  2. Feature Requests
  3. Req BASE_RADIO_ID
Req BASE_RADIO_ID
4 Posts 2 Posters 2.2k Views 1 Watching
  • Ivan ZI
    Ivan ZI
    Ivan Z
    RF24 can listen some Pipe
    Сan make 2 pipe. 1 - public, 2 - self
    When gateway in inclusive mode listen PUBLIC pipe. Node req ID. GateWay send ID and SELF pipe. Node save and listen SELF PIPE. Other communication work in SLEF pipe
    Pipe ID request form software (not in gateway)
    This algorithm has the following advantages
    1. No need to flash ready device. Purchased from third parties
    2. The work of many networks in one place
    3. Easy change of the network
    4. Ready sensor from third parties does not require reprogramming by your network
    There is an idea to promote this product to study in schools. To do this, you need to have multiple networks in the same classroom
      wrote on last edited by hek
      Yes, NRF24l01 can listen to 2 pipes, but only the last byte seems to be significant.
      Example:
      If you first listen to 0xA8A8E1FC00LL on pipe 2
      and the 0xB8A8E1FC01LL on pipe 3
      The radio will only listen to 0xB8A8E1FC00LL and 0xB8A8E1FC01LL
      So the first 9 bytes (B8A8E1FC0) of the pipe address must be the same... It cannot handle multiple of those...
      This limits us to address range of 255 valid simultaneous "pipe addresses".
      In the mysensors NRF-driver we use 255 as a broadcast address (that all nodes listen to).
      • Ivan ZI
        Ivan ZI
        Ivan Z
        253 nets - enough
        • Ivan ZI
          Ivan ZI
          Ivan Z
          Inclusive mode need only when configured network. It lasts one minute. No nide listen self pipe.
          After end inclusive mode, gateway listen self pipe
          his makes it possible to have a whole range of addresses
