  3. OpenHAB
  4. openHAB 2.0 binding
openHAB 2.0 binding
534 Posts 88 Posters 676.6k Views 99 Watching
  • N
    N
    Nicklas Starkel
    I was checking back on this bindning and it really has matured!
    On GitHub I see that there are some updates referring to MqTT protocol.
    Are they available in the JAR that is posted here?
    http://www.oberfoell.com/openhab2/org.openhab.binding.mysensors-2.0.0-SNAPSHOT.jar
    Kudos on the great work!
    • N Nicklas Starkel
      TimO
      @Nicklas-Starkel Well no, MQTT Gateway is not yet supported. :-(
      I got distracted by my current hardware project and need to catch up on the binding. First tests of the MQTT addition to the binding look very promising and I'll include it soon.
      The current release is this one: http://www.oberfoell.com/openhab2/org.openhab.binding.mysensors-2.1.0-SNAPSHOT.jar
      While preparing the code to be included in OpenHAB2 I'm currently changing some things that will break the current configuration / things files. But I will give some information about that with the release of the next version.
      andreacioniA 1 Reply Last reply
      • G
        G
        gonzalonal
        Hi @TimO, @andreacioni.
        I am doing some "expert mode" rules where I need to get the NodeId of a specific sensors, or at least, to get all the configured Nodes Ids. Is that possible?
        I would like to cron a rule where every X minutes, heartbeat request message is sent to all configured nodes, so as to see wether they are alive or not.
        Thanks, regards.
        • G gonzalonal
          Thanks, regards.
          andreacioniA
          andreacioniA
          andreacioni
          wrote on last edited by andreacioni
          #431
          Hi @gonzalonal :smiley:
          In the new version of binding we have implemented a (beta-)function that allows you to send heartbeat message at certain interval without the need to write your own rules.
          Please take a lock at this gateway-parameter (you must have set enableNetworkSanCheck=true and sanityCheckerInterval).
          With sanCheckSendHeartbeat parameter set you could also use this node-parameter to put your nodes offline after a certain number of failure.
          I hope this function will help you!
          G 1 Reply Last reply
          • andreacioniA andreacioni
            G
            G
            gonzalonal
            Hi @andreacioni . Thats a great feature.
            But for the moment, I think I prefer doing it manually, by rules, because of the way in which I can show my offline nodes in my sitemap and configure custom notifications for them.
            For each node, I have a datetime item showing the time of last heartbeat response received. If more than 25' have passed (5 heartbeats request, 1 heartbeat request each 5 mins) without response, I fire up a notification telling that that specific node has gone offline.
            So, back to my original question. Is there any way to get Node Ids at the rules engine?
            Do you believe we can customize this kind of behavior with the beta feature proposed?
            Thanks, regards.
            • T
              TimO
              @gonzalonal I have no clue! Could be possible, but better ask at the OH2 community because the node Id is something that is specified in the thing description (xml) and maybe it is possible to access this information in rules.
                Samuel235
                Does this happen to support MQTT gateways? You mention serial or ethernet, but openhab doesn't support ethernet so i'm assuming you mean ethernet as the mqtt ethernet gateway?
                MySensors 2.1.1
                • T TimO
                  andreacioniA
                  andreacioniA
                  andreacioni
                  Just few posts before 😉
                    Samuel235
                    I'm sorry, I ran a ctrl+f search and it either didn't show or i completely missed it, thank you for the prompt reply though.
                    In this case then i will have to wait for this release then as i can't achieve what i need to do with rules. Do we have any idea when the release will be?
                    MySensors 2.1.1
                    • Igor AntolićI
                      Igor AntolićI
                      Igor Antolić
                      Hi, did anyone hit the problem when it seems that all works fine
                      and then mysensors plugin start to think that it failed connecting to bridge (even if it doesnt actually)
                      Should I find newer version (last jar I found is since 2017-01-18)
                      I put message from node every 1 second, and in log you will see "0;255;3;0;9;TSF:MSG:READ...." every second
                      but every 10 second it recconects saying "Failed connecting to bridge...next retry in 10 seconds (Retry No.:31).... Shutting down serial connection!...
                      17:40:21.656 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSF:MSG:READ,202-202-0,s=1,c=1,t=37,pt=2,l=2,sg=0:468
                      17:40:21.657 [DEBUG] [rs.internal.protocol.MySensorsReader] - 202;1;1;0;37;468
                      17:40:22.421 [ERROR] [col.serial.MySensorsSerialConnection] - Can't connect to serial port. Wrong port?
                      17:40:22.424 [ERROR] [col.serial.MySensorsSerialConnection] - Failed connecting to bridge...next retry in 10 seconds (Retry No.:31)
                      17:40:22.425 [DEBUG] [col.serial.MySensorsSerialConnection] - Shutting down serial connection!
                      17:40:22.842 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSF:MSG:READ,202-202-0,s=1,c=1,t=37,pt=2,l=2,sg=0:486
                      17:40:22.844 [DEBUG] [rs.internal.protocol.MySensorsReader] - 202;1;1;0;37;486
                      17:40:24.029 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSF:MSG:READ,202-202-0,s=1,c=1,t=37,pt=2,l=2,sg=0:470
                      17:40:24.032 [DEBUG] [rs.internal.protocol.MySensorsReader] - 202;1;1;0;37;470
                      17:40:25.218 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSF:MSG:READ,202-202-0,s=1,c=1,t=37,pt=2,l=2,sg=0:474
                      17:40:25.222 [DEBUG] [rs.internal.protocol.MySensorsReader] - 202;1;1;0;37;474
                      17:40:26.406 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSF:MSG:READ,202-202-0,s=1,c=1,t=37,pt=2,l=2,sg=0:486
                      17:40:26.407 [DEBUG] [rs.internal.protocol.MySensorsReader] - 202;1;1;0;37;486
                      17:40:27.591 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSF:MSG:READ,202-202-0,s=1,c=1,t=37,pt=2,l=2,sg=0:466
                      17:40:27.592 [DEBUG] [rs.internal.protocol.MySensorsReader] - 202;1;1;0;37;466
                      17:40:28.783 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSF:MSG:READ,202-202-0,s=1,c=1,t=37,pt=2,l=2,sg=0:483
                      17:40:28.786 [DEBUG] [rs.internal.protocol.MySensorsReader] - 202;1;1;0;37;483
                      17:40:29.967 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSF:MSG:READ,202-202-0,s=1,c=1,t=37,pt=2,l=2,sg=0:483
                      17:40:29.972 [DEBUG] [rs.internal.protocol.MySensorsReader] - 202;1;1;0;37;483
                      17:40:31.158 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSF:MSG:READ,202-202-0,s=1,c=1,t=37,pt=2,l=2,sg=0:463
                      17:40:31.163 [DEBUG] [rs.internal.protocol.MySensorsReader] - 202;1;1;0;37;463
                      17:40:32.344 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSF:MSG:READ,202-202-0,s=1,c=1,t=37,pt=2,l=2,sg=0:487
                      17:40:32.346 [DEBUG] [rs.internal.protocol.MySensorsReader] - 202;1;1;0;37;487
                      17:40:32.431 [DEBUG] [col.serial.MySensorsSerialConnection] - Connecting to /dev/ttyUSB0 [baudRate:115200]
                      17:40:32.435 [DEBUG] [col.serial.MySensorsSerialConnection] - Final port list: /dev/ttyUSB0
                      17:40:33.530 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSF:MSG:READ,202-202-0,s=1,c=1,t=37,pt=2,l=2,sg=0:470
                      17:40:33.533 [DEBUG] [rs.internal.protocol.MySensorsReader] - 202;1;1;0;37;470
                      17:40:34.438 [ERROR] [col.serial.MySensorsSerialConnection] - Can't connect to serial port. Wrong port?
                      17:40:34.440 [ERROR] [col.serial.MySensorsSerialConnection] - Failed connecting to bridge...next retry in 10 seconds (Retry No.:32)
                      17:40:34.441 [DEBUG] [col.serial.MySensorsSerialConnection] - Shutting down serial connection!
                      17:40:34.720 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSF:MSG:READ,202-202-0,s=1,c=1,t=37,pt=2,l=2,sg=0:472
                      Igor AntolićI 1 Reply Last reply
                      • Igor AntolićI Igor Antolić
                        Igor AntolićI
                        Igor AntolićI
                        Igor Antolić
                        @Igor-Antolić huh,... my mistake, just installed 2.1.0 instead of 2.0.0. It seems it is from 2017-03-07.
                        I dont have a good way to find last version of lib. Any suggestion how to check if last stabile version of mysensors java lib?
                          TimO
                          @Igor-Antolić I'm glad it worked after the update!
                          It currently is not possible to automatically update (or check) for the most recent version. There are currently two sources for the binding:
                          • the IoT Marketplace
                          • The link in the wiki on github
                          The most convenient way is the integration in the official openhab2-plugins repository and I'm working on it, but I still have a lot of homework to do.
                          Maybe the IoT Marketplace will soon support such mechanisms, there are a few extensions planned.
                          • S Samuel235
                            TimO
                            @Samuel235 said in openHAB 2.0 binding:
                            What is it, what you want to achieve? I'm running MQTT too, as a connection between OpenHAB2 and nodered (50% of my rules are now nodered based). My gateways are serial or ethernet based.
                            serial / ethernet gateway
                            OpenHAB2 binding
                            MQTT Event bus
                            nodered
                            @Samuel235 Are you willing and have the ability to test the MQTT implementation of the binding? Any help is really appreciated!
                            S 1 Reply Last reply
                            • ben999B
                              ben999B
                              ben999
                              wrote on last edited by ben999
                              #441
                              Guys,
                              I am getting this in Karaf :
                              16:20:33.171 [WARN ] [thome.io.rest.core.item.ItemResource] - Received HTTP PUT request at 'items/MySensorsDevice21_Lock' with an invalid item type 'Status'.
                              and this in PaperUI
                               "ERROR : undefined - undefined"  "some error occured"
                              when trying to link "Lock status" of an rfid node to an item in PaperUI...
                              Is that anything to do with the binding ? Or shall i ask eslewhere ?
                              Thanks a lot for your help (in general as well ;) )
                              • T TimO
                                OpenHAB2 binding
                                MQTT Event bus
                                nodered
                                Samuel235
                                @TimO - I have implemented a work-around for the issue that i was facing. OpenHAB just can't handle a empty MQTT message, so there is a fix for the pulse sensor to work with OpenHAB by changing the message that it send over to the MQTT server.
                                If you're interested in how this is done, please refer to: https://forum.mysensors.org/topic/3088/pulse-power-meter-with-openhab/4
                                I will be documenting this in possibly better to read steps for people when I get chance to finish the documentation to my new hardware node for the Pulse Sensor.
                                MySensors 2.1.1
                                • L LastSamurai
                                  @TimO Right, I guess thats the problem. I have written my sketch against domoticz, so it expects either a 6 bit hex string (rgb = e.g. ff00ff) or a 9 bit (idk why) rgbw hex string (e.g. #ff00ff00).
                                  According to the mysensors docu "ff00ff00" would be right, I guess.
                                  RVMRVMR
                                  RVMRVMR
                                  RVMRVM
                                  @LastSamurai
                                  Hello, i'am trying to connect a RGBW node by the serial gateway, is there already a solution for the hexstring format in the bindings or do we need to handle the rgbw items separatly ?
                                  kind regards
                                  Roger
                                  • RVMRVMR RVMRVM
                                    @LastSamurai
                                    kind regards
                                    Roger
                                    TimO
                                    @RVMRVM could you give this one a try?
                                    https://github.com/tobof/openhab2-addons/issues/76
                                    It is not yet integrated into the main branch. If you could test it and give me some feedback I would be very grateful. :)
                                    M RVMRVMR 2 Replies Last reply
                                    • L
                                      L
                                      LastSamurai
                                      @RVMRVM Sorry I haven't had the time to test anything yet (was working on another project). Might take me a while to get to.
                                      • P patrick schaerer
                                        @TimO said:
                                        @bentrik said:
                                        I managed to find an addons directory in /usr/share/openhab2/addons, but I can´t find a way to copy the .jar file there, as I get permission denied both through WinSCP in sudo mode and terminal ssh. The folder has permission 0775.
                                        That is the correct directory if you installed OH2 via .deb. Seems like you are using a user in WinSCP that is not allowed to write to the directory above. To circumvent this:
                                        1. Copy the binding jar to /tmp.
                                        2. Login via ssh and execute:
                                        sudo cp /tmp/org.openhab.binding.mysensors-2.0.0-SNAPSHOT.jar /usr/share/openhab2/addons/
                                        and
                                        sudo chmod openhab.openhab /usr/share/openhab2/addons/org.openhab.binding.mysensors-2.0.0-SNAPSHOT.jar
                                        OH2 is started/stopped/restarted with
                                        service openhab2 start/stop/restart
                                        To log into the karaf console do:
                                        ssh openhab@localhost -p 8101
                                        Password is: habopen
                                        Follow the guide/wiki from:
                                        In the console enter feature:install openhab-transport-serial
                                        I have installed openhab with the openhabian image. I could start the mysensors gateway too.
                                        I followed the github-openhab2 installation instructions.
                                        To this point
                                        I read a lot of posts on this thread but on get this error:
                                        openhab> install openhab-transport-serial
                                        Bundle IDs:
                                        Error executing command: Error installing bundles:
                                        	Unable to install bundle openhab-transport-serial
                                        the chmod line posted above doesn't work neither. chmod does not accept openhab.openhab
                                        I dont have any clue how to install the binding for openhab2 ... why isn't that possible from paperui :-(
                                        the trung
                                        @patrick-schaerer
                                        hi patrick
                                        i follow your guide with command to install MPC23017 Binding on openhab2
                                        sudo chmod openhab.openhab /usr/share/openhab2/addons/org.openhab.binding.mcp23017-1.9.0.jar
                                        but it not work and has information" chmod: invalid mode: ‘openhab.openhab’
                                        then i take ":" instead of "." into account like
                                        sudo chmod openhab:openhab /usr/share/openhab2/addons/org.openhab.binding.mcp23017-1.9.0.jar
                                        but it same error
                                        0_1496478264776_upload-ff8c1fc1-81fa-4e92-9e2d-46d4d7ca3f33
                                        can you help me, please.
                                        thanks you
                                        • T the trung
                                          @patrick-schaerer
                                          hi patrick
                                          but it same error
                                          thanks you
                                          TimO
                                          @the-trung This thread is OpenHAB and MySensors binding related. Better ask here: https://community.openhab.org
                                          In your case I suppose you need to switch chmod with chown. :)
