  3. RS485/RS232/Serial transport class for mysensors.org
rs485 serialrs485
143 Posts 27 Posters 138.9k Views 27 Watching
  • lanL
    lanL
    lan
    I understand that the RS485 is a separate gateway to communicate. Is it also possible to have the wireless gateway and RS485 gateway combined?
      Currently, no..
      lanL 1 Reply Last reply
        Currently, no..
        lanL
        lanL
        lan
        @hek Thanks for the quick response. I'm looking for some direction (this might not be the right forum).
        I want to create a node to control my Itho Ecofan ventilation box. I now have a working program (thanks to the help of Rogier Reedijk The nodo now uses a CC1101 transceiver to control the box and thus uses the SPI bus. I'm looking for some direction to use this transmitter as part of my sensor network so I can control it from my Domoticz. Hope you can give me some directions how to proceed.
          Why do you need to hook it up to RS485 wired network? Can't you just forwards commands to the CC11001 from any radio node or the gateway?
          • lanL
            lanL
            lan
            Is it then possible to use the two radio's on one node and share the SPI bus?
              Yes, if the CC11001 behaves correctly.
              • lanL
                lanL
                lan
                Thanks, will try that
                • elektro12345E
                  elektro12345E
                  elektro12345
                  wrote on last edited by elektro12345
                  #108
                  I have a problem running gatewayserial to rs-485 and the node with the usual lightsensor.
                  NODE # 1 as a gateway and tried to upload a sketch of the library 2.0 and 1.5.4, and the monitor serial I can not see any data, I use to check on the serial PuTTy com6 because the converter rs-485 to USB is connected to the PC.
                  NODE # 2 as a light sensor, during the upload Sketch by arduino programmer for serial monitor can see the data being sent but after plugging arduino to rs-485 as below no longer visible.
                  My question is whether I have something wrong with the connection or sketch, can someone show an example of a complete sketch for the gateway, and a node?
                  Connection mine looks like this:
                  TX and RX Connect was to pins 0 and 1 in arduino or 8 and 9, DE is always PIN 2.
                  BartB 1 Reply Last reply
                    Looks like you got the pins to the Arduino wrong.
                    Pin 9 >>> DI
                    Pin 8 >>> RO
                    Pin 2 >>> DE and RE
                    elektro12345E 1 Reply Last reply
                      I need a nice picture done in fritzing (or similar) for an article on the main site on how to connect the RS485 module (atmega 328 enough I guess).
                      Anyone volunteering in making one?
                      • CrankyCoderC
                        CrankyCoderC
                        CrankyCoder
                        so this is a 1 to 1 setup right? There is nothing here for multiple serial nodes correct?
                        Home Automation Tinkerer
                        www.CrankyCoder.net
                        Gateway: MQTTClientGateway
                        MySensors: 2.3
                          Aren't they just daisy chained?
                            Pin 9 >>> DI
                            Pin 8 >>> RO
                            Pin 2 >>> DE and RE
                            elektro12345E
                            elektro12345E
                            elektro12345
                            #113
                            @hek
                            On the pictures is connect to TX and RX pins arduino but I tried to connect to pins 8,9,2 and result was the same :(
                            On thsi connections with pins 8,9,2 ofcourse and library mysensors 2.0 should works fine ?
                              Yes, people have reported the RS485 transport working above.
                              I just created this article with a summary of this thread
                              https://www.mysensors.org/build/rs485
                              • elektro12345E elektro12345
                                BartB
                                BartB
                                Bart
                                @elektro12345
                                So what's with the DE+RE pins on that USB-RS485 converter? Will it even work in this configuration? I do have such converter but so far I've used the arduino as a SerialGateway to connect to RPi.
                                • BartB
                                  BartB
                                  Bart
                                  wrote on last edited by Bart
                                  #116
                                  I am not sure if I am seeing a normal behavior. I don't know if it is expected that the sensor is taking such long time to become visible to the GW. I have recreated the examples from https://www.mysensors.org/build/rs485
                                  The only difference is that I've added SketchInfo for the GW and used Serial1 on MEGA board instead of AltSoftSerial.
                                  The debug on the motion sensor is as follows:
                                  MCO:BGN:INIT NODE,CP=RSNNA--,VER=2.0.1-beta
                                  TSM:INIT
                                  TSM:INIT:TSP OK
                                  TSF:ASID:OK,ID=1
                                  TSM:FPAR
                                  TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                                  !TSM:FPAR:NO REPLY
                                  TSM:FPAR
                                  !TSM:FPAR:NO REPLY
                                  TSM:FPAR
                                  !TSM:FPAR:NO REPLY
                                  TSM:FPAR
                                  !TSM:FPAR:FAIL
                                  TSM:FAILURE
                                  TSM:FAILURE:PDT
                                  TSM:FAILURE:RE-INIT
                                  TSM:INIT
                                  TSM:INIT:TSP OK
                                  TSF:ASID:OK,ID=1
                                  TSM:FPAR
                                  TSF:MSG:READ,0-0-1,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                  TSF:MSG:FPAR RES,ID=0,D=0
                                  TSF:MSG:FPAR OK,ID=0,D=1
                                  TSM:FPAR:OK
                                  TSM:ID
                                  TSM:ID:OK,ID=1
                                  TSM:UPL
                                  TSF:PING:SEND,TO=0
                                  TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                                  TSF:CHKUPL:FAIL
                                  !TSM:UPL:FAIL
                                  TSM:FPAR
                                  TSM:FPAR:OK
                                  TSM:ID
                                  TSM:ID:OK,ID=1
                                  TSM:UPL
                                  TSF:PING:SEND,TO=0
                                  TSF:CHKUPL:FAIL
                                  !TSM:UPL:FAIL
                                  TSM:FPAR
                                  TSM:FPAR:OK
                                  TSM:ID
                                  TSM:ID:OK,ID=1
                                  TSM:UPL
                                  TSF:PING:SEND,TO=0
                                  TSF:CHKUPL:FAIL
                                  !TSM:UPL:FAIL
                                  TSM:FPAR
                                  TSM:FPAR:OK
                                  TSM:ID
                                  TSM:ID:OK,ID=1
                                  TSM:UPL
                                  TSF:PING:SEND,TO=0
                                  TSF:CHKUPL:FAIL
                                  !TSM:UPL:FAIL
                                  TSM:FPAR
                                  TSM:FPAR:OK
                                  TSM:ID
                                  TSM:ID:OK,ID=1
                                  TSM:UPL
                                  TSF:PING:SEND,TO=0
                                  TSF:MSG:READ,0-0-1,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                                  TSF:MSG:PONG RECV,HP=1
                                  TSF:CHKUPL:OK
                                  TSM:UPL:OK
                                  TSM:READY
                                  TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                                  TSF:MSG:SEND,1-1-0-0,s=255,c=0,t=17,pt=0,l=10,sg=0,ft=0,st=OK:2.0.1-beta
                                  TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                                  TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=11,pt=0,l=13,sg=0,ft=0,st=OK:Motion Sensor
                                  TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
                                  TSF:MSG:SEND,1-1-0-0,s=1,c=0,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
                                  MCO:REG:REQ
                                  TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                                  TSF:MSG:READ,0-0-1,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                                  MCO:PIM:NODE REG=1
                                  MCO:BGN:STP
                                  MCO:BGN:INIT OK,ID=1,PAR=0,DIS=1,REG=1
                                  TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:0
                                  I don't know how to obtain debug from the Gateway Serial but as far as the GW messages on the console it looked as follows:
                                  0;255;0;0;18;2.0.1-beta
                                  0;255;3;0;11;SerialGateway
                                  0;255;3;0;12;0.1
                                  1;255;3;0;6;0
                                  1;255;3;0;11;Motion Sensor
                                  1;255;3;0;12;1.0
                                  1;1;0;0;1;
                                  1;1;1;0;16;0
                                  1;1;1;0;16;0
                                  1;1;1;0;16;0
                                  1;1;1;0;16;0
                                  1;1;1;0;16;0
                                  As you see it takes a fair amount of time (around 30-40 secs) to obtain the readings from the sensor. This happens each time I reset the sensor node but it works instantly if I reset the GW (i.e. the readings appear instantly after the reset). Is it expected behavior?
                                    30 seconds sound like a long time.. Not sure what could be wrong. I don't have any test setup here unfortunately.
                                    BartB 2 Replies Last reply
                                    • kduinoK
                                      kduinoK
                                      kduino
                                      I am wondering if I can just use the mySensors Lib to pass on the data via another connection. Currently I have a Loxone Controller which accepts UDP and TCP/IP connections (and others, but I chose these). As gateway I have an ArduinoMega and the network is running on RS485.
                                      So my understanding is that I can setup the network with the mySensors code and all the data is collected by the gateway which passes the data via UDP to the controller. V.v. the controller sends the data to the gateway which passes tha data on to the correspondent node.
                                      Is there any project similar to this?
                                      Thank you very much for your help!
                                      Best regards Kduino
                                      • BartB Bart
                                        @elektro12345
                                        elektro12345E
                                        elektro12345E
                                        elektro12345
                                        @Bart I do not know what You mean with DE+RE pins on the converter.
                                        On the converter You connect A and B calbe from bus.
                                        DE and RE pins fromMAX485 You connect with sealf and connect to pin in my case D2 on Arduino.
                                        • elektro12345E
                                          elektro12345E
                                          elektro12345
                                          I have a question, when I wont send do domoticz from Arduino presentation lightsensor I can send by serial something like this:
                                          1;2;0;0;16;V_LIGHT_LEVEL
                                          and domoticz will understend that is the lightsensor LUX ?
