  3. Domoticz
  4. Dimmer doesn't appear in devices
33 Posts 6 Posters 15.7k Views 4 Watching
  • A Offline
    A Offline
    andrezibaia
    @Sparkman, nothing happens...
    No message at all in the serial monitor.
    S 1 Reply Last reply
    • A andrezibaia
      Sparkman
      @andrezibaia To rule out an issue with Domoticz, do you have the ability to hookup the gateway to MYSController? Might be worth a try to see what happens with it.
      Cheers
      Al
      • A Offline
        A Offline
        andrezibaia
        Yes, sure. Just did that.
        Here's what I have:
        upload-d51ca5cc-04b6-4516-9878-ce26ecbe57ed
        What should I do now?
        Cheers!
        • A andrezibaia
          Here's what I have:
          Cheers!
          Sparkman
          @andrezibaia Should be able to send a message to the node using the "Send Message" portion on the bottom of the screen.
          Cheers
          Al
          • A Offline
            A Offline
            andrezibaia
            Sure. What should I write in the payload section?
            I tried this, but nothing happened.
            upload-2fe2e7d5-4492-44df-b83d-e35436ce14b3
            I'm sorry for all the "noobness", I am still trying to learn all this...
            • A andrezibaia
              Sparkman
              @andrezibaia Looks correct. Anything in the serial monitor of the dimmer? Try the light subtype as well and send a 0 or a 1. What does the MYSController log show when you do this?
              Cheers
              Al
              • A Offline
                A Offline
                andrezibaia
                Nothing at all in the node serial monitor...
                The log from MYSController shows this:
                13/09/2015 19:53:01	TX	55;255;3;0;6;M
                13/09/2015 19:53:01	RX	55;255;3;0;6;0
                13/09/2015 19:53:04	RX	0;0;3;0;9;read: 55-55-0 s=0,c=0,t=4,pt=0,l=0,sg=0:
                13/09/2015 19:53:04	DEBUG	Update child id=0, type=DIMMER
                13/09/2015 19:53:04	RX	55;0;0;0;4;
                13/09/2015 19:53:04	RX	0;0;3;0;9;read: 55-55-0 s=255,c=3,t=11,pt=0,l=11,sg=0:DimmableLED
                13/09/2015 19:53:04	RX	55;255;3;0;11;DimmableLED
                13/09/2015 19:53:04	RX	0;0;3;0;9;read: 55-55-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.1
                13/09/2015 19:53:04	RX	55;255;3;0;12;1.1
                13/09/2015 19:53:04	RX	0;0;3;0;9;read: 55-55-0 s=0,c=2,t=3,pt=0,l=0,sg=0:
                13/09/2015 19:53:04	RX	55;0;2;0;3;
                13/09/2015 19:53:12	TX	55;0;1;0;3;50
                13/09/2015 19:53:46	RX	0;0;3;0;9;read: 55-55-0 s=255,c=0,t=17,pt=0,l=3,sg=0:1.5
                13/09/2015 19:53:46	DEBUG	Update child id=255, type=ARDUINO_NODE
                13/09/2015 19:53:46	RX	55;255;0;0;17;1.5
                13/09/2015 19:53:46	RX	0;0;3;0;9;read: 55-55-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                13/09/2015 19:53:46	TX	55;255;3;0;6;M
                13/09/2015 19:53:46	RX	55;255;3;0;6;0
                13/09/2015 19:53:48	RX	0;0;3;0;9;read: 55-55-0 s=0,c=0,t=4,pt=0,l=0,sg=0:
                13/09/2015 19:53:48	DEBUG	Update child id=0, type=DIMMER
                13/09/2015 19:53:48	RX	55;0;0;0;4;
                13/09/2015 19:53:48	RX	0;0;3;0;9;read: 55-55-0 s=255,c=3,t=11,pt=0,l=11,sg=0:DimmableLED
                13/09/2015 19:53:48	RX	55;255;3;0;11;DimmableLED
                13/09/2015 19:53:48	RX	0;0;3;0;9;read: 55-55-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.1
                13/09/2015 19:53:48	RX	55;255;3;0;12;1.1
                13/09/2015 19:53:48	RX	0;0;3;0;9;read: 55-55-0 s=0,c=2,t=3,pt=0,l=0,sg=0:
                13/09/2015 19:53:48	RX	55;0;2;0;3;
                13/09/2015 19:53:56	TX	55;0;1;0;3;50
                13/09/2015 19:54:16	TX	55;0;1;0;2;50
                13/09/2015 19:55:02	TX	55;0;1;0;2;50
                • A andrezibaia
                  Sparkman
                  The last 3 lines show you sending 50 to the dimmer device first (3) and then twice to the light device (2). The light device should only respond to a 0 or a 1. Have you tried sending that?
                  Cheers
                  Al
                  • A Offline
                    A Offline
                    andrezibaia
                    Yes, I tried that as well. Nothing happened.
                    In the meantime, the serial monitor from the node shows only this and nothing else:
                    send: 55-55-0-0 s=255,c=0,t=17,pt=0,l=3,sg=0,st=ok:1.5
                    send: 55-55-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
                    sensor started, id=55, parent=0, distance=0
                    send: 55-55-0-0 s=0,c=0,t=4,pt=0,l=0,sg=0,st=ok:
                    send: 55-55-0-0 s=255,c=3,t=11,pt=0,l=11,sg=0,st=ok:DimmableLED
                    send: 55-55-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.1
                    send: 55-55-0-0 s=0,c=2,t=3,pt=0,l=0,sg=0,st=ok:
                    Is it perhaps a problem with the radio? It only sends and does not receive?
                    I tried different NRF24L01+ chips, but the problem remains...
                    I even tried to feed the NRF chip through a 3.3v regulator, but nothing happens...
                    • A andrezibaia
                      Sparkman
                      It's possible, but none of the logs indicate a communications issue. Maybe @blacey who wrote the sketch or @hek have some other ideas.
                      Cheers
                      Al
                      A 1 Reply Last reply
                      • S Sparkman
                        Cheers
                        Al
                        A Offline
                        A Offline
                        andrezibaia
                        @Sparkman Thanks a lot for all your time and effort!
                        Cheers!
                        • A Offline
                          A Offline
                          andrezibaia
                          wrote on last edited by andrezibaia
                          #32
                          @Sparkman, after a lot of days of despair, I found the problem!
                          My gateway was built on a 3.3v Arduino Mini Pro. As soon as I set it up on a 5V one (I did not even need a power regulator for the radio, because I used one of those Sparkfun ones with an antenna.
                          Now it's all kicking ass! :dancer:
                          Thanks again, man!
                          • A andrezibaia
                            Thanks again, man!
                            Sparkman
                            wrote on last edited by Sparkman
                            #33
                            @andrezibaia You're welcome and glad to hear you got it resolved.
                            Cheers
                            Al
                            12.2k
