  3. 110v-230v AC to Mysensors PCB board
269 Posts 63 Posters 341.5k Views 68 Watching
  • V
    V
    vampircik
    I can not help.I not particularly versed in radio details
    • A aproxx
      Hi all,
      **UPDATE April 17 2016 **
      The latest version of this board is available HERE.
      After spending a few months on this forum and a few prototypes later, I decided I wanted to build a small but cheap PCB which could be placed in either the wall behind the light switch, or above the lamp.
      Besides the boards I've seen on this forum, I wanted these boards to contain a module to go from 230v AC to 5/3.3v DC in order to power an Arduino nano and the NRF module. I eventually ended up with a PCB which is about 4 by 4.5cm. So with all components attached I'm hoping to get in stuffed in a 5x5x3cm plastic printed case.
      Modules which I've used to power the board:
      [http://www.aliexpress.com/item/5-pcs-HLK-PM01-AC-DC-220V-to-5V-Step-Down-Power-Supply-Module-Intelligent-Household/32319202093.html?spm=2114.32010308.4.19.8oKfZg
      UPDATE: 2015/09/18
      As promised, I've got an update for this project. The board has been tested in the past week, and everything is working as expected. Compared to the previous board I've posted, I have updated the following:
      • Solder pads of LE33CZ have been placed a little wider apart to avoid short circuit while soldering.
      • Solder pads of the resettable fuse (Fuse2) has been placed closer together to better fit the fuses of the BOM.
      • Moved the NRF24L01 connector a bit away from the solid state relay. Should make it easier to solder.
      • Moved Fuse2 to another location on the board, away from the 230v circuit.
      Some 3D pictures (Top and bottom):
      Anyone who is interested can order the PCB HERE
      Some documentation, complete list of required components and all gerber / DipTrace files (in case you would like to make some modifications) can be found here: MySensors board v3.2.3.zip.
      scropion86
      @aproxx hi wonderful design , i was going to make a similar but i can't find EAGLE part and footprint
      for HLK-PM01 ,and actually i don't know how to design the part library .
      so please if you can share it i will be thankful
      • sundberg84S
        sundberg84S
        @scropion86 https://www.openhardware.io/download/5693e2ffaab2635a049184d5/design/HKLPM01.lbr
        • P
          P
          punter9
          wrote on last edited by punter9
          #173
          • P
            P
            punter9
            I really like that this uses the hlk power supply. Any versions of this floating around that instead of a relay do a digital/analog pinout for you to connect sensors to? That would be like a plain vanilla do anything board with safe power
            • sundberg84S
              sundberg84S
              @punter9 check our hardware site openhardware.io
              • P
                P
                punter9
                thanks! one more question. I am really striking out finding resettable fuses for 120v US application. Anybody conquer this mole hill?
                petewillP 1 Reply Last reply
                • P punter9
                  petewillP
                  petewillP
                  petewill
                  I don't remember where I read this but it was advised not to use resettable fuses with the HLK. Basically it was said that if the fuse were to blow the HLK would have already been stressed to the point where it may be unsafe and it's best to replace the whole device. I wish I could remember where I read that but I'm not sure...
                  TD22057T 1 Reply Last reply
                  • petewillP petewill
                    TD22057T
                    TD22057T
                    TD22057
                    I'm 90% certain that was from the guy who did the power tests of the HLK. I believe he was saying that these small PSU's don't handle heat or spikes well and if the fuse goes, you should assume the PSU is unsafe as well and replace it. I think it was in a thread that he was replying to on a different forum but I could be wrong.
                    HenryWhiteH 1 Reply Last reply
                    • TD22057T TD22057
                      HenryWhiteH
                      HenryWhiteH
                      HenryWhite
                      Here it is I guess: http://lygte-info.dk/review/Power Mains to 5V 0.6A Hi-Link HLK-PM01 UK.html
                      Quote: "I would place a fuse or fusible resistor before the converter, the fuse is not supposed to be replaceable, when it blows it is time to replace the converter."
                      Pierre PP 1 Reply Last reply
                      • HenryWhiteH HenryWhite
                        Pierre PP
                        Pierre PP
                        Pierre P
                        @HenryWhite it mean that appart if you make a direct shortcut with a metal part, the only thing that came make the fuse blow, it is because of the HLK part.
                        So: fuse blow = HLK dead.
                        HLK dead = you don't need a resettable fuse, as you have to unsolder the HLK to repair the board (if no component seam to be dead after this one).
                        No quote, no forum notification (else, the mail box ring every minutes !). Thanks, and have a very good MySensors day !
                        • ikin77I
                          ikin77I
                          ikin77
                          Hi and thanks for sharing your project!!! I'm new here and up to now I've been using Fritzing as PCB design tool. I'm impressed with the 3D preview of diptrace. I've imported your project since is almost what I need, but I need some changes: ESP8266 (E-12/E-04) instead or Arduino and Relay instead of SSR.
                          When I import your project I can't see 3D preview of HLK. How do I import this 3D part? Where's can I find the Songle Relay part that has been shown above?
                          Just one more question: why do you use NRF24L01 + Arduino if you can do the same and more with ESP8266?? :o/
                          Thanks again and best regads!!!
                          P.S.
                          I'll share my PCB if you wish.
                          • A aproxx
                            Hi all,
                            UPDATE: 2015/09/18
                            Jsmit83J
                            Jsmit83J
                            Jsmit83
                            @aproxx said:
                            Hi all,
                            UPDATE: 2015/09/18
                            • J
                              J
                              Jan Gatzke
                              Just ordered 10 pcs of this board. Great Job!
                              • P
                                P
                                punter9
                                thanks for the update on the resettable fuses! Another rookie ?. I ordered 0.4A fuses since the 0.3A are sold out. Is this a classic dumb move thinking that 0.1A is no big deal?
                                • sundberg84S
                                  sundberg84S
                                  HLK spec. is max input of 0.2a with small spikes tolerance to 1.0A. I also ran out of 0.3 but are now using 0.2a and that works fine.
                                  • C
                                    C
                                    csa02221862
                                    Does the light switch need to be a SPST or can you use a pushbutton? Curious how this would work with a SPST switch. I haven't looked at the code to see what is setup.
                                    • J
                                      J
                                      Jan Gatzke
                                      @csa02221862 said:
                                      SPST
                                      This depends on the sketch you flash. ;)
                                      • NikolayChN
                                        NikolayChN
                                        NikolayCh
                                        I understand that the question has already been asked, but ... Is there a possibility to adjust the scheme to the ESP8266 instead of Arduino? Anybody can tell or help - how to do it?
                                        Regards,
                                        Nikolay
                                        • J
                                          J
                                          jemish
                                          yes, now how to use ESP8266 instead of arduino for the same function that we are discuss in this topics.
