  3. Multisensor node using Ceech board
64 Posts 8 Posters 39.6k Views 11 Watching
  • rollercontainerR
    rollercontainerR
    rollercontainer
    In the ebay auction I bought it your text says buck boost converter. On the chip there is a number gnq 666 601, but I cant find him. Board says: 77534K_Y471
    • C
      C
      ceech
      The first number from IC is the LTC4079. Board number means that you have one with a voltage regulator. You somehow ended with one. You can send it back and I'll send you replacement if you wish.
      • rollercontainerR
        rollercontainerR
        rollercontainer
        I am not amused...
        I will buy additonal batteries and a second solar cell.
        • C
          C
          ceech
          There are also the appropriate charging voltage and current settings to be made to accommodate for the NiCd batteries. Are you sure you don't want for me to do it for you?
          • rollercontainerR
            rollercontainerR
            rollercontainer
            I thought, sunset will be enough to terminate charging on NiCd?
            So its easier to take 3,2V LiFePo4, right? And because my board only regulates down, I have to take 2 in series to provide enough voltage to regulate, right?
            All these flat LiPo types provide ~3,7V. Is that enough to feed the regulator (+dropout)?
            • C
              C
              ceech
              wrote on last edited by ceech
              #46
              Proper voltage and current also take effect in charging NiCd batteries.
              And LiFePO4 would also require different charge voltage (3.6V).
              The best option is a single cell LiPo battery with a capacity between 1000mAh and 2500mAh.
              Charge voltage matches (4.2V) and the current as well. Voltage regulator on the board is extremely efficient with just 2uA of consumption and 180mV dropout voltage. At 3V with the battery you still get 2.82V for the microcontroller. That's plenty. And quiescent current is the same in dropout. You'll be well off.
              • rollercontainerR
                rollercontainerR
                rollercontainer
                like this one?
                http://www.ebay.de/itm/1x-Lipo-Akku-LxBxH-75-x-40-x-5-6-mm-3-7V-2000mAh-1S-JST-Stecker-554475-/371581598136
                • C
                  C
                  ceech
                  Like that one, yes. Or, if you do not mind doing some soldering yourself, you can choose one from this list:
                  http://www.ebay.com/sch/i.html?_from=R40&_sacat=0&_nkw=Li-ion+Replacement+Battery+For+Samsung&_sop=15
                  I do it like this:
                  • rollercontainerR
                    rollercontainerR
                    rollercontainer
                    I wanted to use it outside for collecting weather data. But the battery which the board is designed for isn't suitable for temperatures below 0°C.
                    Is that right so far?
                    Or did you successfully used Li-Ion outside below 0°C?
                    • C
                      C
                      ceech
                      The capacity of LiPo batteries start to decline below 0 degrees Celsius. But that is a fact in all kinds of batteries. You are not going to notice much change till below -20 degrees. I found this post which describes it perfectly ( scroll down a little ):
                      https://backpackinglight.com/forums/topic/84570/
                      • rollercontainerR
                        rollercontainerR
                        rollercontainer
                        Ok, now I've got a 12V 50mA solar cell and a 3,7V 2000mAh LiPo. Potentiometer is at 12 o'clock (flat segment at the single solder pad)
                        Can you please try to explain what exactly the potentiometer is adjusting?
                        Does the charger only charge if the cell voltage is below the adjusted voltage level?
                        Your example sketch is not showing any charging current:
                        Vcc = 3.32V
                        Charge current = 0.00mA
                        Solar cell voltage = 0.24V
                        Battery voltage = 3.79V
                        CHRG = 424
                        Vcc = 3.32V
                        Solar cell voltage = 7.44V
                        CHRG = 409
                        Vcc = 3.32V
                        Solar cell voltage = 11.72V
                        CHRG = 0
                        alexsh1A C 2 Replies Last reply
                        • rollercontainerR rollercontainer
                          Vcc = 3.32V
                          CHRG = 424
                          Vcc = 3.32V
                          CHRG = 409
                          Vcc = 3.32V
                          CHRG = 0
                          alexsh1A
                          alexsh1A
                          alexsh1
                          @rollercontainer I would suggest you scroll up and see a few posts above concerning your question. The setting for potentiometer- for you it should be around 6 o'clock (or 12 o'clock where the cut-off mark is).
                          Basically what it does is adjusting when your battery is being charged. For example, I have a 5V solar panel and I'd like the LiPO to start being charged at 4.75V therefore I put the potentiometer at the minimum (around 2pm or 8pm cut-off mark). This threshold (in my case 4.75V) can be adjusted by this potentiometer.
                            Vcc = 3.32V
                            CHRG = 424
                            Vcc = 3.32V
                            CHRG = 409
                            Vcc = 3.32V
                            CHRG = 0
                            C
                            C
                            ceech
                            @rollercontainer The potentiometer is adjusting the voltage at which the solar panel is operating at its maximum power. It is so called MPPT. Just set it to the solar panel's nominal voltage.
                            When the voltage on the solar panel is reduced (is in shade or we want to extract too much from it), the charger reduces the charging current in order to prevent the solar panel from collapsing entirely.
                            • rollercontainerR
                              rollercontainerR
                              rollercontainer
                              D'oh! I thought, the wiper of the trimmer is at the flat side, but its opposite to the flat, got it finally. Now pimatic is showing a current (0.74A).
                              • FraidF
                                FraidF
                                Fraid
                                Hi everyone, I'm new to arduino, and I bougth Ceech board.
                                Can someone please let me know how to upload sketch on this board? I read it's compatible with arduino but I can't find any wiring schema.
                                Also where is A7/CHRG ? Because my board go from analog A0 to A5.
                                And I bought the following one :
                                http://www.ebay.com/itm/331838940273?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
                                I just want a solar/battery powered sensor. And I have anduino nano.
                                Thank
                                alexsh1A 1 Reply Last reply
                                • FraidF Fraid
                                  Thank
                                  alexsh1A
                                  alexsh1A
                                  alexsh1
                                  @Fraid-DIRON welcome to the forum! This is beginners question and I would suggest you browse www.arduino.cc
                                  You will find tons of international on that web-site concerning programming Arduino in general. This is how I was learning it.
                                  Concerning Ceech's board, it is programmed the same way as any Arduino Pro or Arduino Pro Mini - with a help of FTDI USB to TTL converter (there are many on eBay) connected to the 6 angled pins on the board.
                                  This link is for Pro Mini, but Pro (Ceech's board) is programmed in exactly the same way:
                                  https://www.arduino.cc/en/Guide/ArduinoProMini
                                  • FraidF
                                    FraidF
                                    Fraid
                                    @alexsh1 said:
                                    FTDI
                                    Ohh thank you @alexsh1 , and my bad, you made me realize that Ceech's board as the ATMega. Now that make more sense the A7 is the analog pin 7 that is linked with the CHRG of LTC4067. Anyway Thanks :D !
                                    • FraidF Fraid
                                      @alexsh1 said:
                                      FTDI
                                      alexsh1A
                                      alexsh1A
                                      alexsh1
                                      @Fraid-DIRON No worries
                                      • rollercontainerR
                                        rollercontainerR
                                        rollercontainer
                                        Can someone explain, why the charger isnt charging all the time or at least earlier? BattVoltage is 3.96V on the right end. Is the cell considered full?
                                        C 1 Reply Last reply
                                          C
                                          C
                                          ceech
                                          #60
                                          @rollercontainer For some reason current started to drop. Once it reached C/10 (around 10mA), charger stopped charging. This is a programmed function.
                                          I can see two reasons why the current started to drop. Voltage readings might be off for one. Or the battery doesn't accept charge above 4V. Its internal resistance might risen.
                                          Late charge start might indicate wrong voltage readings. If we assume that in the morning the voltage is 4.2V, then at 11 o'clock the voltage dropped just enough for the charger to start charging (also a programmed feature).
