  3. How to bootload OTA on arduino pro mini?
5 Posts 3 Posters 4.2k Views 4 Watching
  • G
    G
    Gefkuz
    I'm searching, since a couple hours, a simple method to bootload a pro mini 5v 16Mhz with an OTA bootloader.
    I found some part of information, but no simple things like "copy this file at this location and then click here".......
    There is a tutorial somewhere?
    • rvendrameR
      rvendrameR
      rvendrame
      Maybe this can help...
      http://starter-kit.nettigo.eu/2013/arduino-as-isp-or-how-to-burn-bootloader/
      ESP8266 GW + mySensors 2.3.2
      Alexa / Google Home
      • G
        G
        Gefkuz
        This is the part of information I have.
        The missing part is how can I add the new OTA bootloader on arduino ide!!!
        • E
          E
          ericvdb
          wrote on last edited by ericvdb
          In the file arduino-1.6.5-r2\hardware\arduino\avr\boards.txt add a new section with the correct settings
          ## Arduino Pro or Pro Mini (3V3 & 5V, 16 MHz) w/ ATmega328 MYSBootloader
          proMYSBL.menu.cpu.8MHzatmega328=ATmega328 16Mhz MYSBootloader
          proMYSBL.menu.cpu.8MHzatmega328.upload.tool=avrdude
          proMYSBL.menu.cpu.8MHzatmega328.upload.protocol=arduino
          proMYSBL.menu.cpu.8MHzatmega328.upload.maximum_size=30720
          proMYSBL.menu.cpu.8MHzatmega328.upload.maximum_data_size=2048
          proMYSBL.menu.cpu.8MHzatmega328.upload.speed=115200
          proMYSBL.menu.cpu.8MHzatmega328.bootloader.tool=avrdude
          proMYSBL.menu.cpu.8MHzatmega328.bootloader.low_fuses=0xF7
          proMYSBL.menu.cpu.8MHzatmega328.bootloader.high_fuses=0xDA
          proMYSBL.menu.cpu.8MHzatmega328.bootloader.extended_fuses=0x06
          proMYSBL.menu.cpu.8MHzatmega328.bootloader.unlock_bits=0x3F
          proMYSBL.menu.cpu.8MHzatmega328.bootloader.lock_bits=0x0F
          proMYSBL.menu.cpu.8MHzatmega328.bootloader.file=MySensors/MYSBootloader.hex
          proMYSBL.menu.cpu.8MHzatmega328.build.mcu=atmega328p
          proMYSBL.menu.cpu.8MHzatmega328.build.f_cpu=16000000L
          proMYSBL.menu.cpu.8MHzatmega328.build.board=AVR_UNO
          proMYSBL.menu.cpu.8MHzatmega328.build.core=arduino
          proMYSBL.menu.cpu.8MHzatmega328.build.variant=standard
          save the file and restart the arduino IDE
          • G
            G
            Gefkuz
            Hey, Bootloader in pro-mini.
            I have to flash with a new sketch, connect nrf and test OTA.
            Thank you
