  3. OpenHAB
  4. openHAB 2.0 binding
openHAB 2.0 binding
534 Posts 88 Posters 676.6k Views 99 Watching
  • G
    G
    gonzalonal
    Hi @TimO, @andreacioni.
    I am doing some "expert mode" rules where I need to get the NodeId of a specific sensors, or at least, to get all the configured Nodes Ids. Is that possible?
    I would like to cron a rule where every X minutes, heartbeat request message is sent to all configured nodes, so as to see wether they are alive or not.
    Thanks, regards.
    andreacioniA 1 Reply Last reply
    • G gonzalonal
      Thanks, regards.
      andreacioniA
      andreacioniA
      andreacioni
      wrote on last edited by andreacioni
      #431
      Hi @gonzalonal :smiley:
      In the new version of binding we have implemented a (beta-)function that allows you to send heartbeat message at certain interval without the need to write your own rules.
      Please take a lock at this gateway-parameter (you must have set enableNetworkSanCheck=true and sanityCheckerInterval).
      With sanCheckSendHeartbeat parameter set you could also use this node-parameter to put your nodes offline after a certain number of failure.
      I hope this function will help you!
      G 1 Reply Last reply
      • andreacioniA andreacioni
        G
        G
        gonzalonal
        Hi @andreacioni . Thats a great feature.
        But for the moment, I think I prefer doing it manually, by rules, because of the way in which I can show my offline nodes in my sitemap and configure custom notifications for them.
        For each node, I have a datetime item showing the time of last heartbeat response received. If more than 25' have passed (5 heartbeats request, 1 heartbeat request each 5 mins) without response, I fire up a notification telling that that specific node has gone offline.
        So, back to my original question. Is there any way to get Node Ids at the rules engine?
        Do you believe we can customize this kind of behavior with the beta feature proposed?
        Thanks, regards.
        • T
          TimO
          @gonzalonal I have no clue! Could be possible, but better ask at the OH2 community because the node Id is something that is specified in the thing description (xml) and maybe it is possible to access this information in rules.
            Samuel235
            Does this happen to support MQTT gateways? You mention serial or ethernet, but openhab doesn't support ethernet so i'm assuming you mean ethernet as the mqtt ethernet gateway?
            MySensors 2.1.1
            • T TimO
              @Nicklas-Starkel Well no, MQTT Gateway is not yet supported. :-(
              I got distracted by my current hardware project and need to catch up on the binding. First tests of the MQTT addition to the binding look very promising and I'll include it soon.
              The current release is this one: http://www.oberfoell.com/openhab2/org.openhab.binding.mysensors-2.1.0-SNAPSHOT.jar
              While preparing the code to be included in OpenHAB2 I'm currently changing some things that will break the current configuration / things files. But I will give some information about that with the release of the next version.
              andreacioniA
              andreacioniA
              andreacioni
              Just few posts before 😉
                Samuel235
                I'm sorry, I ran a ctrl+f search and it either didn't show or i completely missed it, thank you for the prompt reply though.
                In this case then i will have to wait for this release then as i can't achieve what i need to do with rules. Do we have any idea when the release will be?
                MySensors 2.1.1
                • Igor AntolićI
                  Igor AntolićI
                  Igor Antolić
                  Hi, did anyone hit the problem when it seems that all works fine
                  and then mysensors plugin start to think that it failed connecting to bridge (even if it doesnt actually)
                  Should I find newer version (last jar I found is since 2017-01-18)
                  I put message from node every 1 second, and in log you will see "0;255;3;0;9;TSF:MSG:READ...." every second
                  but every 10 second it recconects saying "Failed connecting to bridge...next retry in 10 seconds (Retry No.:31).... Shutting down serial connection!...
                  17:40:21.656 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSF:MSG:READ,202-202-0,s=1,c=1,t=37,pt=2,l=2,sg=0:468
                  17:40:21.657 [DEBUG] [rs.internal.protocol.MySensorsReader] - 202;1;1;0;37;468
                  17:40:22.421 [ERROR] [col.serial.MySensorsSerialConnection] - Can't connect to serial port. Wrong port?
                  17:40:22.424 [ERROR] [col.serial.MySensorsSerialConnection] - Failed connecting to bridge...next retry in 10 seconds (Retry No.:31)
                  17:40:22.425 [DEBUG] [col.serial.MySensorsSerialConnection] - Shutting down serial connection!
                  17:40:22.842 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSF:MSG:READ,202-202-0,s=1,c=1,t=37,pt=2,l=2,sg=0:486
                  17:40:22.844 [DEBUG] [rs.internal.protocol.MySensorsReader] - 202;1;1;0;37;486
                  17:40:24.029 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSF:MSG:READ,202-202-0,s=1,c=1,t=37,pt=2,l=2,sg=0:470
                  17:40:24.032 [DEBUG] [rs.internal.protocol.MySensorsReader] - 202;1;1;0;37;470
                  17:40:25.218 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSF:MSG:READ,202-202-0,s=1,c=1,t=37,pt=2,l=2,sg=0:474
                  17:40:25.222 [DEBUG] [rs.internal.protocol.MySensorsReader] - 202;1;1;0;37;474
                  17:40:26.406 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSF:MSG:READ,202-202-0,s=1,c=1,t=37,pt=2,l=2,sg=0:486
                  17:40:26.407 [DEBUG] [rs.internal.protocol.MySensorsReader] - 202;1;1;0;37;486
                  17:40:27.591 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSF:MSG:READ,202-202-0,s=1,c=1,t=37,pt=2,l=2,sg=0:466
                  17:40:27.592 [DEBUG] [rs.internal.protocol.MySensorsReader] - 202;1;1;0;37;466
                  17:40:28.783 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSF:MSG:READ,202-202-0,s=1,c=1,t=37,pt=2,l=2,sg=0:483
                  17:40:28.786 [DEBUG] [rs.internal.protocol.MySensorsReader] - 202;1;1;0;37;483
                  17:40:29.967 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSF:MSG:READ,202-202-0,s=1,c=1,t=37,pt=2,l=2,sg=0:483
                  17:40:29.972 [DEBUG] [rs.internal.protocol.MySensorsReader] - 202;1;1;0;37;483
                  17:40:31.158 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSF:MSG:READ,202-202-0,s=1,c=1,t=37,pt=2,l=2,sg=0:463
                  17:40:31.163 [DEBUG] [rs.internal.protocol.MySensorsReader] - 202;1;1;0;37;463
                  17:40:32.344 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSF:MSG:READ,202-202-0,s=1,c=1,t=37,pt=2,l=2,sg=0:487
                  17:40:32.346 [DEBUG] [rs.internal.protocol.MySensorsReader] - 202;1;1;0;37;487
                  17:40:32.431 [DEBUG] [col.serial.MySensorsSerialConnection] - Connecting to /dev/ttyUSB0 [baudRate:115200]
                  17:40:32.435 [DEBUG] [col.serial.MySensorsSerialConnection] - Final port list: /dev/ttyUSB0
                  17:40:33.530 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSF:MSG:READ,202-202-0,s=1,c=1,t=37,pt=2,l=2,sg=0:470
                  17:40:33.533 [DEBUG] [rs.internal.protocol.MySensorsReader] - 202;1;1;0;37;470
                  17:40:34.438 [ERROR] [col.serial.MySensorsSerialConnection] - Can't connect to serial port. Wrong port?
                  17:40:34.440 [ERROR] [col.serial.MySensorsSerialConnection] - Failed connecting to bridge...next retry in 10 seconds (Retry No.:32)
                  17:40:34.441 [DEBUG] [col.serial.MySensorsSerialConnection] - Shutting down serial connection!
                  17:40:34.720 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSF:MSG:READ,202-202-0,s=1,c=1,t=37,pt=2,l=2,sg=0:472
                  Igor AntolićI 1 Reply Last reply
                  • Igor AntolićI Igor Antolić
                    Igor AntolićI
                    Igor AntolićI
                    Igor Antolić
                    @Igor-Antolić huh,... my mistake, just installed 2.1.0 instead of 2.0.0. It seems it is from 2017-03-07.
                    I dont have a good way to find last version of lib. Any suggestion how to check if last stabile version of mysensors java lib?
                      TimO
                      @Igor-Antolić I'm glad it worked after the update!
                      It currently is not possible to automatically update (or check) for the most recent version. There are currently two sources for the binding:
                      • the IoT Marketplace
                      • The link in the wiki on github
                      The most convenient way is the integration in the official openhab2-plugins repository and I'm working on it, but I still have a lot of homework to do.
                      Maybe the IoT Marketplace will soon support such mechanisms, there are a few extensions planned.
                      • S Samuel235
                        TimO
                        @Samuel235 said in openHAB 2.0 binding:
                        What is it, what you want to achieve? I'm running MQTT too, as a connection between OpenHAB2 and nodered (50% of my rules are now nodered based). My gateways are serial or ethernet based.
                        serial / ethernet gateway
                        OpenHAB2 binding
                        MQTT Event bus
                        nodered
                        @Samuel235 Are you willing and have the ability to test the MQTT implementation of the binding? Any help is really appreciated!
                        S 1 Reply Last reply
                        • ben999B
                          ben999B
                          ben999
                          wrote on last edited by ben999
                          #441
                          Guys,
                          I am getting this in Karaf :
                          16:20:33.171 [WARN ] [thome.io.rest.core.item.ItemResource] - Received HTTP PUT request at 'items/MySensorsDevice21_Lock' with an invalid item type 'Status'.
                          and this in PaperUI
                           "ERROR : undefined - undefined"  "some error occured"
                          when trying to link "Lock status" of an rfid node to an item in PaperUI...
                          Is that anything to do with the binding ? Or shall i ask eslewhere ?
                          Thanks a lot for your help (in general as well ;) )
                          • T TimO
                            OpenHAB2 binding
                            MQTT Event bus
                            nodered
                            Samuel235
                            @TimO - I have implemented a work-around for the issue that i was facing. OpenHAB just can't handle a empty MQTT message, so there is a fix for the pulse sensor to work with OpenHAB by changing the message that it send over to the MQTT server.
                            If you're interested in how this is done, please refer to: https://forum.mysensors.org/topic/3088/pulse-power-meter-with-openhab/4
                            I will be documenting this in possibly better to read steps for people when I get chance to finish the documentation to my new hardware node for the Pulse Sensor.
                            MySensors 2.1.1
                            • L LastSamurai
                              @TimO Right, I guess thats the problem. I have written my sketch against domoticz, so it expects either a 6 bit hex string (rgb = e.g. ff00ff) or a 9 bit (idk why) rgbw hex string (e.g. #ff00ff00).
                              According to the mysensors docu "ff00ff00" would be right, I guess.
                              RVMRVMR
                              RVMRVMR
                              RVMRVM
                              @LastSamurai
                              Hello, i'am trying to connect a RGBW node by the serial gateway, is there already a solution for the hexstring format in the bindings or do we need to handle the rgbw items separatly ?
                              kind regards
                              Roger
                              • RVMRVMR RVMRVM
                                @LastSamurai
                                kind regards
                                Roger
                                TimO
                                @RVMRVM could you give this one a try?
                                https://github.com/tobof/openhab2-addons/issues/76
                                It is not yet integrated into the main branch. If you could test it and give me some feedback I would be very grateful. :)
                                M RVMRVMR 2 Replies Last reply
                                • L
                                  L
                                  LastSamurai
                                  @RVMRVM Sorry I haven't had the time to test anything yet (was working on another project). Might take me a while to get to.
                                  • P patrick schaerer
                                    @TimO said:
                                    @bentrik said:
                                    I managed to find an addons directory in /usr/share/openhab2/addons, but I can´t find a way to copy the .jar file there, as I get permission denied both through WinSCP in sudo mode and terminal ssh. The folder has permission 0775.
                                    That is the correct directory if you installed OH2 via .deb. Seems like you are using a user in WinSCP that is not allowed to write to the directory above. To circumvent this:
                                    1. Copy the binding jar to /tmp.
                                    2. Login via ssh and execute:
                                    sudo cp /tmp/org.openhab.binding.mysensors-2.0.0-SNAPSHOT.jar /usr/share/openhab2/addons/
                                    and
                                    sudo chmod openhab.openhab /usr/share/openhab2/addons/org.openhab.binding.mysensors-2.0.0-SNAPSHOT.jar
                                    OH2 is started/stopped/restarted with
                                    service openhab2 start/stop/restart
                                    To log into the karaf console do:
                                    ssh openhab@localhost -p 8101
                                    Password is: habopen
                                    Follow the guide/wiki from:
                                    In the console enter feature:install openhab-transport-serial
                                    I have installed openhab with the openhabian image. I could start the mysensors gateway too.
                                    I followed the github-openhab2 installation instructions.
                                    To this point
                                    I read a lot of posts on this thread but on get this error:
                                    openhab> install openhab-transport-serial
                                    Bundle IDs:
                                    Error executing command: Error installing bundles:
                                    	Unable to install bundle openhab-transport-serial
                                    the chmod line posted above doesn't work neither. chmod does not accept openhab.openhab
                                    I dont have any clue how to install the binding for openhab2 ... why isn't that possible from paperui :-(
                                    the trung
                                    @patrick-schaerer
                                    hi patrick
                                    i follow your guide with command to install MPC23017 Binding on openhab2
                                    sudo chmod openhab.openhab /usr/share/openhab2/addons/org.openhab.binding.mcp23017-1.9.0.jar
                                    but it not work and has information" chmod: invalid mode: ‘openhab.openhab’
                                    then i take ":" instead of "." into account like
                                    sudo chmod openhab:openhab /usr/share/openhab2/addons/org.openhab.binding.mcp23017-1.9.0.jar
                                    but it same error
                                    0_1496478264776_upload-ff8c1fc1-81fa-4e92-9e2d-46d4d7ca3f33
                                    can you help me, please.
                                    thanks you
                                    • T the trung
                                      @patrick-schaerer
                                      hi patrick
                                      but it same error
                                      thanks you
                                      TimO
                                      @the-trung This thread is OpenHAB and MySensors binding related. Better ask here: https://community.openhab.org
                                      In your case I suppose you need to switch chmod with chown. :)
                                      • carlylerC
                                        carlylerC
                                        carlyler
                                        wrote on last edited by carlyler
                                        #448
                                        I am trying to make use of the customSensor using org.openhab.binding.mysensors-2.1.0-SNAPSHOT.jar I see the node 12 var4 message arrive but it is not being assigned to my item; am I doing something wrong? I have tried both string and number item types.
                                        10:37:37.879 [DEBUG] [rsAbstractConnection$MySensorsReader] - 12;0;1;0;27;1023
                                        10:37:37.880 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 12 found in gateway
                                        10:37:37.881 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 0 found in node 12
                                        10:37:37.882 [DEBUG] [ensors.handler.MySensorsThingHandler] - Updating channel: var4(27) value to: 1023
                                        10:37:37.896 [DEBUG] [ensors.handler.MySensorsThingHandler] - Setting last update for node/child 12/0 to 2017-06-03T10:37:37.000-0400
                                        10:37:37.901 [DEBUG] [rsAbstractConnection$MySensorsReader] - 12;255;3;0;22;63464
                                        10:37:37.912 [INFO ] [marthome.event.ItemStateChangedEvent] - Sensor12LastUpdate changed from 2017-06-03T10:37:26.000-0400 to 2017-06-03T10:37:37.000-0400
                                        10:37:37.925 [INFO ] [marthome.event.ItemStateChangedEvent] - mySMsg01 changed from 1;4;1;0;1;64.2 to 12;0;1;0;27;1023
                                        10:37:37.935 [INFO ] [marthome.event.ItemStateChangedEvent] - mySMsg01 changed from 12;0;1;0;27;1023 to 12;255;3;0;22;63464
                                        10:37:41.974 [DEBUG] [rsAbstractConnection$MySensorsReader] - 2;0;1;0;17;544
                                        10:37:41.975 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 2 found in gateway
                                        10:37:41.976 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 0 found in node 2
                                        10:37:41.976 [DEBUG] [ensors.handler.MySensorsThingHandler] - Updating channel: watt(17) value to: 544
                                        10:37:41.984 [DEBUG] [ensors.handler.MySensorsThingHandler] - Setting last update for node/child 2/0 to 2017-06-03T10:37:41.000-0400
                                        10:37:41.995 [INFO ] [marthome.event.ItemStateChangedEvent] - watt01 changed from 547 to 544
                                        10:37:42.005 [DEBUG] [rsAbstractConnection$MySensorsReader] - 2;0;1;0;24;1138982
                                        10:37:42.006 [INFO ] [marthome.event.ItemStateChangedEvent] - Sensor02LastUpdate changed from 2017-06-03T10:37:27.000-0400 to 2017-06-03
                                        Things
                                        Bridge mysensors:bridge-eth:ethGatewayPi [ ipAddress="127.0.0.1", tcpPort=5003, sendDelay=200 ]
                                           humidity         hum01       [ nodeId="1", childId="0" ]
                                           temperature      temp01      [ nodeId="1", childId="1" ]
                                           humidity         hum02       [ nodeId="1", childId="2" ]
                                           temperature      temp02      [ nodeId="1", childId="3" ]
                                           humidity         hum03       [ nodeId="1", childId="4" ]
                                           temperature      temp03      [ nodeId="1", childId="5" ]
                                           power            power01     [ nodeId="2", childId="0" ]
                                           rgbLight         rgb02       [ nodeId="6", childId="0", requestAck=true ]
                                           light            relay01     [ nodeId="7", childId="0", requestAck=true ]
                                           motion           motion01    [ nodeId="8", childId="0", requestAck=true ]
                                           motion           motion02    [ nodeId="9", childId="0", requestAck=true ]
                                           light            relay02     [ nodeId="9", childId="1", requestAck=true ]
                                           cover            cover03     [ nodeId="10", childId="0", requestAck=true, smartSleep=true ]
                                           cover            cover02     [ nodeId="11", childId="0", requestAck=true, smartSleep=true ]
                                           customSensor     blind01     [ nodeId="12", childId="0", requestAck=true, smartSleep=true ]
                                        items:
                                        String blind1BatReading	    "Blind#1 Battery A/D Reading"  	<battery>			{ channel="mysensors:customSensor:ethGatewayPi:blind01:var4" }
                                        DateTime Sensor12LastUpdate "Last seen Nd12 [%1$ta %1$tT]"       <clock>    	{ channel="mysensors:customSensor:ethGatewayPi:blind01:lastupdate" }
                                        edit 6/7: I stand corrected, the variables are being updated. I was fooled by the log. For some reason the log does not show the change the way it did it binding 2.0.0. I placed debug messages in my rules and they're updating.
                                        • T TimO
                                          matt shepherd
                                          @TimO is it possible to configure using paper ui?
                                          cheers
                                          Matt
