  3. Repeater questions
Repeater questions
5 Posts 4 Posters 2.9k Views 3 Watching
  • E
    E
    ericvdb
    Can I send a heartbeat from the repeater node like this,
    unsigned long lastHeartbeat = 0;
    #define HEARTBEAT_INTERVAL 3600000
    if (millis() - lastHeartbeat > HEARTBEAT_INTERVAL) {
      ... PING ....
      lastHeartbeat = millis();
    and will the status leds work on a repeater node?
    I thought I ask first before spending time making the modifications.
    Greetz
      Code looks fine... And yes you can enable status lead in MyConfig.h before compiling the repeater (1.5).
      • Tore André RosanderT
        Tore André Rosander
        How should i include the heartbeat function in this sketch? (or any other)
         * Version 1.0 - Created by vil1driver
         * RGB led strip controled with three dimmers + one On/Off for run/stop rgb color cycle :p
        #define SN   "RGB Led strip 3D"
        #define SV   "v1"
        // Arduino pin attached to MOSFET Gate pin
        #define RED_PIN 3
        #define GREEN_PIN 5
        #define BLUE_PIN 6
        // Define message name and type to send sensor info
        MyMessage RedStatus(RED_PIN, V_DIMMER);
        MyMessage GreenStatus(GREEN_PIN, V_DIMMER);
        MyMessage BlueStatus(BLUE_PIN, V_DIMMER);
        MyMessage Status(1, V_DIMMER);
        MyMessage rgbShowState(0, V_LIGHT);
        // Serial.print translate sensor id to sensor name
        char color[][6] = {"","","","RED","","GREEN","BLUE"};
        // Vars for rgbShow function
        int redval = 0;
        int greenval = 0;
        int blueval = 0;
        long time=0;
        int isShow;
          // Define pin mode (pin number, type)
          pinMode(RED_PIN, OUTPUT);
          pinMode(GREEN_PIN, OUTPUT);
          pinMode(BLUE_PIN, OUTPUT);
          // Correct saved RGB value for first start
          saveState(RED_PIN, constrain((int8_t)loadState(RED_PIN), 0, 100));
          saveState(GREEN_PIN, constrain((int8_t)loadState(GREEN_PIN), 0, 100));
          saveState(BLUE_PIN, constrain((int8_t)loadState(BLUE_PIN), 0, 100));
          // Get value from eeprom and write to output
          analogWrite(RED_PIN, 255 * loadState(RED_PIN) / 100);
          analogWrite(GREEN_PIN, 255 * loadState(GREEN_PIN) / 100);
          analogWrite(BLUE_PIN, 255 * loadState(BLUE_PIN) / 100);
          // Write some debug info
          Serial.print("Load from eeprom RED: ");
          Serial.print(loadState(RED_PIN));
          Serial.println("%");
          Serial.print("Load from eeprom GREEN: ");
          Serial.print(loadState(GREEN_PIN));
          Serial.print("Load from eeprom BLUE: ");
          Serial.print(loadState(BLUE_PIN));
          // Send RGB value to controler (request ack back: true/false)
          Serial.println("Send eeprom value to controler");
          send( RedStatus.set(loadState(RED_PIN)), false );
          send( GreenStatus.set(loadState(GREEN_PIN)), false );
          send( BlueStatus.set(loadState(BLUE_PIN)), false );
          // Correct RGB show state for first start and load it (set to 'On' at first start)
          saveState(0, constrain((int8_t)loadState(0), 0, 1));
          isShow=loadState(0);
          // Send RGB show state to controler (request ack back: true/false)
          send( rgbShowState.set(isShow), false);
          if (isShow==1){Serial.println("RGB show running..."); }
          Serial.println("Ready to receive messages...");
        void presentation()  {
          // Present sketch (name, version)
          sendSketchInfo(SN, SV);
          // Register sensors (id, type, description, ack back)
          present(RED_PIN, S_DIMMER, "present RED light", false);
          present(GREEN_PIN, S_DIMMER, "present GREEN light", false);
          present(BLUE_PIN, S_DIMMER, "present BLUE light", false);
          present(0, S_LIGHT, "present Show button", false);
          // Run RGB show if is set
          if (isShow==1)
            	rgbShow();
          	analogWrite(RED_PIN, redval);
          	analogWrite(GREEN_PIN, greenval);
          	analogWrite(BLUE_PIN, blueval);
          if (message.isAck())
           	Serial.println("Got ack from gateway");
          if (message.type == V_LIGHT)
          	// Incoming on/off command sent from controller ("1" or "0")
          	int lightState = message.getString()[0] == '1';
          	// if receive RGB Show On commands, start the show
          	if (message.sensor==0 && lightState==1){ rgbShowOn();	}
                // if receive RGB Show Off commands, stop the show
          	else if (message.sensor==0 && lightState==0){	rgbShowOff();	}
          	// if receive RGB switch On command
          	else if (lightState==1)
                  	Serial.print("Incoming change for ");
                  	Serial.print(color[message.sensor]);
                  	Serial.println(": On");
                  	Serial.print("Load from eeprom: ");
          		if ( loadState(message.sensor) == 0)
          			// Pick up last saved dimmer level from the eeprom
                    		analogWrite(message.sensor, 255 * loadState(10*message.sensor) / 100);
                    		// Save loaded value to current
                    		saveState(message.sensor, loadState(10*message.sensor));
                    		Serial.print(loadState(10*message.sensor));
                    		// Send value to controler
                    		Serial.println("Send value to controler");
                    		send(Status.setSensor(message.sensor).set(loadState(10*message.sensor)),false);
                  	else
                    		analogWrite(message.sensor, 255 * loadState(message.sensor) / 100);
                    		Serial.print(loadState(message.sensor));
                    		send(Status.setSensor(message.sensor).set(loadState(message.sensor)),false);
                  	// Stop the show if it's running
                  	if (isShow==1){ rgbShowStop(message.sensor); }
          	// if recieve switch Off command
          	else if (lightState==0)
          		// Write output to 0 (Off)
                  	analogWrite(message.sensor, 0);
                  	// Save old value to eeprom if it'was not zero
                  	if ( loadState(message.sensor) != 0 )
                    		saveState(10*message.sensor, constrain((int8_t)loadState(message.sensor), 0, 100));
                  	// Save new value to eeprom
                  	saveState(message.sensor, 0);
          		Serial.print(": ");
          		Serial.println("Off");
                  	Serial.print("Store old value: ");
          else if (message.type == V_DIMMER)
            	uint8_t incomingDimmerStatus = message.getByte();
            	// limits range of sensor values to between 0 and 100
            	incomingDimmerStatus = constrain((int8_t)incomingDimmerStatus, 0, 100);
            	// Change Dimmer level
            	analogWrite(message.sensor, 255 * incomingDimmerStatus / 100);
            	//Save value to eeprom
            	saveState(message.sensor, incomingDimmerStatus);
            	Serial.print(": ");
            	Serial.print(incomingDimmerStatus);
        void rgbShow()
          time = millis();
          redval = 128+250*cos(2*PI/300000*time);
          greenval = 128+250*cos(2*PI/300000*time-222);
          blueval = 128+250*cos(2*PI/300000*time-111);
          // limits range of sensor values to between 0 and 255
          redval = constrain(redval, 0, 255);
          greenval = constrain(greenval, 0, 255);
          blueval = constrain(blueval, 0, 255);
        void rgbShowOn()
          // define show On
          isShow=1;
          // Save state
          saveState(0, 1);
          Serial.println("Show must go on");
        void rgbShowOff()
          // define show Off
          isShow=0;
          // Save state
          saveState(0, 0);
          // Save RGB value to eeprom
          saveState(RED_PIN, 100 * redval / 255);
          saveState(GREEN_PIN, 100 * greenval / 255);
          saveState(BLUE_PIN, 100 * blueval / 255);
          Serial.println("Stop the show");
          // Send actual RGB value and state to controler and request ack back (true/false)
          send( rgbShowState.set(0), false);
        void rgbShowStop(int sensor)
           // define show Off
           isShow=0;
           // Save state
           saveState(0, 0);
           if (sensor != RED_PIN)
            if (sensor != GREEN_PIN)
            if (sensor != BLUE_PIN)
        AWIA 1 Reply Last reply
        • Tore André RosanderT Tore André Rosander
          #define SV   "v1"
          #define RED_PIN 3
          #define GREEN_PIN 5
          #define BLUE_PIN 6
          int redval = 0;
          int greenval = 0;
          int blueval = 0;
          long time=0;
          int isShow;
            if (isShow==1)
              	rgbShow();
                    	else
            		Serial.print(": ");
              	Serial.print(": ");
          void rgbShow()
            time = millis();
          void rgbShowOn()
            // define show On
            isShow=1;
            // Save state
            saveState(0, 1);
          void rgbShowOff()
            // define show Off
            isShow=0;
            // Save state
            saveState(0, 0);
             // define show Off
             isShow=0;
             // Save state
             saveState(0, 0);
          AWIA
          AWIA
          AWI
          @Tore-André-Rosander You can just include it in the loop. What is the purpose of the -"heartbeat " you are using? In the development branch there is also a special implementation of a heartbeat service.
          One other observation in your code: you are constraining and converting a lot between percentages an byte values. Converting only where needed (when communicating with the controller) and using the "map" function makes the code more straightforward.
          Nice reading and examples for color manipulation can be found with the Fastled library also.
          Tore André RosanderT 1 Reply Last reply
          • AWIA AWI
            Tore André Rosander
            @AWI The code is from the MySensors examples and i use it to control 3 mosfets that controls a ledstrip.
            I need the heartbeat because i use the RPi gateway with the NRF24 chip directly connected to the RPi, and the gateway software for the raspberry dont store the network map so if i reboot the RPi the nodes loose connection to the gateway.
