Repeater nood keeps looping... and doesnt reach gw.
Ok, with some help from @celonunes I think we found the problem.
It has been pushed to master.. just one little eeprom write that was missing. ;)
@hek Correct me if im wrong - but can this been a bug from 1.4?
I had 1.4 on another laptop, uploaded the repeaterscetch there... then my last relay (new and 1.5) didnt work (stupid me - i didnt check repeter log though) - bu I changed computer reuploaded the new 1.5 and the new relay worked.
Can be a good to know for people upgrading to 1.5 - if my finding is correct they should upgrade repeaters asap.
Ok - tnx! :)
Hello Team,
I think I fall into the same issue. My repeater goes into a loop (led is blinking continiously), and nothing is not longer working on the repeaterI changed everything (nano/NRF PA/LNA). NRF is powered externally, adding Cap also. Issue seems like to be the same. I can't connect full time in USB because my repeater is outside. Repeater stuck after between 1 day and 2 weeks.
I have a serial console on the sensor, and after a while, packet are sent st=ok, but packets doesn't reach the GW which work correctly...
I use library 1.5 for the repeater / node / GW (downloaded in august)... I don't understand the conclusion !!! What should I do, downgrade to 1.4 ??? what is the line code changed, to compare if I have the fix into my library already...please advise, I'm working on this issue since 3 months without any finding...Should I clear the eeprom ?
Thanks a lot ! -
Hi @doblanch!
This issue was resolved in 1.5 and if you are using 1.5 you should do fine!
My repeaters use 1.5 and works great.
