  3. Introducing MySensors on nRF24LE1
myscontrollernrf24le1soc
37 Posts 18 Posters 34.9k Views 18 Watching
  • J
    J
    Justin Decker
    wrote on last edited by Justin Decker
    #21
    I've done a lot of work on this chip. Nothing for this project though.
    You can take a look here.
    https://hackaday.io/project/6270-io-node
    @tekka I released my code under GPL3.
    • D
      D
      demon1977
      This post is deleted!
      • D
        D
        demon1977
        wrote on last edited by demon1977
        #23
        sdcc --model-large --std-sdcc99-Iinclude -I../nRF24LE1_SDK/_target_sdcc_nrf24le1_32/include -I../nRF24LE1_SDK/
        include -L../nRF24LE1_SDK/ -c main.c
        Have:
        main.c:374: warning 158: overflow in implicit constant conversion
        What is this error and how to fix it?
        • J
          J
          jobarjo
          Thanks a lot for this, that's exactly what I was looking for.
          This is very cheap, small, and low power.
          I'm still waiting to receive one to try.
          Please note the existance of existing libraries including a wiring library which looks great:
          https://hackaday.io/project/5794-nrf24le1-wiring-library
          It is written by Justin who just posted above.
          There is also a rf24.h there, I don't know if it is compatible with arduino's lib?
          It seems you have made your own digitalRead/Write?
          I'm still very new to all this.
          I will start to setup a dev environment (ubuntu) and try to compile your stuff.
          Do you plan something else?
          Create a library? Is MySensor only C++? Is there a plan to create a C MySensor library?
          Too bad that most MySensor examples are in C++...
          Would you like to create a github repo?
          J 1 Reply Last reply
          • J jobarjo
            J
            J
            Justin Decker
            @jobarjo thanks for taking a look. The Wiring library isn't much more than a bunch of macros for the SDK. I chose to do it that way because SDCC will keep unused code in the output it generates. So yes, there is most everything you would expect if you are coming from arduino. digitalRead etc are all there.
            There is also a very alpha version of the RF24 library. It is in C of course, so a small amount of porting is needed.
            Let me know if you run into any problems. I am busy with another project at the moment with the nrf51822 SoC which is actually similarly priced and much more capable, although much more cumbersome to work with at the moment.
            • J
              J
              jobarjo
              @Justin-Decker said:
              nrf51822
              module costs 6.18 euro on ebay, 32 bit arm 16k sram, 256k flash!!
              compatible with nrf24 radio and bluetooth smart.
              I'm impressed!
              Seems compatible with arm mbed, and there even exists arduino add-on ? (looks like commercial...)
              I will look at existence of linux tools, will order one, and see if porting mysensor on this is easy...
              • J jobarjo
                nrf51822
                I'm impressed!
                J
                J
                Justin Decker
                @jobarjo Yes, there are implementations using mbed. If you go that route, you also get a nice BLE API to work with as well as all the standard mbed stuff. I haven't looked too closely at the Arduino board (Red Bear), but their source is on github so you can pull that and work with it without having the actual board.
                https://hackaday.io/project/8512-nrf51822-development is my project for this chip. It includes a working project skeleton and instructions on setting up debugging. It uses a custom board that I made, but I suspect the one you linked to on ebay will work.
                • D
                  D
                  Diogo Salazar
                  Quick question on the topic of using the nRF24LE1 as a platform.
                  Can the AES accelerator be used in order to sign messages?
                  Thanks.
                  • AnticimexA
                    AnticimexA
                    Anticimex
                    No, AES is used for encryption. The HMAC/SHA256 signing format MySensors use, has no benefit of AES.
                    • D
                      D
                      Diogo Salazar
                      @Anticimex : Thanks for the quick response. I have got my terms mixed there, thanks for clarifying.
                      AnticimexA 1 Reply Last reply
                      • D Diogo Salazar
                        AnticimexA
                        AnticimexA
                        Anticimex
                        @Diogo-Salazar You are welcome :)
                        • tekkaT tekka
                          First impression of MySensors running on nRF24LE1. Reporting temperature / humidity from DHT22, VCC voltage and millis() timer.
                          This SoC has many interesting features (SPI, 2-Wire, Serial, GPIO, ADC, RNG, AES accelerator, etc. ) and sub uA sleeping modes - without the need to solder a RF module. However, flash size limited to 16kB - still more than enough for many (peripheral) sensors... :)
                          Readings in MYSController:
                          Compiling with SDCC and nRF24LE1 SDK.
                          Source (Proof of concept/POC, non-optimized) here.
                          Y
                          Y
                          ykhokhlov
                          @tekka Hi! I'm trying to assemble this setup :-)
                          Could you provide the wiring diagram (humidity sensor and NRF).
                          Do you have an updated code?
                          C 1 Reply Last reply
                          • Y ykhokhlov
                            C
                            C
                            chickey
                            @ykhokhlov would like to get it going as well, have a requirement for a tiny form factor, have had one of these in the drawer forever.
                            tekkaT 1 Reply Last reply
                            • C chickey
                              tekkaT
                              tekkaT
                              tekka
                              wrote on last edited by tekka
                              #34
                              @chickey @ykhokhlov This was a POC I did a few years ago and never updated the code nor did I do further development on the library due to limited interest. There are way better alternatives available nowadays, i.e. nrf51/nrf52.
                              Y 1 Reply Last reply
                              • tekkaT tekka
                                Y
                                Y
                                ykhokhlov
                                @tekka Thanks for the answer and suggestion. Did you develop a POC of a MySensors node for the nrf51/nrf52?
                                NeverDieN 1 Reply Last reply
                                • Y ykhokhlov
                                  NeverDieN
                                  NeverDieN
                                  @ykhokhlov There are a ton of not just POCs but also fully functioning mysensors nrf51/nrf52 nodes on openhardware.io Just click and have a look for yourself.
                                  • NeverDieN NeverDie
                                    Y
                                    Y
                                    ykhokhlov
                                    @neverdie Thank you!
