  3. [n00b]]Ethernet GW - without NF24
31 Posts 4 Posters 18.4k Views 3 Watching
  • B
    B
    brix7be
    The final goal for me is the build ethernet sensor(s) (2 or 3 one each arduino board) connected to domoticz by lan gw.
    • B
      B
      brix7be
      Is there anyone who have done a sketch to connect sensor directly on an ethernet gateway ?
      Iam searching a working exemple or a working draft to see the process to build my own code.
      Thank everyone for your advices.
      • B
        B
        brix7be
        wrote on last edited by brix7be
        #23
        Hi Hek, Everyone,
        I've clean the approximative sketch I've made before to simply try to see the value of a DS18b20 sensor trough a serial gw in domoticz.
        So i've placed the merged code below to have your advices.
        In domoticz's log i can see the declaration of the gw but neither the dallas sensor!?
        Does someone could check my sketch please?
        To be sure that the arduino see the dallas, i've tested a sketch wich send the value to the serial terminal (it works properly :-).
        Thank you in advance for your help.
        Have a nice sunday all. (clouday in belgium today ;-)).
        // Enable serial gateway
        #define MY_GATEWAY_SERIAL
        // Flash leds on rx/tx/err
        //#define MY_LEDS_BLINKING_FEATURE
        // Set blinking period
        //#define MY_DEFAULT_LED_BLINK_PERIOD 300
        // Enable inclusion mode
        //#define MY_DEFAULT_ERR_LED_PIN 7  // Error led pin
        //#define MY_DEFAULT_RX_LED_PIN  8  // Receive led pin
        //#define MY_DEFAULT_TX_LED_PIN  9  // the PCB, on board LED
        #include <OneWire.h>
        int numSensors=0;
        boolean metric = true;
        MyMessage msg(0,V_TEMP);
          sensors.begin();
        void presentation() {
          sendSketchInfo("Temperature Sensor", "1.1");
             present(i, S_TEMP);
          sleep(conversionTime);
            float temperature = static_cast<float>(static_cast<int>((getConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
            #if COMPARE_TEMP == 1
            #else
              send(msg.setSensor(i).set(temperature,1));
          sleep(SLEEP_TIME);
        To be complete, there is the domoticz log.
        2015-10-25 10:44:40.157 MySensors: Using serial port: COM3
        2015-10-25 10:44:41.892 MySensors: Gateway Ready...
        2015-10-25 10:44:41.892 MySensors: Node: 0, Sketch Name: Temperature Sensor
        2015-10-25 10:44:41.946 MySensors: Node: 0, Sketch Version: 1.1
        • B
          B
          brix7be
          No idea?
            Sensors attached to gateway (node id=0) is a new feature.
            Might be Domoticz filtering these type of messages perhaps?
            @GizMoCuz might know if this is the case.
            • A
              A
              afick
              I have created ethernet gateway :) with 2 sensors :) (DHT11, and door/windows sensor) all data are send to domoticz without problem.But when i adds "przekaznik" - one channel relay - i can't send/receive data about this relay. Can anyone check why ?
              sorry for mess in code
              #define MY_GATEWAY_W5100
              // radio on the same spi bus.
              #define MY_SOFTSPI
              #define MY_RF24_CE_PIN 5
              #define MY_RF24_CS_PIN 6
              // Enable to UDP
              //#define MY_USE_UDP
              #define MY_IP_ADDRESS 192,168,0,250   // If this is disabled, DHCP is used to retrieve address
              #define MY_PORT 5003
              //#define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 254
              //Przekaznik
              #define MY_REPEATER_FEATURE
              #define RELAY_1  22  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
              #if defined(MY_USE_UDP)
              #include <EthernetUdp.h>
              #include <Ethernet.h>
              #include <DHT.h>   //dodany czujnik
              //czujnik temp i wilgotnosci
              #define CHILD_ID_HUM 0
              #define CHILD_ID_TEMP 1
              #define DOOR_ID1 4
              #define DOOR_ID1_PIN A0
              unsigned long SLEEP_TIME = 300; // Sleep time between reads (in milliseconds)
              DHT dht;
              float lastTemp;
              float lastHum;
              MyMessage msgDOOR_ID1(DOOR_ID1, V_TRIPPED);
              int old_DOOR_ID1_STATE = -1;
                //temp + hum
                metric = getConfig().isMetric;
                //  kontaktron DOOR_ID1
                pinMode(DOOR_ID1_PIN, INPUT);
                //  //przekaznik
                //    // Then set relay pins in output mode
                    pinMode(pin, OUTPUT);
                //    // Set relay to last known state (using eeprom storage)
                //temp + hum
                sendSketchInfo("Humidity", "1.0");
                present(CHILD_ID_HUM, S_HUM);
                present(DOOR_ID1, S_DOOR);
                //przekaznik
                for (int sensor = 1, pin = RELAY_1; sensor <= NUMBER_OF_RELAYS; sensor++, pin++) {
                  present(sensor, S_LIGHT);
                  Serial.print("Petla presentation");
                //temp + hum
                if (isnan(temperature)) {
                  lastTemp = temperature;
                  if (!metric) {
                  Serial.print("T: ");
                  Serial.println(temperature);
                if (isnan(humidity)) {
                  lastHum = humidity;
                  Serial.print("H: ");
                  Serial.println(humidity);
                int DOOR_ID1_STATE = analogRead(DOOR_ID1_PIN);
                Serial.print("Analog= ");
                Serial.println(DOOR_ID1_STATE);
                Serial.println(old_DOOR_ID1_STATE);
                if (DOOR_ID1_STATE == 0) {
                  DOOR_ID1_STATE = 0;
                  send(msgDOOR_ID1.set(DOOR_ID1_STATE));
                  old_DOOR_ID1_STATE = DOOR_ID1_STATE;
                  Serial.print("drzwi_1=");
                } else {
                  DOOR_ID1_STATE = 1;
                  Serial.print("drzwi_2=");
                  // Change relay state
                  digitalWrite(message.sensor - 1 + RELAY_1, message.getBool() ? RELAY_ON : RELAY_OFF);
                  // Store state in eeprom
                  // Write some debug info
                  Serial.print(message.sensor);
                Just did some verification of message receiving in gateway on the ESP8266 sent from my shell (using netcat). Messages is showing up in receive() just fine here.
                Are you sending to node 0 from Domoticz? What does the log say in the gateway?
                • A
                  A
                  afick
                  wrote on last edited by afick
                  #28
                  Nothing special
                  0;0;3;0;9;Starting...
                  IP: 192.168.0.250
                  Domoticz log
                   2015-11-09 23:09:50.588 (GW) Temp + Humidity (TempHum)
                  2015-11-09 23:09:53.599 (GW) Temp + Humidity (TempHum)
                  2015-11-09 23:09:56.614 (GW) Temp + Humidity (TempHum)
                  2015-11-09 23:09:56.620 (GW) Temp + Humidity (TempHum)
                  2015-11-09 23:10:00.632 (GW) Temp + Humidity (TempHum)
                  2015-11-09 23:10:00.680 (GW) Lighting 2 (Security Sensor)
                  2015-11-09 23:10:03.706 (GW) Temp + Humidity (TempHum)
                  2015-11-09 23:10:07.718 (GW) Temp + Humidity (TempHum)
                  2015-11-09 23:10:12.730 (GW) Temp + Humidity (TempHum)
                  2015-11-09 23:10:17.745 (GW) Temp + Humidity (TempHum)
                  2015-11-09 23:10:21.762 (GW) Temp + Humidity (TempHum)
                  2015-11-09 23:10:22.770 (GW) Lighting 2 (Security Sensor)
                  2015-11-09 23:10:27.791 (GW) Temp + Humidity (TempHum)
                  2015-11-09 23:10:31.805 (GW) Temp + Humidity (TempHum)
                  2015-11-09 23:10:32.812 (GW) Temp + Humidity (TempHum)
                  I'm receiving only this kind of information.
                  How can i send "0" from domoticz to GW ?
                    Your have messed up the presentation of your S_LIGHT devices in the loop. They start with id 1 in the loop. But that id has already been used by CHILD_ID_TEMP.
                    • A
                      A
                      afick
                      Even if i change CHILD_ID_RELAY (to 5 or 6 ) sill the same.
                      • zaphodusZ
                        zaphodusZ
                        zaphodus
                        I had the same problem as you and I have found a possible solution. The arduino has default auto reset on serial connection. So when you connect gateway to controller trough USB, the gateway is rebooting immediately and processing presentation(). In case of wireless gateway (esp8266) this does not happen. The presentation() runs only on startup of the gateway. I made little change in MyGatewayTransportEthernet.cpp and now the gateway processes presentation() when the controller is connecting to it.
                        You can find here my solution:
                        https://github.com/zaphodus/Arduino/commit/ce93db73513f1da45637b186787c9b2501e5d882
