  3. 110v-230v AC to Mysensors PCB board
269 Posts 63 Posters 346.1k Views 68 Watching
  • the cosmic gateT
    the cosmic gateT
    the cosmic gate
    Could I ask to the smart PCB builder's / designers to make the same 230v PCB but not using an Arduino but one of the ESP8266 versions , the the board could be even smaller and easier to fix in the wholes
    There's more than meets the eye
    B 1 Reply Last reply
    • the cosmic gateT the cosmic gate
      B
      B
      Brijesh Mishra
      @the-cosmic-gate, greetings to you. Kindly let me know, is there any issue with the component placement in the board. Not sure why it's not working :(.
      Brijesh
      the cosmic gateT 1 Reply Last reply
      • N
        N
        nunver
        @aproxx Great job. Just started to work with mysensors and I was looking for a power supply alternative to mobile phone chargers. Though one question; the board that you included the relay was really interesting. Why did you not proceed on this? Also, do you sell the PCB's?
        • B Brijesh Mishra
          Brijesh
          the cosmic gateT
          the cosmic gateT
          the cosmic gate
          Brijesh
          There absolutely nothing wrong, but I want to use the ESP8266 to build in instead of the arduino and 2.4 ghz radio (the ESP8266 is an Arduino incl WiFi) so the PCB can be much smaller I think.
          • N
            N
            novicit
            @Brijesh-Mishra , I see two issues with your photos. 1) the 3.3V regulator is on backwards. If you earlier in this thread someone comments that the regulator needs to be put on backward. The white design on the board is not correct. That was also my experience with the boards I built. The flat side of the regulator should face the two cap's. 2) more importantly, it appears that you used a thermal fuse in the spot where fuse #1 goes. Fuse #1 is supposed to be a 300ma slo blow fuse. If that is what you have there no problem, but it looks like the thermal discussed in the thread. This board does not have a place for the thermal fuse. I would consider this a serious safety issue, but I am not an expert. Hope this helps.
            • N novicit
              B
              B
              Brijesh Mishra
              @novicit, Thanks a lot for your help. i will make a new board as per your guidance and share the photos soon.
              Regards
              Brijesh
              • V
                V
                vampircik
                Hello. Here I soldered all works well. Thank you
                Daniel OliveiraD 1 Reply Last reply
                • V vampircik
                  Daniel OliveiraD
                  Daniel OliveiraD
                  Daniel Oliveira
                  Hi @vampircik,
                  Can you please share roughly how much it costed you to build that node?
                  MySensors rules my home :)
                  • icebobI
                    icebobI
                    icebob
                    wrote on last edited by icebob
                    #169
                    I now received PCBs from DirtyPCB. I'm searching components (but not from China sellers).
                    Can I use this varistor on the AC side?: http://uk.farnell.com/multicomp/mcsr391k10ds/varistor-60j-250vrms/dp/1856880
                    And on the DC side?: http://uk.farnell.com/multicomp/mcvz1206m050agt/varistor-multilayer-4vac-0402/dp/2462756
                    Thanks in advance!
                    • V
                      V
                      vampircik
                      I can not help.I not particularly versed in radio details
                      • A aproxx
                        Hi all,
                        **UPDATE April 17 2016 **
                        The latest version of this board is available HERE.
                        After spending a few months on this forum and a few prototypes later, I decided I wanted to build a small but cheap PCB which could be placed in either the wall behind the light switch, or above the lamp.
                        Besides the boards I've seen on this forum, I wanted these boards to contain a module to go from 230v AC to 5/3.3v DC in order to power an Arduino nano and the NRF module. I eventually ended up with a PCB which is about 4 by 4.5cm. So with all components attached I'm hoping to get in stuffed in a 5x5x3cm plastic printed case.
                        Modules which I've used to power the board:
                        [http://www.aliexpress.com/item/5-pcs-HLK-PM01-AC-DC-220V-to-5V-Step-Down-Power-Supply-Module-Intelligent-Household/32319202093.html?spm=2114.32010308.4.19.8oKfZg
                        UPDATE: 2015/09/18
                        As promised, I've got an update for this project. The board has been tested in the past week, and everything is working as expected. Compared to the previous board I've posted, I have updated the following:
                        • Solder pads of LE33CZ have been placed a little wider apart to avoid short circuit while soldering.
                        • Solder pads of the resettable fuse (Fuse2) has been placed closer together to better fit the fuses of the BOM.
                        • Moved the NRF24L01 connector a bit away from the solid state relay. Should make it easier to solder.
                        • Moved Fuse2 to another location on the board, away from the 230v circuit.
                        Some 3D pictures (Top and bottom):
                        Anyone who is interested can order the PCB HERE
                        Some documentation, complete list of required components and all gerber / DipTrace files (in case you would like to make some modifications) can be found here: MySensors board v3.2.3.zip.
                        scropion86
                        @aproxx hi wonderful design , i was going to make a similar but i can't find EAGLE part and footprint
                        for HLK-PM01 ,and actually i don't know how to design the part library .
                        so please if you can share it i will be thankful
                        • sundberg84S
                          @scropion86 https://www.openhardware.io/download/5693e2ffaab2635a049184d5/design/HKLPM01.lbr
                          • P
                            P
                            punter9
                            wrote on last edited by punter9
                            #173
                            This post is deleted!
                            • P
                              P
                              punter9
                              I really like that this uses the hlk power supply. Any versions of this floating around that instead of a relay do a digital/analog pinout for you to connect sensors to? That would be like a plain vanilla do anything board with safe power
                              • sundberg84S
                                @punter9 check our hardware site openhardware.io
                                • P
                                  P
                                  punter9
                                  thanks! one more question. I am really striking out finding resettable fuses for 120v US application. Anybody conquer this mole hill?
                                  petewillP 1 Reply Last reply
                                  • P punter9
                                    petewillP
                                    petewillP
                                    petewill
                                    I don't remember where I read this but it was advised not to use resettable fuses with the HLK. Basically it was said that if the fuse were to blow the HLK would have already been stressed to the point where it may be unsafe and it's best to replace the whole device. I wish I could remember where I read that but I'm not sure...
                                    TD22057T 1 Reply Last reply
                                    • petewillP petewill
                                      TD22057T
                                      TD22057T
                                      TD22057
                                      I'm 90% certain that was from the guy who did the power tests of the HLK. I believe he was saying that these small PSU's don't handle heat or spikes well and if the fuse goes, you should assume the PSU is unsafe as well and replace it. I think it was in a thread that he was replying to on a different forum but I could be wrong.
                                      HenryWhiteH 1 Reply Last reply
                                      • TD22057T TD22057
                                        HenryWhiteH
                                        HenryWhiteH
                                        HenryWhite
                                        Here it is I guess: http://lygte-info.dk/review/Power Mains to 5V 0.6A Hi-Link HLK-PM01 UK.html
                                        Quote: "I would place a fuse or fusible resistor before the converter, the fuse is not supposed to be replaceable, when it blows it is time to replace the converter."
                                        Pierre PP 1 Reply Last reply
                                        • HenryWhiteH HenryWhite
                                          Pierre PP
                                          Pierre PP
                                          Pierre P
                                          @HenryWhite it mean that appart if you make a direct shortcut with a metal part, the only thing that came make the fuse blow, it is because of the HLK part.
                                          So: fuse blow = HLK dead.
                                          HLK dead = you don't need a resettable fuse, as you have to unsolder the HLK to repair the board (if no component seam to be dead after this one).
                                          No quote, no forum notification (else, the mail box ring every minutes !). Thanks, and have a very good MySensors day !
