  3. Domoticz
  4. Help needed on a sketch...
16 Posts 2 Posters 5.9k Views 2 Watching
  • B
    B
    Bram81
    I'm running a serial gateway on a rpi running Domoticz with two moisture sensores connected. Since I want to feed the nodes by batteries I'm trying to only let the nodes send their info a couple of times a day, starting with a two hours interval for now.
    The nodes are seen by domoticz and their info is updated after two hours only once, after that no new data is send/received until I've restarted the nodes. Domoticz and the gateway are running fine for the entire time. It seems that the nodes don't wake up after sleeping for two hours for the second time. This is the sketch I use:
    Insert Code Here
    #define CHILD_ID_LIGHT 0
    #define LIGHT_SENSOR_ANALOG_PIN 1
    #define BATTERY_SENSE_PIN  A1  // select the input pin for the battery sense point
    #define MIN 300  // Liquid
    #define MAX 700 // Air
    int sensorPin = A0; // select the input pin for the potentiometer
    int sensorValue = 0; // variable to store the value coming from the sensor
    int lastLightLevel;
    int oldBatteryPcnt = 0;
    int battLoop =0;
    void setup(){
    Serial.begin(9600);
    gw.begin();
    gw.sendSketchInfo("Mobile2", "1.16");
    gw.present(CHILD_ID_LIGHT, S_LIGHT_LEVEL);
    void loop(){
    // read the value from the sensor:
    sensorValue = analogRead(sensorPin);
    delay(1000);
    int lastsensorValue = sensorValue;
    Serial.println(sensorValue);
    gw.send(msg.set(constrain(map(sensorValue, 1023, 250, 0, 100),0,100)));
    gw.sleep(1800000);
    void check_batt()
      // get the battery Voltage
      int batteryValue = analogRead(BATTERY_SENSE_PIN);
      Serial.println(batteryValue);
      // vout = (sensorvalue x 3.3) / 1023
      //vin = vout /  (R2/(R1+R2));
      float batteryV  = ( batteryValue * 0.003225806 ) / 0.3; // divide R2/(R1+R2)
      int batteryPcnt = batteryValue / 10 ;
      if ( batteryPcnt > 100 )
      batteryPcnt = 100;
      Serial.print(batteryV);
      Serial.println(" V");
      Serial.print(batteryPcnt);
      Serial.println(" %");
      if (oldBatteryPcnt != batteryPcnt)
        // Power up radio after sleep
        oldBatteryPcnt = batteryPcnt;
    I'm still a newbie when it comes to coding, so maybe there is just a obvious error that I just miss?
    BTW, the both nodes are fed through USB for now, so I'm sure it's not because of low battery levels. Is there anyone that can help me solve this?
    • rvendrameR
      rvendrameR
      rvendrame
      Did you try to remove the constrain() and move map() out of the equation?
      Like this:
        int sendValue =  map(sensorValue, 1023, 250, 0, 100);
        gw.send( msg.set( sendValue ) );
      And am I wrong or gw.sleep(1800000) = 20min?
      And finally, can you keep the note connected to serial monitor, so you would see the output after 2h (or 20min ;-) )?
      ESP8266 GW + mySensors 2.3.2
      Alexa / Google Home
      B 1 Reply Last reply
      • rvendrameR rvendrame
        Like this:
        B
        B
        Bram81
        @rvendrame Hi! Just changed the code as you suggested. That 1800000 was still from an old test, I'm sure that the sleeptime on the nodes was set for 2 hrs. It's set in miliseconds right? In that case it wasn't 20 but 30 minutes.. :wink:
        For the test I've set it to 600000 - do we agree on this being 10 min..? Since I'm using a Pro Trinket which can only use the serial monitor via FDTI I had to connect a breadbord to get some extra GND pins.. Node are running now.. Knowing more within the next half hour...
        • rvendrameR
          rvendrameR
          rvendrame
          Right, 1800000 = 30min, sorry.
          Alexa / Google Home
            B
            B
            Bram81
            @rvendrame Hi, It seems to work now... THANKS! Another question, I'm trying to measure the level of a 9v battery in the same sketch as well, using this:
            Insert Code Here
            ``#include <SPI.h>
            boolean metric = true;
            int lastLightLevel;
            int battLoop =0;
            void setup(){
            Serial.begin(9600);
            gw.begin();
            gw.sendSketchInfo("Mobile1", "1.16");
            void loop(){
            delay(1000);
              float batteryV  = ( batteryValue * 0.0088 ) / 0.8; // divide R2/(R1+R2)
              batteryPcnt = 100;
            gw.sleep(300000);
            Using this sketch causes the battery check into some kind of loop and not sending it back correctly to domoticz. Log shows:
            Battery Voltage: 1.68 V
            Battery percent: 15 %
            384
            send: 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,st=ok:82
            153
            385
            153
            384
            Any ideas on this?
            • rvendrameR
              rvendrameR
              rvendrame
              Just put the gw.sleep out of the if {}
              Alexa / Google Home
              • B
                B
                Bram81
                Ok, I'm almost where I want to be... Feeding my pro tinket 5v on a 9v battery I've managed to get the correct voltage reading. Which is aprox 9.10v on a new battery. The only thing I can't get to work is the % which I need to send to Domoticz .
                I'm using this code, being pretty sure that the formula is correct but whatever I try, the battery % is shown as 0 on every voltage level. Am I missing something... ?
                // number of analog samples to take per reading
                #define NUM_SAMPLES 10
                int sum = 0;                    // sum of samples taken
                unsigned char sample_count = 0; // current sample number
                float voltage = 0.0;            // calculated voltage
                void setup(){
                Serial.begin(9600);
                gw.begin();
                void loop(){
                delay(1000);
                  gw.sleep(3000);
                 // take a number of analog samples and add them up
                    while (sample_count < NUM_SAMPLES) {
                        sum += analogRead(A1);
                        sample_count++;
                        delay(10);
                    // calculate the voltage
                    // use 5.0 for a 5.0V ADC reference voltage
                    // 5.015V is the calibrated reference voltage
                    voltage = ((float)sum / (float)NUM_SAMPLES * 4.92) / 1024.0;
                    int Vmax = 9.10;
                int Vmin =4.92;
                int spanning = voltage * 11.714;
                   int batteryPcnt = ((spanning-Vmin)/(Vmax-Vmin))*100;
                  batteryPcnt = 100;
                    // send voltage for display on Serial Monitor
                    // voltage multiplied by 11 when using voltage divider that
                    // divides by 11. 11.132 is the calibrated voltage divide
                    // value
                    Serial.print(voltage * 11.714);
                    Serial.println (" V");
                    sample_count = 0;
                    sum = 0;
                • B
                  B
                  Bram81
                  Oh and I mean shown as 0% in the serial monitor since I haven't put in the gw.send command in yet..
                  • rvendrameR
                    rvendrameR
                    rvendrame
                    Did you try to define batteryPcnt as 'float' instead 'int'?
                    Alexa / Google Home
                    • B
                      B
                      Bram81
                      define batteryPcn as float didn't make a difference, but after that I did:
                      float spanning = voltage * 11.714;
                      float batteryPcnt = ((spanning-Vmin)/(Vmax-Vmin))*100;
                      It seems to be working now! Thanks a million again..
                      • B
                        B
                        Bram81
                        Do i have to use a different command to send the battterypcnt to the gateway?
                        gw.send(batteryPcnt);
                        gives this error:
                        no matching function for call to 'MySensor::send(float&)'
                        • rvendrameR
                          rvendrameR
                          rvendrame
                          it means gw.send() only accepts a integer --- So you need to set batteryPcnt back to int.
                          Alexa / Google Home
                          • B
                            B
                            Bram81
                            When i set batteryPcnt back to int it shows: no matching function for call to 'MySensor::send(int&)'
                            • rvendrameR
                              rvendrameR
                              rvendrame
                              I use this:
                              // Report battery level to controller
                              gw.sendBatteryLevel( bat_level );
                              Alexa / Google Home
                              • B
                                B
                                Bram81
                                Working like a charm now! Thank you very much for your help!!
                                • B
                                  B
                                  Bram81
                                  Hi there,
                                  I'm having another sketch problem.. In order to try and save battery power on my moisture sensors I'm trying to use a IO pin as power by setting it high for some time, let the sensor take a measurement, send the results to the gateway, setting the IO pin low again, let the node go to sleep for some time .
                                  This works only one time, the node presents itself to the gateway, sends data but after that it's not seen again after the expected sleep time.
                                  My guess is that somehow after puting the IO pin low it doesn't come back up in a high state. The strange thing is that when I measure the current on the pins of my moisture sensor with a multimeter the current goes from 0 to aprox 4.27V in the given time, so actually that indicates the pin is going from high to low as needed, but somehow the radio doesn't come back up... This is my code:
                                  int power =4;
                                  MyMessage msg(CHILD_ID_LIGHT, V_HUM);
                                  int lastLightLevel;
                                  void setup(){
                                  pinMode(power, OUTPUT);
                                  digitalWrite(power, HIGH);
                                  delay(3000);
                                  Serial.begin(9600);
                                  gw.begin();
                                  gw.sendSketchInfo("Mobile Sensor 1", "Kruiden");
                                  gw.present(CHILD_ID_LIGHT, S_HUM);
                                  delay (2000);
                                  void loop(){
                                  delay (5000);
                                  delay(1000);
                                  int sendValue =  map(sensorValue, 0, 842, 0, 100);
                                   delay(10000);
                                  digitalWrite(power, LOW);
                                  delay (2000);
                                  gw.sleep(60000);
                                  Does anyone have any clue..?
