will make a node with this converter version this weekend.
            • icebobI icebob
              tomkxy
              Thanks! It's a pity that the chinese "varistors" seem to be jumpers. I even saw in some offers on AliExpress that they are referred to as jumpers.
              • T
                tomkxy
                How can I check whether the solid state relay works at all. My assembled board receives messages and sets state properly, I have 5V on the pin, however the relay does not seem to switch. Should I hear it? Any other ideas for "debugging"?
                • T tomkxy
                  GertSandersG
                  GertSandersG
                  GertSanders
                  #220
                  @tomkxy
                  Measure the resistance over the AC terminals of the SSR. It should be very high when "open" en very low when "closed". SSRs do not make sounds when they switch, so sound will not give a clue if they work.
                  • J
                    J
                    Jan Gatzke
                    Most SSRs cannot be checked this way because they can only switch AC and not DC. See https://en.wikipedia.org/wiki/Zero_cross_circuit
                    • Cliff KarlssonC
                      Cliff KarlssonC
                      Cliff Karlsson
                      I don't know if this has been answered already. But I have some major problems soldering the thermal fuse to the board. It always blows. Any tips ?
                      m26872M 1 Reply Last reply
                      • sundberg84S
                        sundberg84S
                        @Cliff-Karlsson Be quick :)
                        I have the same problem - dont know any better sollution atm... solder for 0.5 sec and remove - then you need to let it cool down before adding more solder.
                        • Cliff KarlssonC
                          Cliff KarlssonC
                          Cliff Karlsson
                          I read something before about low temp thermal sensors usally being crimped to place. Do you know how this works and if it is usable on the pcb?
                          Also the last times I tried to assemble the parts on the pcb I noticed that the holes for one of the fuses are too narrow for the standard brown(?) auto reset fuse. I have managed to destroy the solderpads every time I tried to drill the holes a little bigger.
                          Can I use a standard glass fuse for this one with the same value?
                          • C
                            C
                            csa02221862
                            Just a couple of questions. Most of the components are 240V, are these the same as used for 110/120v in the US? Also one of the varistors is not available, suggested alternative?
                            • V
                              V
                              vil1driver
                              wrote on last edited by vil1driver
                              #226
                              thanks for your great work..
                              great to have chosed a pwm output for the relay (ssr can be used as a dimmer)
                              but is it possible to add a fuse on the ssr output too ?
                              and a second switch
                              and imho relay's trace is too near a nrf trace..
                              and return the draw of le33 :p
                              sry for my english
                              thanks
                              • Sefi NinioS
                                Sefi NinioS
                                Sefi Ninio
                                wrote on last edited by Sefi Ninio
                                #227
                                I love your design!
                                However, I must have missed something. Considering I want to retain the ability to turn the light off with the wall switch, this board does not allow to connect the relay as a 3-way switch.
                                Also, considering it could be mounted inside the wall (and not only in the lamp base) - having 2-3 relays would be very functional! In my house, it is very common that a single wall mount has 3-4 switches that control 3-4 separate lamps. It will probably make the board bigger, more so if we support 3-way switches (see above comment), but it will be very versatile, especially for 4-way switches (see http://forum.mysensors.org/topic/3173/3-4-way-switch-with-a-relay )
                                • toabhishekvermaT
                                  toabhishekvermaT
                                  toabhishekverma
                                  Hi Sefi Ninio,
                                  There are two ways you can do it, Either change relay to SPDT Relay which is two way relay. this option is not feasible with this pcb. But if you are not using same PCB you can try SPDT relays.
                                  Second option which can work with this setup is ,
                                  Your light switch has two pins, connect them with gpio and 3.3 power .
                                  when switch turn on/off gpio pin input goes high(when on) and low (when off).
                                  You have to write a code to monitor this gpio and if its state changes, you have to toggle the relay state.
                                  This is my idea, I havent tried it yet. and I am newbie too, Please comment.
                                  I hope I am clear enough
                                  Regards,
                                  Abhishek
                                  Sefi NinioS 1 Reply Last reply
                                    Hi Sefi Ninio,
                                    Regards,
                                    Abhishek
                                    Sefi NinioS
                                    Sefi NinioS
                                    Sefi Ninio
                                    Hi, @toabhishekverma
                                    Well, your suggestion might work, I am not sure a switch that is meant to be connected to 220v mains can be connected to the gpio pin.
                                    I think, adding an additional relay to the pcb and allowing them both to behave like a 3way switch will allow for maximum flexibility.
                                    1. It could control 2 separate lamps
                                    2. It could behave like 2 3-way switches
                                    3. It could behave like a single 4-way switch
                                    I would have done it myself, but I have no clue 😀
                                    • Cliff KarlssonC
                                      Cliff KarlssonC
                                      Cliff Karlsson
                                      I have several lamps where I have done something similar. The bulbs are wireless wemo-bulbs and I have connected the wires behind the lampswitch so that the bulbs are always powered. The I have placed a battery powered arduino witch is connected to the wall switch pin3-gnd.
                                      Every time I flip the switch the arduino wakes up and the controller sends a toggle command using REST
                                        m26872M
                                        m26872M
                                        m26872
                                        wrote on last edited by m26872
                                        #231
                                        Raise the temperature of your soldering iron, and you'll be able to do it quicker with less propagating heat. You could also add some extra bend and length to the fuse legs.
                                        • Sefi NinioS Sefi Ninio
                                          Sefi NinioS
                                          Sefi NinioS
                                          Sefi Ninio
                                          @aproxx , what do you think about adding another relay (for a total of 2 on board) and making them 3-way?
