  2. Announcements
  3. 1.4 Beta
1.4 Beta
1.4betahelp
129 Posts 18 Posters 121.8k Views 4 Watching
    @ServiceXp
    Yes correct!
    RJ_MakeR
    RJ_MakeR
    RJ_Make
    @hek
    I can only find MyConfig.h file, and DEBUG was already without the "//".
    So I noticed something VERY strange. It seems when I have the sensors connected to the computer, they start reading in Fahrenheit, and once I pull the USB cable it reverts back to Celsius with-in 30-60 seconds..
    RJ_Make
    • RJ_MakeR
      RJ_MakeR
      RJ_Make
      Yep, I have no idea how to debug this. The debug window reads in Fahrenheit, (and in Vera), but 30-60 seconds after I disconnect the usb cable from my computer (at which point I can't use the serial com window) it reverts back to Celsius.
      I've deleted one of the sensor nodes and child from Vera, cleared the eEPROM and re-install sketch and re-incuded back into Vera...
      I just don't understand why it works while connected to my computer...
      RJ_Make
      hekH 1 Reply Last reply
      • RJ_MakeR RJ_Make
        @ServiceXp
        No, this seems strange. The unit settings should get stored in eeprom.
        RJ_MakeR 1 Reply Last reply
          @ServiceXp
          RJ_MakeR
          RJ_MakeR
          RJ_Make
          @hek
          Do you think I can rule out my sensor hardware as it works with 1.3? Is there any way I can determine if it's being written to eEPROM while connected to the computer and then after it's disconnected (to see if it's getting overwritten)?
          RJ_Make
          • RJ_MakeR RJ_Make
            @hek
            @ServiceXp
            Do you call process() in loop()?
            But, really.. Don't put too much effort into this. Just hardcode sensor to send fahrenheit until conversion is done by controller plugin.
              @ServiceXp
              RJ_MakeR
              RJ_MakeR
              RJ_Make
              wrote on last edited by RJ_Make
              #126
              @hek
              I'm using the boiler plate sketch provided in the 1.4b1 files. The only modifications I've done is add battery code. (Copy and Paste).
              How to I hard code sensor to send in Fahrenheit?
              Sorry you have to hold my hand through this, I'm very new at this.....
              RJ_Make
              • RJ_MakeR RJ_Make
                @hek
                @ServiceXp
                Change
                To
                float temperature = static_cast<float>(static_cast<int>((sensors.getTempFByIndex(i)) * 10.)) / 10.;
                But I still wonder what goes wrong...
                  @ServiceXp
                  Change
                  To
                  RJ_MakeR
                  RJ_MakeR
                  RJ_Make
                  @hek
                  Worked perfectly for the temperature sensor, but it appears the Humidity and Temp. Sketch handles this differently. Not sure what to replace and where.
                  RJ_Make
                  • RJ_MakeR
                    RJ_MakeR
                    RJ_Make
                    Not very nice but I think this will work..
                      //float temperature = dht.getTemperature();
                     float temperature = dht.getTemperature()*9/5 + 32;
                     if (isnan(temperature)) {
                     lastTemp = temperature;
                       if (!metric) {
                      temperature = dht.getTemperature()*9/5 + 32;   //dht.toFahrenheit(temperature);
                    RJ_Make
