  3. Over the air (OTA) bootloading update tutorial?
97 Posts 19 Posters 72.8k Views 22 Watching
  • Suresh MaliS
    Suresh MaliS
    Suresh Mali
    Can I use i2c EEPROM for OTA bootloading with DualOptiboot or it has to be Serial SPI. I was not able to find any documentation on it. I brought a breakout board and it seems to be i2c, and i2c chips are easily available where I live.
    http://www.aliexpress.com/item-img/AT24C256-Serial-EEPROM-I2C-Interface-EEPROM-Data-Storage-Module-PIC-NEW/32471353868.html?spm=2114.10010108.100005.10.sd3Dld
    Suresh MaliS 1 Reply Last reply
    • Suresh MaliS Suresh Mali
      Suresh MaliS
      Suresh MaliS
      Suresh Mali
      Request, if some one help me with this question. Thanks
      • scalzS
        scalzS
        Dualoptiboot use spi protocol for eeprom. So you can't. you would have to rewrite the code to use i2c protocol.
        I don't know if there are cheap spi alternative and I have not looked at ali, I buy mine at mouser.
        • scalzS scalz
          Suresh MaliS
          Suresh MaliS
          Suresh Mali
          @scalz Thanks buddy :thumbsup: . Probably I would have to keep hunting for SPI EEPROMs iguess.:sweat:
          ahmedadelhosniA 1 Reply Last reply
            ahmedadelhosniA
            ahmedadelhosniA
            ahmedadelhosni
            @Suresh-Mali I have the same problem. Only I2C IC is available in my country :(
            Looks like we have to hack the code. I will inform you when I reach this phase in my project.
            scalzS Suresh MaliS 3 Replies Last reply
            • ahmedadelhosniA ahmedadelhosni
              scalzS
              scalzS
              wrote on last edited by scalz
              #86
              @ahmedadelhosni, @Suresh-Mali : I don't know if you have a soldering iron ?? But you could use this ref : w25x40clsnig . This is the one used on moteino from lowpowerlab (they created Dualoptiboot).
              You can find this flash ic on aliexpress. It is cheap but ic only, no eval board..
              Then you can use this :
              https://www.openhardware.io/view/18/OTA-and-Authentication-Evaluation-Board
              I hope it helps. I have not tried these aliexpress flash but it should work. I hope ;) I will order some to see too.
              Few months ago, I made this french tut about OTA and dualoptiboot for jeedom users. I never had time to translate it. I will see when I will be able, but in case it can help, with some google translate, there are some pics too so maybe...
              https://www.jeedom.com/forum/viewtopic.php?f=35&t=9539
                Suresh MaliS
                Suresh MaliS
                Suresh Mali
                @ahmedadelhosni Great, do let us know once you have something.
                  Suresh MaliS
                  Suresh MaliS
                  Suresh Mali
                  @ahmedadelhosni Hey, I found this article. Seems like the guy has used i2c for remote flash. I was not able to extactly understand whats going on, maybe you can help.
                  http://www.rotwang.co.uk/projects/bootloader.html
                  • scalzS
                    scalzS
                    nice catch ;) yes it should work with some tests and code changes in mysensors lib to write into the i2c flash instead of spi flash...
                    • scalzS scalz
                      Suresh MaliS
                      Suresh MaliS
                      Suresh Mali
                      @scalz , Thanks:smiley:
                      I am not a Device Programmer, I am counting on some one to hack and make it possible. Hope somebody puts in efforts that will help everybody like me.
                      • scalzS
                        scalzS
                        @Suresh-Mali : yep, I understand :confused: unfortunately, I have no time, even if it is maybe not the biggest thing, tests take time..there are so much things I would like to do! Do you have a soldering iron??? What I have showed to you in previous post don't need big soldering skills...
                        • scalzS scalz
                          Suresh MaliS
                          Suresh MaliS
                          Suresh Mali
                          @scalz Oh yes, soldering is not an issue. I have rework station and I am proficient with soldering Through Hole and SMD components.
                          Its about getting the EEPROMs.
                          Buying from Ali would be my last resort. I am hunting for this chip in other parts of India. I should have an answer by day end, If I dont get them then I'll order from Ali. Waiting is the worst part of ordering from Ali. I had Order ATSHA204 on 12th Dec and still waiting.:disappointed:
                          • Suresh MaliS
                            Suresh MaliS
                            Suresh Mali
                            wrote on last edited by Suresh Mali
                            #93
                            Hey Guys, I managed to find a EEPROM chip from Bangalore, India. Its 25LC512, priced at Rs.65(~$1). I hope it works. I should get it next 2days. It has the same footprint as one used in SenseBenderMicro. Will try once I have them and update.
                            • ahmedadelhosniA
                              ahmedadelhosniA
                              ahmedadelhosni
                              nice catch for the I2C bootloader.
                              Keep us updated please of your progress. I can't actually start this phase now as I am working on other things at the moment.
                              Good luck.
                              • Suresh MaliS
                                Suresh MaliS
                                Suresh Mali
                                #95
                                This post is deleted!
                                  [[topic:post-is-deleted]]
                                  @Suresh-Mali please do not post the same question in more than one thread. Answer is available in http://forum.mysensors.org/topic/3060/home-made-ota-and-authentication-breakout-board/2
                                  • G
                                    G
                                    gepd
                                    There is several alternatives in aliexpress to the memory @Anticimex posted above, SPI interface, same pin distribution, only change the memory capacity and voltage input. (and good prices)
