  3. Domoticz 4 x relay
Domoticz 4 x relay
6 Posts 3 Posters 5.2k Views 2 Watching
  • R Offline
    R Offline
    romeok01
    I wrote code to 4 relays:
    #include <MySigningNone.h>
    #include <MyTransportNRF24.h>
    #include <MyTransportRFM69.h>
    #include <MyHwATMega328.h>
    #define RELAY_1  3  // Pin D3
    #define RELAY_2  4  // Pin D4
    #define RELAY_3  5  // Pin D5
    #define RELAY_4  6  // Pin D6
    #define NUMBER_OF_RELAYS 4 // Liczba przekaznikow
    #define RELAY_ON 1  // Stan wysoki przekaznik wlaczony
    #define RELAY_OFF 0 // Stan niski przekaznik wylaczony
    //MyTransportRFM69 radio;
    //MySigningNone signer;
    MyHwATMega328 hw;
    MySensor gw(radio, hw);
      gw.sendSketchInfo("Relay", "1.0");
      // Fetch relay status
      for (int sensor=1, pin=RELAY_1; sensor<=NUMBER_OF_RELAYS;sensor++, pin++)
      for (int sensor=1, pin=RELAY_2; sensor<=NUMBER_OF_RELAYS;sensor++, pin++)
      for (int sensor=1, pin=RELAY_3; sensor<=NUMBER_OF_RELAYS;sensor++, pin++)
      for (int sensor=1, pin=RELAY_4; sensor<=NUMBER_OF_RELAYS;sensor++, pin++){
        gw.present(sensor, S_LIGHT);
        pinMode(pin, OUTPUT);
        digitalWrite(pin, gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
      gw.process();
      if (message.type==V_LIGHT) {
         // Change relay state
         // Store state in eeprom
         // Write some debug info
         Serial.print(message.sensor);
    Domoticz detected 4 switches
    I added 4 switches in Domoticz
    I connected the LED to pins 3,4,5,6 and when I turn on switch in Domoticz the LEDs do not want to turn on.
    What is poorly written code?
    hekH 1 Reply Last reply
    • R romeok01
      MyHwATMega328 hw;
        gw.process();
      hekH Offline
      hekH Offline
      Is this really correct?
      • T Offline
        T Offline
        TheoL
        Where do you power the LED's from? In other words how did you connect them to the relays?
        • R Offline
          R Offline
          romeok01
          wrote on last edited by romeok01
          I used leds to perform a functional test code.
          I connected LEDs to pins 3, 4, 5, 6 and GND.
          • T Offline
            T Offline
            TheoL
            What I allways do during development is to uncomment the line #define DEBUG in MySensor.h that way MySensors is writing Debug info to your serial Monitor. It's getting late where I live and I need to go to bed. So I don't have time to dig into it.
            But try this as your setup code
              for (int sensor=1, pin=RELAY_1; sensor<=NUMBER_OF_RELAYS;sensor++, pin++){
            Not sure if it helps but you can try it. I personally don't use gw.saveState a lot. The EPROM doesn't support unlimited write actions. So during development it's allways good to comment lines like that.
            R 1 Reply Last reply
            • T TheoL
              R Offline
              R Offline
              romeok01
              @TheoL Thank you very much, really helped me, now the program code work :smile:
