  3. Mailbox/Postbox Alert
31 Posts 8 Posters 22.0k Views 7 Watching
  • F
    F
    f1dev
    @n3ro Ok, thanks! Then I learned something new today.. IRQ is only needed for receiving nodes then, like repeaters and gateways, right?
    Strange though that my circuit draws so much more current than yours. I have tested different setups, different arduinos and different radios from different suppliers with same result.
    Well, at least my mailbox are mysensored now! :smiley:
    • n3roN
      n3roN
      n3ro
      I think you need the irq only for the gw. I have a receive node without irq.
      Do you have changed fuses on your arduino?
      And remember. All this stuff is cheap China electronic.The devices can vary consume a lot of electricity.
      pimatic + MySensors + Homeduino + z-way
      https://github.com/n3roGit/MySensors_n3ro
      • F
        F
        f1dev
        Nope, havent done that yet. It´s a "stock" 3v3 pro mini. Still reading up on how to do that and how to change to MYS-bootloader, curious on how OTA-update works.
        Big thanks for your respons! :smile:
        n3roN 1 Reply Last reply
        • F f1dev
          n3roN
          n3roN
          n3ro
          @f1dev sweebe wrote a very good howto:
          http://forum.pimatic.org/topic/383/tips-battery-powered-sensors
          • F
            F
            f1dev
            @n3ro - Thanks, that was really helpfull!:smile:
            • n3roN n3ro
              Moshe LivneM
              Moshe LivneM
              Moshe Livne
              @n3ro Brilliant! He recommends to take out the voltage regulator. it is easier (and works better) just to snip off one leg as described here http://www.mysensors.org/build/battery. I'll try his other mods.... hopefully now my nodes will last forever!!!!
              • Ashley SavageA
                Ashley SavageA
                Ashley Savage
                quality project, been having a tinker with mixed results. used sketch from original post, but would it be possible to get a circuit diagram showing pull up locations??? bit of a beginner, but have had a few success with rolling out some power operated sensors , this is my first battery operated sensor...
                • n3roN
                  n3roN
                  n3ro
                  No problem. I make one :) give me a day
                  • Ashley SavageA Ashley Savage
                    n3roN
                    n3roN
                    n3ro
                    • Ashley SavageA
                      Ashley SavageA
                      Ashley Savage
                      thanks for the diagram, much appreciated...
                        mathieu44444
                        Does this code still work?
                        Thank you
