  3. Washing machine state sensor
32 Posts 10 Posters 24.5k Views 7 Watching
  • M Offline
    M Offline
    mvdarend
    Created a custom widget in HomeGenie and set it up to send PushBullet notifications. After running for a week I've noticed a few small problems.
    • If I leave the door open and the sun shines on the sensor, it's status changes to 'Running'. Increasing the threshold doesn't help so I'll need to protect the sensor from outside elements better. *
    • The LED on the machine also flashes just before it goes into running mode. I think I'll go with an extra status depending on the previous one (Off -> Flashing = 'stand by', Running -> flashing = 'Idle') or something like that.
    • My 3D printer is ordered and on its way, so I'll be able to create a custom holder. You guys are killing my finances :)
    • M mvdarend
      Moshe LivneM Offline
      Moshe Livne
      @mvdarend While waiting for the current sensor (and also discovering that new powerboards have one way screws! evil people!), I have re-checked my vibration sensors. i am using this one http://www.aliexpress.com/item/1pc-lot-SW-420-Normally-Closed-Alarm-Vibration-Sensor-Module-Vibration-Switch-30512/32259757483.html which is better than the others i think.
      currently I am just monitoring 5 minute periods and if there is a vibration during this time I mark it as "active". my theory (that I can't check as I ran out of laundry) is that 3 periods of vibrations signal that a cycle is in progress. a period of quite means the cycle has finished. will post final results the minute the kids will produce enough dirty cloths.
      • Moshe LivneM Moshe Livne
        M Offline
        M Offline
        mvdarend
        wrote on last edited by mvdarend
        #23
        @Moshe-Livne How is it working so far, have you been able to test it?
        • M mvdarend
          Moshe Livne
          @mvdarend so far so good. have added a bit of logic to my sketch and need another load to test it :-)
          this is the current sketch:
          // Washing machine finished sketch
          #define CHILD_ID 3
          #define BUTTON_PIN  3  // Arduino Digital I/O pin for button/reed switch
          #define SAMPLING_PERIOD 600000
          int oldValue=-1;
          unsigned long period_start = millis();
          int state = -1;
            gw.begin();
           // Setup the button
            pinMode(BUTTON_PIN,INPUT);
            // Activate internal pull-up
            gw.present(CHILD_ID, S_DOOR);
          void report_state(int state)
          	  	Serial.print("reporting state: ");
          		Serial.println(state);
          	    gw.send(msg.set(state));
          int prev_state = -1;
          int prev_state_length = 0;
            // Get the update value
            int value = digitalRead(BUTTON_PIN);
            if (value == 1) {// 0 means vibration detected
            	state = 1;
            	Serial.println("setting state to 1");
            Serial.println(millis()-period_start);
            if (millis() - period_start > SAMPLING_PERIOD) {
              if (state != prev_state) {
            		if (state == 1 && prev_state_length > 2) { //a vibration period after long period of quit means a cycle started
            	    	report_state(state);
          	    	prev_state_length = 1;
            		} else if (state == 0 && prev_state_length > 2){ //a long quite period after a cycle means cycle finished
          	prev_state = state;
              state = 0;
            delay(100);
          will refine it once i verify it works through all the different cycles - this is not even a tested version, just to give you an idea about how it works. looks promising so far.
          • Moshe LivneM Offline
            Moshe Livne
            found some flaws in the logic - updated and checking - do not use the code above
            B 1 Reply Last reply
              B Offline
              B Offline
              BulldogLowell
              wrote on last edited by BulldogLowell
              #26
              @Moshe-Livne
              I think you can make this easier...
              It looks like you are looking for two motion events in the past two minutes to indicate washer is on?
              something like this (untested)
              #define CHILD_ID 3
              #define SAMPLING_PERIOD 600000UL
              unsigned long motionTime;
              unsigned long lastMotionTime = millis();
              boolean lastSensorState = false;
              boolean lastWasherState = false;
                gw.begin();
                pinMode(BUTTON_PIN, INPUT_PULLUP);
                boolean sensorState = digitalRead(BUTTON_PIN);// Get the updated sensor value
                if (sensorState != lastSensorState && lastSensorState == true) //detect state change from true to false
                  lastMotionTime = motionTime; //cascade time back
                  motionTime = millis();
                lastSensorState = sensorState;
                boolean washerState = (motionTime - lastMotionTime < SAMPLING_PERIOD && motionTime - millis() < SAMPLING_PERIOD);
                if (washerState != lastWasherState)
                  gw.send(msg.set(washerState));
                lastWasherState = washerState;
              Moshe LivneM 2 Replies Last reply
              • B BulldogLowell
                @Moshe-Livne
                #define CHILD_ID 3
                  gw.begin();
                Moshe Livne
                @BulldogLowell It is slightly more complicated (but not much). the machine can idle for 5-10 min (well, not really idle, but idle enough so no vibrations will be felt). so, the current logic marks 5 minute periods. a vibration period marks the beginning of the cycle and 2 or 3 (yet to be determined) periods of quite marks end of cycle.
                  B Offline
                  B Offline
                  BulldogLowell
                  #28
                  @Moshe-Livne
                  so if no vibration is sensed in the past five (configurable) minutes machine is OFF, otherwise machine is ON?
                  likewise you want to indicate Washing when two vibrations are sensed in less than two or three (configurable) minutes?
                  yes?
                  • B BulldogLowell
                    @Moshe-Livne
                    #define CHILD_ID 3
                      gw.begin();
                    Moshe Livne
                    @BulldogLowell re-reading your code, it would work well. the reason I made the "periods" was more to help me debug the scenario as I didn't want to sift through zillions of on/off.
                    • B Offline
                      B Offline
                      BulldogLowell
                      #30
                      yeah, that is why it is important to just print() when there are state changes... added configuration and debug:
                      #define CHILD_ID 3
                      #define ONE_MINUTE 600000UL
                        gw.begin();
                        boolean washerState = ((motionTime - lastMotionTime < ONE_MINUTE * 2) && (motionTime - millis() < ONE_MINUTE * 5));
                          Serial.print(F("Washer is "));
                          Serial.println(washerState? F("ON") : F("OFF"));
                        lastWasherState = sensorState;
                      • B BulldogLowell
                        #define CHILD_ID 3
                          gw.begin();
                        Moshe Livne
                        @BulldogLowell Alas, no. The sensors are on the edge of their capability, so you get some on, lots of off. an ON means a cycle started (I am not too worried about false positives from loading the machine for now. A quite period (no ON what so ever) of about 10 min means the cycle has finished. so basically its going to be eventually a very simple code like:
                        if (sensorState == ON)
                            cycleState=WASHING
                        else period check and if long enough then cycleState = ENDED
                        I am still checking through different cycles and the kids do not produce enough dirty cloths, just to annoy me i think. Anyone has cloths he needs to wash?
                        • J Offline
                          J Offline
                          jasonrio
                          I bought one this year and i am really happy with it.
