  3. Serial Monitor of the gateway shows change but no change on the vera
3 Posts 3 Posters 1.5k Views 1 Watching
  • DrJeffD
    DrJeffD
    DrJeff
    On the serial monitor output I see motion being changed. But I can not see the change being made on the vera.
    send: 31-31-0-0 s=255,c=3,t=11,pt=0,l=16,sg=0,st=ok:RGB Led strip 3D
    send: 31-31-0-0 s=255,c=3,t=12,pt=0,l=2,sg=0,st=ok:v1
    send: 31-31-0-0 s=6,c=0,t=4,pt=0,l=17,sg=0,st=ok:present RED light
    send: 31-31-0-0 s=4,c=0,t=4,pt=0,l=19,sg=0,st=ok:present GREEN light
    send: 31-31-0-0 s=5,c=0,t=4,pt=0,l=18,sg=0,st=ok:present BLUE light
    send: 31-31-0-0 s=0,c=0,t=3,pt=0,l=19,sg=0,st=ok:present Show button
    send: 31-31-0-0 s=3,c=0,t=1,pt=0,l=14,sg=0,st=ok:present Motion
    Load from eeprom RED: 0%
    Load from eeprom GREEN: 0%
    Load from eeprom BLUE: 0%
    Send eeprom value to controler
    send: 31-31-0-0 s=6,c=1,t=3,pt=1,l=1,sg=0,st=ok:0
    send: 31-31-0-0 s=4,c=1,t=3,pt=1,l=1,sg=0,st=ok:0
    send: 31-31-0-0 s=5,c=1,t=3,pt=1,l=1,sg=0,st=ok:0
    send: 31-31-0-0 s=0,c=1,t=2,pt=2,l=2,sg=0,st=ok:0
    Ready to receive messages...
    send: 31-31-0-0 s=3,c=1,t=1,pt=1,l=1,sg=0,st=ok:1
    send: 31-31-0-0 s=3,c=1,t=1,pt=1,l=1,sg=0,st=ok:0
    As seen after Ready to receive messages... that is the motion sensor working but in Vera it shows no difference here is the code used it is a mix of @hek RGB code mixed with a motion sensor. The idea of the motion sensor is just to report if there is motion. It is a presence sensor for the room if I want it to turn on the the LED it will be scripted separate from the arduino code.
     * Version 1.0 - Created by vil1driver
     * RGB led strip controled with three dimmers + one On/Off for run/stop rgb color cycle :p
    #define SN   "RGB Led strip 3D"
    #define SV   "v1"
    // Load mysensors library
    // Load Serial Peripheral Interface library
    // Arduino pin attached to MOSFET Gate pin
    #define RED_PIN 4
    #define GREEN_PIN 5
    #define BLUE_PIN 6
    // added motion
    #define Motion_PIN 3
    #define INTERRUPT Motion_PIN-2
    uint8_t lastMotion = 0;
    unsigned long previousMillis = 0; // last time update //see http://stackoverflow.com/questions/10773425/performing-a-function-after-x-time for more details on this
    unsigned long motionDelay = 10000; // interval at which to keep motion sensor trippped (milliseconds).  Used to prevent too frequent updates to Vera.
    // Define message name and type to send sensor info
    MyMessage RedStatus(RED_PIN, V_DIMMER);
    MyMessage GreenStatus(GREEN_PIN, V_DIMMER);
    MyMessage BlueStatus(BLUE_PIN, V_DIMMER);
    MyMessage Status(1, V_DIMMER);
    MyMessage rgbShowState(0, V_LIGHT);
    MyMessage MotionStatus(Motion_PIN, S_MOTION);
    // Serial.print translate sensor id to sensor name
    char color[][6] = {"","","","RED","","GREEN","BLUE"};
    // Vars for rgbShow function
    int redval = 0;
    int greenval = 0;
    int blueval = 0;
    long time=0;
    int isShow;
      //motion setup
      //pinMode(Motion_PIN, INPUT);
      // Initializes the sensor node (Callback function for incoming messages, node id, is repeater)
      // Present sketch (name, version)
      gw.sendSketchInfo(SN, SV);
      // Register sensors (id, type, description, ack back)
      gw.present(RED_PIN, S_DIMMER, "present RED light", false);
      gw.present(GREEN_PIN, S_DIMMER, "present GREEN light", false);
      gw.present(BLUE_PIN, S_DIMMER, "present BLUE light", false);
      gw.present(0, S_LIGHT, "present Show button", false);
      // motion present
      gw.present(Motion_PIN, S_MOTION, "present Motion", false);
      // Define pin mode (pin number, type)
      pinMode(RED_PIN, OUTPUT);
      pinMode(GREEN_PIN, OUTPUT);
      pinMode(BLUE_PIN, OUTPUT);
      // Correct saved RGB value for first start
      gw.saveState(RED_PIN, constrain((int8_t)gw.loadState(RED_PIN), 0, 100));
      gw.saveState(GREEN_PIN, constrain((int8_t)gw.loadState(GREEN_PIN), 0, 100));
      gw.saveState(BLUE_PIN, constrain((int8_t)gw.loadState(BLUE_PIN), 0, 100));
      // Get value from eeprom and write to output
      analogWrite(RED_PIN, 255 * gw.loadState(RED_PIN) / 100);
      analogWrite(GREEN_PIN, 255 * gw.loadState(GREEN_PIN) / 100);
      analogWrite(BLUE_PIN, 255 * gw.loadState(BLUE_PIN) / 100);
      // Write some debug info
      Serial.print("Load from eeprom RED: ");
      Serial.print(gw.loadState(RED_PIN));
      Serial.println("%");
      Serial.print("Load from eeprom GREEN: ");
      Serial.print(gw.loadState(GREEN_PIN));
      Serial.print("Load from eeprom BLUE: ");
      Serial.print(gw.loadState(BLUE_PIN));
      // Send RGB value to controler (request ack back: true/false)
      Serial.println("Send eeprom value to controler");
      gw.send( RedStatus.set(gw.loadState(RED_PIN)), false );
      gw.send( GreenStatus.set(gw.loadState(GREEN_PIN)), false );
      gw.send( BlueStatus.set(gw.loadState(BLUE_PIN)), false );
      // Correct RGB show state for first start and load it (set to 'On' at first start)
      gw.saveState(0, constrain((int8_t)gw.loadState(0), 0, 1));
      isShow=gw.loadState(0);
      // Send RGB show state to controler (request ack back: true/false)
      gw.send( rgbShowState.set(isShow), false);
      if (isShow==1){Serial.println("RGB show running..."); }
      Serial.println("Ready to receive messages...");
      // Process incoming messages (like config and light state from controller)
      gw.process();
      // Run RGB show if is set
      if (isShow==1)
          rgbShow();
        analogWrite(RED_PIN, redval);
        analogWrite(GREEN_PIN, greenval);
        analogWrite(BLUE_PIN, blueval);
        // Read digital motion value
         if(currentMillis - previousMillis > motionDelay){
          uint8_t motionDetect = digitalRead(Motion_PIN);
          if(motionDetect != lastMotion){
    //        Serial.print("motionDetect Value: ");
    //        Serial.println(motionDetect);
            gw.send(MotionStatus.set(motionDetect));  // Send tripped value to gw
            if(motionDetect == 1){
              previousMillis = currentMillis;  //"Tripped" delay
            else{
              previousMillis = currentMillis - motionDelay + 1000; //"Not tripped" delay for 1 second to stop rapid "not tripped" and "tripped" updates to Vera
             lastMotion = motionDetect;
      if (message.isAck())
        Serial.println("Got ack from gateway");
      if (message.type == V_LIGHT)
        // Incoming on/off command sent from controller ("1" or "0")
        int lightState = message.getString()[0] == '1';
        // if receive RGB Show On commands, start the show
        if (message.sensor==0 && lightState==1){ rgbShowOn(); }
            // if receive RGB Show Off commands, stop the show
        else if (message.sensor==0 && lightState==0){ rgbShowOff(); }
        // if receive RGB switch On command
        else if (lightState==1)
                Serial.print("Incoming change for ");
                Serial.print(color[message.sensor]);
                Serial.println(": On");
                Serial.print("Load from eeprom: ");
          if ( gw.loadState(message.sensor) == 0)
            // Pick up last saved dimmer level from the eeprom
                    analogWrite(message.sensor, 255 * gw.loadState(10*message.sensor) / 100);
                    // Save loaded value to current
                    gw.saveState(message.sensor, gw.loadState(10*message.sensor));
                    Serial.print(gw.loadState(10*message.sensor));
                    // Send value to controler
                    Serial.println("Send value to controler");
                    gw.send(Status.setSensor(message.sensor).set(gw.loadState(10*message.sensor)),false);
                else
                    analogWrite(message.sensor, 255 * gw.loadState(message.sensor) / 100);
                    Serial.print(gw.loadState(message.sensor));
                    gw.send(Status.setSensor(message.sensor).set(gw.loadState(message.sensor)),false);
                // Stop the show if it's running
                if (isShow==1){ rgbShowStop(message.sensor); }
        // if recieve switch Off command
        else if (lightState==0)
          // Write output to 0 (Off)
                analogWrite(message.sensor, 0);
                // Save old value to eeprom if it'was not zero
                if ( gw.loadState(message.sensor) != 0 )
                    gw.saveState(10*message.sensor, constrain((int8_t)gw.loadState(message.sensor), 0, 100));
                // Save new value to eeprom
                gw.saveState(message.sensor, 0);
          Serial.print(": ");
          Serial.println("Off");
                Serial.print("Store old value: ");
      else if (message.type == V_DIMMER)
          uint8_t incomingDimmerStatus = message.getByte();
          // limits range of sensor values to between 0 and 100
          incomingDimmerStatus = constrain((int8_t)incomingDimmerStatus, 0, 100);
          // Change Dimmer level
          analogWrite(message.sensor, 255 * incomingDimmerStatus / 100);
          //Save value to eeprom
          gw.saveState(message.sensor, incomingDimmerStatus);
          Serial.print(": ");
          Serial.print(incomingDimmerStatus);
    void rgbShow()
      time = millis();
      redval = 128+250*cos(2*PI/300000*time);
      greenval = 128+250*cos(2*PI/300000*time-222);
      blueval = 128+250*cos(2*PI/300000*time-111);
      // limits range of sensor values to between 0 and 255
      redval = constrain(redval, 0, 255);
      greenval = constrain(greenval, 0, 255);
      blueval = constrain(blueval, 0, 255);
    void rgbShowOn()
      // define show On
      isShow=1;
      // Save state
      gw.saveState(0, 1);
      Serial.println("Show must go on");
    void rgbShowOff()
      // define show Off
      isShow=0;
      // Save state
      gw.saveState(0, 0);
      // Save RGB value to eeprom
      gw.saveState(RED_PIN, 100 * redval / 255);
      gw.saveState(GREEN_PIN, 100 * greenval / 255);
      gw.saveState(BLUE_PIN, 100 * blueval / 255);
      Serial.println("Stop the show");
      // Send actual RGB value and state to controler and request ack back (true/false)
      gw.send( rgbShowState.set(0), false);
    void rgbShowStop(int sensor)
       // define show Off
       isShow=0;
       // Save state
       gw.saveState(0, 0);
       if (sensor != RED_PIN)
        if (sensor != GREEN_PIN)
        if (sensor != BLUE_PIN)
     void motion()
      boolean tripped = digitalRead(Motion_PIN) == HIGH;
      Serial.println(tripped);
      gw.send(MotionStatus.set(tripped?"1":"0"));  // Send tripped value to gw
      gw.sleep(INTERRUPT,CHANGE, SLEEP_TIME);
    Any Ideas of where I'm going wrong?
    • DwaltD
      DwaltD
      Dwalt
      wrote on last edited by Dwalt
      @DrJeff
      What does Vera show when you include this sensor? I am on mobile so it is hard to look through your code but it doesn't appear that you present the motion sensor as a separate child id. As it is presented last under mymessage, it may be overriding the light messages.
        Did you have some other sensor with the same id on the vera side (which you deleted)?
        Once in a while I've seen that Vera just hides deleted devices until rebooted.
