  3. Problem with UV sensor
5 Posts 4 Posters 2.3k Views 2 Watching
    A Former User
    wrote on last edited by [[global:former-user]]
    After some research i've found out that my UVM-30A is outputting 0-1V (as stated in the datasheet). The analog input on my nano pro however, expect 0-5V to calculate the 0-1170 analog value that is used for the UV calculation in the sketch (see: http://www.mysensors.org/build/uv)
    Right now i'm multiplying the input times 5 to correct the issue. But I was wondering whether it is the sketch or my nano pro who is wrong here..
    • skywatchS
      skywatchS
      skywatch
      I was scratching my head over this problem last year, but found a solution that works for me.....Try this.....
      sensorVal = analogRead(sensorPin); //The pin the UV sensor is connected to
      sensorVal = constrain(sensorVal, 0, 1180);
      sensorValue = map (sensorVal, 0, 246, 0, 1180); //sensorValue is the number you
      //are looking for
      Then I did a look up for the UV index as follows......
      if (sensValue >= 0 && sensValue <= 226)
      uvVal = 0;
      else if (sensValue >= 227 && sensValue <= 317)
      uvVal = 1;
      else if (sensValue >= 318 && sensValue <= 407)
      uvVal = 2;
      else if (sensValue >= 408 && sensValue <= 502)
      uvVal = 3;
      else if (sensValue >= 503 && sensValue <= 605)
      uvVal = 4;
      else if (sensValue >= 606 && sensValue <= 695)
      uvVal = 5;
      else if (sensValue >= 696 && sensValue <= 794)
      uvVal = 6;
      else if (sensValue >= 795 && sensValue <= 880)
      uvVal = 7;
      else if (sensorValue >= 881 && sensorValue <= 975)
      uvVal = 8;
      else if (sensValue >= 976 && sensValue <= 1078)
      uvVal = 9;
      else if (sensValue >=1079 && sensValue <=1169)
      uvVal = 10;
      else if (sensValue >= 1170)
      uvVal = 11;
      And now I get the values I expect!
      Look at the map function on the arduino page to see how it works!
      Skywatch
      • BulldogLowellB
        BulldogLowellB
        BulldogLowell
        uvVal = 0;
        uvVal = 1;
        uvVal = 2;
        uvVal = 3;
        uvVal = 4;
        uvVal = 5;
        uvVal = 6;
        uvVal = 7;
        uvVal = 8;
        uvVal = 9;
        uvVal = 10;
        uvVal = 11;
        trivial, but this can be simplified like this:
        if (sensValue <= 226)
        uvVal = 0;
        else if (sensValue <= 317)
        uvVal = 1;
        else if (sensValue <= 407)
        uvVal = 2;
        else if (sensValue <= 502)
        uvVal = 3;
        else if (sensValue <= 605)
        uvVal = 4;
        else if (sensValue <= 695)
        uvVal = 5;
        else if (sensValue <= 794)
        uvVal = 6;
        else if (sensValue <= 880)
        uvVal = 7;
        else if (sensorValue <= 975)
        uvVal = 8;
        else if (sensValue <= 1078)
        uvVal = 9;
        else if (sensValue <=1169)
        uvVal = 10;
        else
        uvVal = 11;
          Or even simpler... ;)
          int levels[11] = {226, 317, 407, ....};
          int uVal = 0;
          for (;uVal<=11;uVal++) {
             if (uVal==11 || sensValue <= levels[uVal])
                break;
          (untested)
          • skywatchS
            skywatchS
            skywatch
            @Bulldog....
            Yeah I know! - it was 19 months ago I did that and I was trying out new ideas. This was obviously the last one as it is the last version (currently) ;)
            @Hek
            som är för smart för mig ;)
