  3. Relay with switch
Relay with switch
relayswitch
5 Posts 3 Posters 3.7k Views 3 Watching
  • O Offline
    O Offline
    oded00
    Hi
    Is it possible to connect simple relay to regular on/off wall switch?
    Oded
    • R Offline
      R Offline
      rvendrame
      You have to change some wiring if you have only a single wire availble in the switch box.
      Have you checked the Relay project?
      ESP8266 GW + mySensors 2.3.2
      Alexa / Google Home
      • O Offline
        O Offline
        oded00
        In the relay project the button is push button.
        Can I use on/off switch with the same sketch?
        • R Offline
          R Offline
          rvendrame
          I think you just need to change this line:
          if (value != oldValue && value==0) {
          to
          if (value != oldValue) {
          And wire the original switch , in order to short GND and pin 3. The original wires now go to the relay (and not more to the switch).
          You need to somehow power arduino + radio + relay , I use cheap phone chargers but the risk of fire is too high. We are testing other alternatives here.
          And please be careful when working with AC Mains! It is letal! ;-)
          Alexa / Google Home
          • D Offline
            deennoo
            Thanks for this input, please can you share which kind of relay i have to use ?
