  3. OpenHAB
  4. openHAB 2.0 binding
openHAB 2.0 binding
534 Posts 88 Posters 675.9k Views 99 Watching
  • L LastSamurai
    @TimO Cool, I'll test it once you are done. Domoticz only allows to either use the white channel or a RGB value (without the white) at the moment. Perhaps it can be done similarly in openhab.
    TimO
    @LastSamurai Could you please take a look at this: https://github.com/tobof/openhab2-addons/issues/76 ?
    I've added the RGB & RGBW channels and because I'm not that confident about the RGBW implementation I'm kindly asking you to test the implementation and give me some feedback. :-)
    The conversion from HSB, which is used by OpenHAB2 internally, to RGBW left me pretty confused. ;-)
    • L
      L
      LastSamurai
      I'll test it. Might take some days to get to it though ;)
      • B balder88
        Hey guys, first message on this forum. Been reading alot before. But now I have a problem I just can't solve.
        It's about smartsleep with openhab 2.
        Im using wifi gw rfm 69.
        Regular messages works as it should both ways.
        But it almost seems like the smartsleep isn't enabled in the binding.
        Here are my configs and logs.
        Things file:
        Bridge mysensors:bridge-eth:gw69 [ ipAddress="192.168.1.235", tcpPort=5003, sendDelay=100, enableNetworkSanCheck=true ] {
        //  Anarduino
            humidity        AnHum   [ nodeId="66", childId="0" ]
            temperature     AnTemp  [ nodeId="66", childId="1" ]
            light           light02 [ nodeId="66", childId="3", smartSleep=true ]
        Items file:
        Switch  TestLight   "Test lampa" (Test) { channel="mysensors:light:gw69:light02:status" }
        Sketch: (Cleaned up the parts that dont matter, RTC and so on.)
        #define MY_RADIO_RFM69
        #define MY_IS_RFM69HW
        #define MY_NODE_ID 66
        #define MY_RFM69_NETWORKID 100
        #define MY_SMART_SLEEP_WAIT_DURATION_MS 1000
        #include <TimeLib.h>
        #include <Wire.h>
        #include <MCP7940RTC.h>
        #include <DHT.h>
        #define MCP7940_CTRL_ID 0x6F
        #define CSMEM_PIN 5
        #define LEDPIN 9
        long sleepIntervalSec=5;
        long loopCnt=0;
        uint8_t d[8];
        uint8_t dAlarm[8];
        int d1[8];
        #define DHT_DATA_PIN 6
        #define SENSOR_TEMP_OFFSET 0
        static const uint64_t UPDATE_INTERVAL = 5000;
        #define CHILD_ID_HUM 0
        #define CHILD_ID_TEMP 1
        #define CHILD_ID_MULTIMETER 2
        float lastTemp;
        float lastHum;
        uint8_t nNoUpdatesTemp;
        uint8_t nNoUpdatesHum;
        bool metric = true;
        MyMessage msgVolt(CHILD_ID_MULTIMETER, V_VOLTAGE);
        DHT dht;
        int oldBatteryPcnt = 0;
        int batteryBasement = 812;
        int batteryFull = 922;
        float batteryConstant = 100.0 / (batteryFull - batteryBasement);
        float lastbatteryV = 0;
        const int buzzer = 7; //buzzer to arduino pin 7
        #define RELAY_1  8  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
        void before()
          for (int sensor=3, pin=RELAY_1; sensor<=NUMBER_OF_RELAYS; sensor++, pin++) {
            pinMode(pin, OUTPUT);
           analogReference(INTERNAL);
          pinMode(LEDPIN, OUTPUT);
          digitalWrite(LEDPIN, LOW);
          Wire.begin();
          pinMode(CSMEM_PIN, OUTPUT);
          digitalWrite(CSMEM_PIN, HIGH);
          sleepIntervalSec = dht.getMinimumSamplingPeriod();
          clearAlarm();
          delay(20);
          setNewAlarm();
          analogRead(BATTERY_SENSE_PIN);
        void presentation() {
           sendSketchInfo("Humidity sensor", "1.0");
           present(CHILD_ID_MULTIMETER, S_MULTIMETER, "VOLT", true);
           present(CHILD_ID_HUM, S_HUM, "HUMIDITY", true);
           present(CHILD_ID_TEMP, S_TEMP, "TEMP", true);
            present(sensor, S_BINARY);
          wait(100);
           #ifdef MY_DEBUG
           Serial.println(sensorValue);
           float batteryV  = sensorValue * 0.004551646;
           if(sensorValue < batteryBasement) {
            sensorValue = batteryBasement;
            batteryV = 0;
           else if (sensorValue > batteryFull) {
            sensorValue = batteryFull;
           int batteryPcnt = (sensorValue - batteryBasement) * batteryConstant;
               if ((abs(oldBatteryPcnt - batteryPcnt) > 1)) {
              oldBatteryPcnt = batteryPcnt;
           if(batteryV != lastbatteryV) {
           send(msgVolt.set(batteryV, 2));
           lastbatteryV = batteryV;
           #ifdef MY_DEBUG
           Serial.print(batteryV);
           Serial.println(" V");
           Serial.print(batteryPcnt);
           Serial.println(" %");
          dht.readSensor(true);
          if (isnan(temperature)) {
            lastTemp = temperature;
            if (!metric) {
            // Reset no updates counter
            nNoUpdatesTemp = 0;
            #ifdef MY_DEBUG
            Serial.print("T: ");
            Serial.println(temperature);
          } else {
            nNoUpdatesTemp++;
          if (isnan(humidity)) {
            lastHum = humidity;
            nNoUpdatesHum = 0;
            #ifdef MY_DEBUG
            Serial.print("H: ");
            Serial.println(humidity);
          } else {
            nNoUpdatesHum++;
        long sleepTime = UPDATE_INTERVAL;
        if (batteryPcnt < 50) {
          sleepTime = (sleepTime * 2);
          sleepIntervalSec = sleepTime / 1000;
          Serial.println();
          Serial.print("Setting new sleep time: ");
          Serial.print(sleepIntervalSec);
          Serial.println(" seconds.");
          clearAlarm();
          delay(20);
          setNewAlarm();
          smartSleep(sleepTime);
          if (message.type==V_STATUS) {
            // Change relay state
            // Store state in eeprom
            // Write some debug info
            Serial.print(message.sensor);
        Sensor startup:
        0 MCO:BGN:INIT NODE,CP=RRNNA--,VER=2.1.1
        3 MCO:BGN:BFR
        4 TSM:INIT
        5 TSF:WUR:MS=0
        8 TSM:INIT:TSP OK
        9 TSM:INIT:STATID=66
        11 TSF:SID:OK,ID=66
        13 TSM:FPAR
        143 TSF:MSG:SEND,66-66-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        524 TSF:MSG:READ,0-0-66,s=255,c=3,t=8,pt=1,l=1,sg=0:0
        529 TSF:MSG:FPAR OK,ID=0,D=1
        2150 TSM:FPAR:OK
        2151 TSM:ID
        2152 TSM:ID:OK
        2154 TSM:UPL
        2161 TSF:MSG:SEND,66-66-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
        2181 TSF:MSG:READ,0-0-66,s=255,c=3,t=25,pt=1,l=1,sg=0:1
        2186 TSF:MSG:PONG RECV,HP=1
        2189 TSM:UPL:OK
        2190 TSM:READY:ID=66,PAR=0,DIS=1
        2199 TSF:MSG:SEND,66-66-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
        2253 TSF:MSG:READ,0-0-66,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
        2310 TSF:MSG:SEND,66-66-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
        2366 TSF:MSG:SEND,66-66-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
        2403 TSF:MSG:READ,0-0-66,s=255,c=3,t=6,pt=0,l=1,sg=0:M
        2461 TSF:MSG:SEND,66-66-0-0,s=255,c=3,t=11,pt=0,l=15,sg=0,ft=0,st=OK:Humidity sensor
        2562 TSF:MSG:SEND,66-66-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
        2618 TSF:MSG:SEND,66-66-0-0,s=2,c=0,t=30,pt=0,l=4,sg=0,ft=0,st=OK:VOLT
        2757 !TSF:MSG:SEND,66-66-0-0,s=0,c=0,t=7,pt=0,l=8,sg=0,ft=0,st=NACK:HUMIDITY
        2777 TSF:MSG:SEND,66-66-0-0,s=1,c=0,t=6,pt=0,l=4,sg=0,ft=1,st=OK:TEMP
        2912 !TSF:MSG:SEND,66-66-0-0,s=1,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=NACK:
        2918 MCO:REG:REQ
        2974 TSF:MSG:SEND,66-66-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=1,st=OK:2
        2991 TSF:MSG:READ,0-0-66,s=255,c=3,t=27,pt=1,l=1,sg=0:1
        2996 MCO:PIM:NODE REG=1
        2999 MCO:BGN:STP
        3154 MCO:SLP:MS=2000,SMS=0,I1=255,M1=255,I2=255,M2=255
        3160 MCO:SLP:TPD
        3161 MCO:SLP:WUP=-1
        3163 MCO:BGN:INIT OK,TSP=1
        Log Sensor: (This is when I press the button when the sensor is awake)
        It's sends away it's heartbeat correctly.
        125578 TSF:MSG:READ,0-0-66,s=3,c=1,t=2,pt=0,l=1,sg=0:0
        Incoming change for sensor:3, New status: 0
        Setting new sleep time: 5 seconds.
        137926 MCO:SLP:MS=5000,SMS=1,I1=255,M1=255,I2=255,M2=255
        137939 TSF:MSG:SEND,66-66-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=OK:134932
        Log Openhab: And the gateway receives heartbeat.
        18:21:37.174 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 66;3;1;0;2;0
        18:21:37.178 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'TestLight' received command OFF
        18:21:37.181 [INFO ] [marthome.event.ItemStateChangedEvent] - TestLight changed from ON to OFF
        18:22:15.416 [DEBUG] [rs.internal.protocol.MySensorsReader] - 66;255;3;0;22;134932
        18:22:16.372 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
        18:22:16.408 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;2;2.1.1
        Log Openhab: When the node sleeps..
        18:26:52.396 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 66;3;1;0;2;0
        18:26:52.397 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'TestLight' received command OFF
        18:26:52.399 [INFO ] [marthome.event.ItemStateChangedEvent] - TestLight changed from ON to OFF
        As you can see there is no mention in the openhab log file about buffering or smart sleep. Or a received heartbeat. Which it gets.
        What am I doing wrong?
        B
        B
        balder88
        I found the solution myself. About a week ago i upgraded the binding. And it worked.
        Everything seems to work as it should. Except I can't recieve var1 (custom) for neither the hum or temp child.
        smartSleep is nice. I use it once an hour (regular sleep every minute) to get configurations from openhab about sleep time and other small things in the code.
        @balder88 said in openHAB 2.0 binding:
        Things file:
        //  Anarduino
        Items file:
        #include <Wire.h>
        #include <DHT.h>
        #define CSMEM_PIN 5
        #define LEDPIN 9
        long loopCnt=0;
        uint8_t d[8];
        uint8_t dAlarm[8];
        int d1[8];
        float lastTemp;
        float lastHum;
        bool metric = true;
        DHT dht;
        void before()
          Wire.begin();
          clearAlarm();
          delay(20);
          setNewAlarm();
          wait(100);
           #ifdef MY_DEBUG
            batteryV = 0;
           #ifdef MY_DEBUG
            if (!metric) {
            nNoUpdatesTemp = 0;
            #ifdef MY_DEBUG
          } else {
            nNoUpdatesTemp++;
            lastHum = humidity;
            nNoUpdatesHum = 0;
            #ifdef MY_DEBUG
          } else {
            nNoUpdatesHum++;
          Serial.println();
          clearAlarm();
          delay(20);
          setNewAlarm();
        Sensor startup:
        3 MCO:BGN:BFR
        4 TSM:INIT
        5 TSF:WUR:MS=0
        8 TSM:INIT:TSP OK
        11 TSF:SID:OK,ID=66
        13 TSM:FPAR
        2150 TSM:FPAR:OK
        2151 TSM:ID
        2152 TSM:ID:OK
        2154 TSM:UPL
        2189 TSM:UPL:OK
        2918 MCO:REG:REQ
        2999 MCO:BGN:STP
        3160 MCO:SLP:TPD
        3161 MCO:SLP:WUP=-1
        • A
          A
          antonholmstedt
          First I want to thank you for this binding, got it working with my esp8266 gateway without any problems at all. However, I want to ask how the reconnection problem is developing, any plans to solve it or is it not possible? I've tried to scan the thread but didn't find any information regarding it.
          • A
            A
            Alpoy
            wrote on last edited by Alpoy
            #425
            Thanks for making this binding! :)
            One question, is there a specific reason motion (tripped) sensors have to be Contact items?
            In OH2 all the Z-wave motion sensors are Switches (AFAIK) so it would be nice if the mysensor PIR's could also be Switches so I can just add these to my existing motion sensor groups and rules.
            (I tried setting a triggered channel as Switch but it didn't work)
            andreacioniA 1 Reply Last reply
            • A Alpoy
              andreacioniA
              andreacioniA
              andreacioni
              @Alpoy check this discussion on GitHub. The question is still open.
              @antonholmstedt reconnection is currently implemented in binding (look here). Feel free to open an issue if you experience reconnection fails in your environment :smiley:
              • andreacioniA andreacioni
                A
                A
                antonholmstedt
                Yes I have reconnection problems right now, so will open an issue :)
                • N
                  N
                  Nicklas Starkel
                  I was checking back on this bindning and it really has matured!
                  On GitHub I see that there are some updates referring to MqTT protocol.
                  Are they available in the JAR that is posted here?
                  http://www.oberfoell.com/openhab2/org.openhab.binding.mysensors-2.0.0-SNAPSHOT.jar
                  Kudos on the great work!
                  T 1 Reply Last reply
                  • N Nicklas Starkel
                    TimO
                    @Nicklas-Starkel Well no, MQTT Gateway is not yet supported. :-(
                    I got distracted by my current hardware project and need to catch up on the binding. First tests of the MQTT addition to the binding look very promising and I'll include it soon.
                    The current release is this one: http://www.oberfoell.com/openhab2/org.openhab.binding.mysensors-2.1.0-SNAPSHOT.jar
                    While preparing the code to be included in OpenHAB2 I'm currently changing some things that will break the current configuration / things files. But I will give some information about that with the release of the next version.
                    • G
                      G
                      gonzalonal
                      Hi @TimO, @andreacioni.
                      I am doing some "expert mode" rules where I need to get the NodeId of a specific sensors, or at least, to get all the configured Nodes Ids. Is that possible?
                      I would like to cron a rule where every X minutes, heartbeat request message is sent to all configured nodes, so as to see wether they are alive or not.
                      Thanks, regards.
                      • G gonzalonal
                        Thanks, regards.
                        andreacioniA
                        andreacioniA
                        andreacioni
                        wrote on last edited by andreacioni
                        #431
                        Hi @gonzalonal :smiley:
                        In the new version of binding we have implemented a (beta-)function that allows you to send heartbeat message at certain interval without the need to write your own rules.
                        Please take a lock at this gateway-parameter (you must have set enableNetworkSanCheck=true and sanityCheckerInterval).
                        With sanCheckSendHeartbeat parameter set you could also use this node-parameter to put your nodes offline after a certain number of failure.
                        I hope this function will help you!
                        G 1 Reply Last reply
                          G
                          G
                          gonzalonal
                          Hi @andreacioni . Thats a great feature.
                          But for the moment, I think I prefer doing it manually, by rules, because of the way in which I can show my offline nodes in my sitemap and configure custom notifications for them.
                          For each node, I have a datetime item showing the time of last heartbeat response received. If more than 25' have passed (5 heartbeats request, 1 heartbeat request each 5 mins) without response, I fire up a notification telling that that specific node has gone offline.
                          So, back to my original question. Is there any way to get Node Ids at the rules engine?
                          Do you believe we can customize this kind of behavior with the beta feature proposed?
                          Thanks, regards.
                          • T
                            TimO
                            @gonzalonal I have no clue! Could be possible, but better ask at the OH2 community because the node Id is something that is specified in the thing description (xml) and maybe it is possible to access this information in rules.
                            • S
                              Samuel235
                              Does this happen to support MQTT gateways? You mention serial or ethernet, but openhab doesn't support ethernet so i'm assuming you mean ethernet as the mqtt ethernet gateway?
                              MySensors 2.1.1
                              • T TimO
                                andreacioniA
                                andreacioniA
                                andreacioni
                                Just few posts before 😉
                                @TimO said in openHAB 2.0 binding:
                                • S
                                  Samuel235
                                  I'm sorry, I ran a ctrl+f search and it either didn't show or i completely missed it, thank you for the prompt reply though.
                                  In this case then i will have to wait for this release then as i can't achieve what i need to do with rules. Do we have any idea when the release will be?
                                  MySensors 2.1.1
                                  • Igor AntolićI
                                    Igor AntolićI
                                    Igor Antolić
                                    Hi, did anyone hit the problem when it seems that all works fine
                                    and then mysensors plugin start to think that it failed connecting to bridge (even if it doesnt actually)
                                    Should I find newer version (last jar I found is since 2017-01-18)
                                    I put message from node every 1 second, and in log you will see "0;255;3;0;9;TSF:MSG:READ...." every second
                                    but every 10 second it recconects saying "Failed connecting to bridge...next retry in 10 seconds (Retry No.:31).... Shutting down serial connection!...
                                    17:40:21.656 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSF:MSG:READ,202-202-0,s=1,c=1,t=37,pt=2,l=2,sg=0:468
                                    17:40:21.657 [DEBUG] [rs.internal.protocol.MySensorsReader] - 202;1;1;0;37;468
                                    17:40:22.421 [ERROR] [col.serial.MySensorsSerialConnection] - Can't connect to serial port. Wrong port?
                                    17:40:22.424 [ERROR] [col.serial.MySensorsSerialConnection] - Failed connecting to bridge...next retry in 10 seconds (Retry No.:31)
                                    17:40:22.425 [DEBUG] [col.serial.MySensorsSerialConnection] - Shutting down serial connection!
                                    17:40:22.842 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSF:MSG:READ,202-202-0,s=1,c=1,t=37,pt=2,l=2,sg=0:486
                                    17:40:22.844 [DEBUG] [rs.internal.protocol.MySensorsReader] - 202;1;1;0;37;486
                                    17:40:24.029 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSF:MSG:READ,202-202-0,s=1,c=1,t=37,pt=2,l=2,sg=0:470
                                    17:40:24.032 [DEBUG] [rs.internal.protocol.MySensorsReader] - 202;1;1;0;37;470
                                    17:40:25.218 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSF:MSG:READ,202-202-0,s=1,c=1,t=37,pt=2,l=2,sg=0:474
                                    17:40:25.222 [DEBUG] [rs.internal.protocol.MySensorsReader] - 202;1;1;0;37;474
                                    17:40:26.406 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSF:MSG:READ,202-202-0,s=1,c=1,t=37,pt=2,l=2,sg=0:486
                                    17:40:26.407 [DEBUG] [rs.internal.protocol.MySensorsReader] - 202;1;1;0;37;486
                                    17:40:27.591 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSF:MSG:READ,202-202-0,s=1,c=1,t=37,pt=2,l=2,sg=0:466
                                    17:40:27.592 [DEBUG] [rs.internal.protocol.MySensorsReader] - 202;1;1;0;37;466
                                    17:40:28.783 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSF:MSG:READ,202-202-0,s=1,c=1,t=37,pt=2,l=2,sg=0:483
                                    17:40:28.786 [DEBUG] [rs.internal.protocol.MySensorsReader] - 202;1;1;0;37;483
                                    17:40:29.967 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSF:MSG:READ,202-202-0,s=1,c=1,t=37,pt=2,l=2,sg=0:483
                                    17:40:29.972 [DEBUG] [rs.internal.protocol.MySensorsReader] - 202;1;1;0;37;483
                                    17:40:31.158 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSF:MSG:READ,202-202-0,s=1,c=1,t=37,pt=2,l=2,sg=0:463
                                    17:40:31.163 [DEBUG] [rs.internal.protocol.MySensorsReader] - 202;1;1;0;37;463
                                    17:40:32.344 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSF:MSG:READ,202-202-0,s=1,c=1,t=37,pt=2,l=2,sg=0:487
                                    17:40:32.346 [DEBUG] [rs.internal.protocol.MySensorsReader] - 202;1;1;0;37;487
                                    17:40:32.431 [DEBUG] [col.serial.MySensorsSerialConnection] - Connecting to /dev/ttyUSB0 [baudRate:115200]
                                    17:40:32.435 [DEBUG] [col.serial.MySensorsSerialConnection] - Final port list: /dev/ttyUSB0
                                    17:40:33.530 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSF:MSG:READ,202-202-0,s=1,c=1,t=37,pt=2,l=2,sg=0:470
                                    17:40:33.533 [DEBUG] [rs.internal.protocol.MySensorsReader] - 202;1;1;0;37;470
                                    17:40:34.438 [ERROR] [col.serial.MySensorsSerialConnection] - Can't connect to serial port. Wrong port?
                                    17:40:34.440 [ERROR] [col.serial.MySensorsSerialConnection] - Failed connecting to bridge...next retry in 10 seconds (Retry No.:32)
                                    17:40:34.441 [DEBUG] [col.serial.MySensorsSerialConnection] - Shutting down serial connection!
                                    17:40:34.720 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSF:MSG:READ,202-202-0,s=1,c=1,t=37,pt=2,l=2,sg=0:472
                                    Igor AntolićI 1 Reply Last reply
                                    • Igor AntolićI Igor Antolić
                                      Igor AntolićI
                                      Igor AntolićI
                                      Igor Antolić
                                      @Igor-Antolić huh,... my mistake, just installed 2.1.0 instead of 2.0.0. It seems it is from 2017-03-07.
                                      I dont have a good way to find last version of lib. Any suggestion how to check if last stabile version of mysensors java lib?
                                        TimO
                                        @Igor-Antolić I'm glad it worked after the update!
                                        It currently is not possible to automatically update (or check) for the most recent version. There are currently two sources for the binding:
                                        • the IoT Marketplace
                                        • The link in the wiki on github
                                        The most convenient way is the integration in the official openhab2-plugins repository and I'm working on it, but I still have a lot of homework to do.
                                        Maybe the IoT Marketplace will soon support such mechanisms, there are a few extensions planned.
                                        • S Samuel235
                                          TimO
                                          @Samuel235 said in openHAB 2.0 binding:
                                          What is it, what you want to achieve? I'm running MQTT too, as a connection between OpenHAB2 and nodered (50% of my rules are now nodered based). My gateways are serial or ethernet based.
                                          serial / ethernet gateway
                                          OpenHAB2 binding
                                          MQTT Event bus
                                          nodered
                                          @Samuel235 Are you willing and have the ability to test the MQTT implementation of the binding? Any help is really appreciated!
                                          S 1 Reply Last reply
