  3. Trying to combine Temp + Battery level-sketch, What is wrong?
4 Posts 3 Posters 2.3k Views 1 Watching
  • Cliff KarlssonC
    Cliff KarlssonC
    Cliff Karlsson
    Hi I tried to combine The temperature & battery-level sketch into one but it does not work. I can see the sensor getting detected in the domoticz log but it does not show up under devices.
     * Example sketch showing how to send in DS1820B OneWire temperature readings back to the controller
     * http://www.mysensors.org/build/temp
    #include <OneWire.h>
    unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in milliseconds)
    int numSensors=0;
    int oldBatteryPcnt = 0;
    boolean metric = true;
    MyMessage msg(0,V_TEMP);
       analogReference(INTERNAL1V1);
    #else
       analogReference(INTERNAL);
      sensors.begin();
      gw.begin();
      gw.sendSketchInfo("Temperature Sensor+Battery", "1.1");
         gw.present(i, S_TEMP);
      gw.process();
      gw.sleep(conversionTime);
        #if COMPARE_TEMP == 1
        #else
        // get the battery Voltage
       #ifdef DEBUG
       Serial.println(sensorValue);
       float batteryV  = sensorValue * 0.003363075;
       #ifdef DEBUG
       Serial.print(batteryV);
       Serial.println(" V");
       Serial.print(batteryPcnt);
       Serial.println(" %");
         // Power up radio after sleep
         oldBatteryPcnt = batteryPcnt;
      gw.sleep(SLEEP_TIME);
    • sundberg84S
      What does domotizcs log say?
      • T
        treb0r
        wrote on last edited by treb0r
        @Cliff-Karlsson said:
        int numSensors=0;
        It seems that you have 0 temp sensors
        treb0r
        • Cliff KarlssonC
          Cliff KarlssonC
          Cliff Karlsson
          I am definitly no expert but I guess that is only a setup value. This part I think sets the proper value of sensors:
