  3. Wind sensors
Wind sensors
8 Posts 6 Posters 6.7k Views 3 Watching
  • O
    O
    otto001
    I am thinking about buying one of those http://www.aliexpress.com/item/WIND-SPEED-SENSOR-JRFS-01-Aluminum-alloy-manufacture/1490853251.html
    for shutter control.
    It is working with reed contacts and gives 10 pulses for a wind speed of 1m/s.
    Does anyone know how something like this could be implemented with mysensors?
    Thanks in advance,
    Otto
    SparkmanS Moshe LivneM 2 Replies Last reply
    • O otto001
      Thanks in advance,
      Otto
      SparkmanS
      SparkmanS
      Sparkman
      @otto001 Hi Otto, you should be able to use one of the pulse counting projects as a way to get started. You'd have to count the pulses over a given time interval and then calculate the wind-speed over that interval. It's definitely do-able.
      Cheers
      Al
      • O otto001
        Thanks in advance,
        Otto
        Moshe LivneM
        Moshe LivneM
        Moshe Livne
        @otto001 I would think that reed might be a bit of a problem if too windy. Don't know for sure but got the impression that their response time is far from being instantaneous. Probably a better idea would be to use hall effect, no? you might even use a current measuring sensor if you rotate a turbine. but i am just guessing, I really don't know much.
        korttomaK 1 Reply Last reply
        • Moshe LivneM Moshe Livne
          korttomaK
          korttomaK
          korttoma
          @Moshe-Livne and @otto001 according to the description for the wind sensor linked to it uses an optocoupler and not reed switch.
          • Tomas
          • T
            treb0r
            wrote on last edited by treb0r
            I have this one:http://www.maplin.co.uk/search?text=Maplin+Replacement+Wind+Speed+Sensor+for+N96FY
            Is much cheaper and works. It has one reed switch, and one turn/s indicates 2,4 km/h
            For rain gauge I have also this part. http://www.maplin.co.uk/search?text=Maplin+Replacement+Wind+Speed+Sensor+for+N96FY
            Works in the same way
            Here you have how it looks inside: http://www.philpot.me/weatherinsider.html
            and here you have some code:
            http://sandaysoft.com/forum/viewtopic.php?f=16&t=10868
            treb0r
            NeverDieN 1 Reply Last reply
            • O
              O
              otto001
              Thanks a lot for the hints, especially @treb0r :-)
              I will have a closer look at it as soon as I have the wind sensor
              • T treb0r
                treb0r
                NeverDieN
                NeverDieN
                treb0r
                That seems like a great prices on the wind sensor. Unfortunately, it looks as though Malin won't ship to the USA. :anguished:
                T 1 Reply Last reply
                • NeverDieN NeverDie
                  treb0r
                  treb0r
                  You can always find somebody who can buy and send it for you ;) I have this privilege that my friend goes to UK very often so he brought me some pcs from Maplin ;)
                  treb0r
