  3. AC diming
AC diming
16 Posts 6 Posters 9.0k Views 4 Watching
  • C Offline
    C Offline
    csa02221862
    Any thoughts on this board? Looks interesting particularly the control of a large motor. It might make a good lamp or ceiling fan controller.
    Richard
    http://researchdesignlab.com/serial-3-channel-ac-230v-ssr-and-dimmer.html
    J 1 Reply Last reply
    • C csa02221862
      Richard
      J Offline
      J Offline
      jemish
      wrote on last edited by jemish
      @csa02221862 It can work with arduino mysensore?????
      • C Offline
        C Offline
        csa02221862
        Yes, they show the diagram for the Arduino and the script on the site.
        • T Offline
          T Offline
          thomasdc
          https://www.domoticz.com/forum/viewtopic.php?f=38&t=8033
          • T Offline
            T Offline
            thomasdc
            wrote on last edited by thomasdc
            hi!
            after long searching and trying i managed to Build an 'MySensors' AC dimming node.
            I bought this:
            http://www.ebay.com/itm/4CH-AC-Dimmer-Module-Controller-Board-ARDUINO-RASPBERRY-Compatible-50-60Hz-/121752461158?ssPageName=ADME:X:RTQ:US:1123
            and i use it to control my lightning.
            regards, Thomas
            It was working for 1 dimmer but now im am updating the code for '4' dimmers but i am having trouble with understanding...
            this is the code so far:
            this is based on the sketch from Quocanhcgd
            link: http://forum.mysensors.org/topic/1316/ac-dimmer-with-openhab
            Tested With Domoticz, working fine 220V 50Hz
            AC Light Control
            Uses up and down buttons to set levels
            makes use of a timer interrupt to set the level of dimming
            #include <TimerOne.h>
            #define SN "AC Dimmer control"
            #define SV "1.0"
            #define NODE_ID 30  //change to a number to assign a specific ID
            #define FADE_DELAY 18  // Delay in ms for each percentage fade up/down (10ms = 1s full-range dim)
            #define FADE_PERCENTAGE 5 //The percentage the fade level will be changed when a button is pressed
            volatile int i=0;               // Variable to use as a counter of dimming steps. It is volatile since it is passed between interrupts
            volatile int j=0;
            volatile int k=0;
            volatile int l=0;
            volatile boolean zero_cross=0;  // Flag to indicate we have crossed zero
            int AC_pin1 = 4;                 // Output to Opto Triac
            int AC_pin2 = 5;
            int AC_pin3 = 6;
            int AC_pin4 = 7;
            int freqStep = 75;              // This is the delay-per-brightness step in microseconds. It allows for 128 steps
                                            // If using 60 Hz grid frequency set this to 65
            //Tuy chinh lai
            static int currentLevel1 = 128;  // Current dim level...
            static int currentLevel2 = 128;  // Current dim level...
            static int currentLevel3 = 128;  // Current dim level...
            static int currentLevel4 = 128;  // Current dim level...
            uint8_t fadeLevel1 = 128; //used to store the fade level when using the buttons
            uint8_t fadeLevel2 = 128:
            uint8_t fadeLevel3 = 128;
            uint8_t fadeLevel4 = 128:
            MyMessage dimmer1Msg(AC_pin1, V_DIMMER);
            MyMessage light1Msg(AC_pin1, V_LIGHT);
            MyMessage dimmer2Msg(AC_pin2, V_DIMMER);
            MyMessage light2Msg(AC_pin2, V_LIGHT);
            MyMessage dimmer3Msg(AC_pin2, V_DIMMER);
            MyMessage light3Msg(AC_pin3, V_LIGHT);
            MyMessage dimmer4Msg(AC_pin4, V_DIMMER);
            MyMessage light4Msg(AC_pin4, V_LIGHT);
            void setup() {  // Begin setup
              Serial.begin(115200);
              /// - Setup Mysensors
              Serial.println( SN );
              gw.begin( incomingMessage,  NODE_ID, true);
                gw.present( AC_pin1, S_DIMMER );
                gw.present( AC_pin2, S_DIMMER );
                gw.present( AC_pin3, S_DIMMER );
                gw.present( AC_pin4, S_DIMMER );
              gw.sendSketchInfo(SN, SV);
              // Pull the gateway's current dim level - restore light level upon sendor node power-up
              gw.request( AC_pin1, V_DIMMER );
              gw.request( AC_pin2, V_DIMMER );
              gw.request( AC_pin3, V_DIMMER );
              gw.request( AC_pin4, V_DIMMER );
              //Setup AC PIN  // Set the Triac pin as output
               pinMode(AC_pin1, OUTPUT);
               pinMode(AC_pin2, OUTPUT);
               pinMode(AC_pin3, OUTPUT);
               pinMode(AC_pin4, OUTPUT);
              attachInterrupt(1, zero_cross_detect, RISING);    // Attach an Interupt to Pin 2 (interupt 0) for Zero Cross Detection
              Timer1.initialize(freqStep);                      // Initialize TimerOne library for the freq we need
              Timer1.attachInterrupt(dim_check, freqStep);      // Go to dim_check procedure every 75 uS (50Hz)  or 65 uS (60Hz)
              // Use the TimerOne Library to attach an interrupt
            void zero_cross_detect() {
              zero_cross = true;               // set flag for dim_check function that a zero cross has occured
              i=0;                             // stepcounter to 0.... as we start a new cycle
              digitalWrite(AC_pin1, LOW);
              digitalWrite(AC_pin2, LOW);
              digitalWrite(AC_pin3, LOW);
              digitalWrite(AC_pin4, LOW);
            // Turn on the TRIAC at the appropriate time
            // We arrive here every 75 (65) uS
            // First check if a flag has been set
            // Then check if the counter 'i' has reached the dimming level
            // if so.... switch on the TRIAC and reset the counter
            void dim_check1() {
              if(zero_cross == true) {
                if(i>=fadeLevel1) {
                  digitalWrite(AC_pin1, HIGH);  // turn on light
                  i=0;  // reset time step counter
                  zero_cross=false;    // reset zero cross detection flag
                else {
                  i++;  // increment time step counter
            void dim_check2() {
                if(j>=fadeLevel2) {
                  digitalWrite(AC_pin2, HIGH);  // turn on light
                  j=0;  // reset time step counter
                else {
                  j++;  // increment time step counter
            void dim_check3() {
                if(k>=fadeLevel3) {
                  digitalWrite(AC_pin3, HIGH);  // turn on light
                  k=0;  // reset time step counter
                else {
                  k++;  // increment time step counter
            void dim_check4() {
                if(l>=fadeLevel4) {
                  digitalWrite(AC_pin4, HIGH);  // turn on light
                  l=0;  // reset time step counter
                else {
                  l++;  // increment time step counter
                gw.process();
              if (message.type == V_LIGHT || message.type == V_DIMMER) {
                requestedLevel *= ( message.type == V_LIGHT ? 100 : 1 );
                // Clip incoming level to valid range of 0 to 100
                float percent_level;
                percent_level = 128 - (requestedLevel * 1.28);
                fadeToLevel( percent_level );
                 Serial.print( "Changing level to " );
                Serial.print( ", from " );
                Serial.println( currentLevel );
               //  gw.send(lightMsg.set(currentLevel > 0 ? 1 : 0));
                 // gw.send( dimmerMsg.set(currentLevel) );
             *  This method provides a graceful fade up/down effect
            void fadeToLevel( int toLevel ) {
              Serial.print("toLevel Value: ");
             Serial.println(toLevel);
              int delta = ( currentLevel - toLevel ) < 0 ? 1 : -1;
              Serial.print("delta Value: ");
             Serial.println(delta);
              while ( currentLevel != toLevel ) {
                currentLevel += delta;
             fadeLevel= ((int)currentLevel);
                delay( FADE_DELAY );
            I have trouble understanding this part:
            all 4 dimmers are type V_LIGHT and V_DIMMER
            how do i get the right dimmer value from the controller from each different dimmer?
            someone who can help me with the rest of the code?
            thanks!
            R 1 Reply Last reply
            • T thomasdc
              hi!
              I bought this:
              regards, Thomas
              AC Light Control
              #define SV "1.0"
              volatile int j=0;
              volatile int k=0;
              volatile int l=0;
              int AC_pin2 = 5;
              int AC_pin3 = 6;
              int AC_pin4 = 7;
              //Tuy chinh lai
              void dim_check1() {
                  if(i>=fadeLevel1) {
                  else {
              void dim_check2() {
                  if(j>=fadeLevel2) {
                  else {
              void dim_check3() {
                  if(k>=fadeLevel3) {
                  else {
              void dim_check4() {
                  if(l>=fadeLevel4) {
                  else {
                  gw.process();
              thanks!
              R Offline
              R Offline
              rvendrame
              @thomasdc , as simple as
               // Channel Number
                int i = message.sensor;
              ESP8266 GW + mySensors 2.3.2
              Alexa / Google Home
              T 1 Reply Last reply
              • R rvendrame
                 // Channel Number
                T Offline
                T Offline
                thomasdc
                 // Channel Number
                Thank you very much for the reply!
                can you expain it a litle more?
                so i have 4 dimmers:
                how do i get the vallue for each dimmer?
                so how do i get an 'int i' for channel one, an 'int j' for channel two, and so on ?
                where do i put the code? is it just behind the:
                ? do i have to change something in the 'void incomming message' (see above)
                big thanks!
                • K Offline
                  K Offline
                  korttoma
                  My RGBW sketch is basically 4 dimmers also, take a look in this thread:
                  http://forum.mysensors.org/topic/1939/scripting-scenes-for-rgb-strip-best-way-to-control-mysensors-rgbw-node-from-vera/6
                  • Tomas
                  • K korttoma
                    T Offline
                    T Offline
                    thomasdc
                    thanks for the reply!
                    I dont really get your code... you receive a byte from the controller? / you use a 'mode' to set your dimmers? my dimmers are 4 induvidual dimmers and dont have to work together ..
                    • C Offline
                      C Offline
                      csa02221862
                      Another way to go is to use something like this and just convert everything to 12/24v dc. You can upgrade your lighting as you go and much easier and safer than AC dimming. If coarse there is still the ceiling fan to deal with. I will probably do that with an IR blaster.
                      • C Offline
                        C Offline
                        csa02221862
                        Forgot the link.....
                        http://www.12vmonster.com/products/ac-dc-12-volt-to-24-volt-12w-60x-5050-cluster-led-light-bulb-e26-e27-screw-fitting-lamp?variant=379155053
                        • T Offline
                          T Offline
                          thomasdc
                          but anyway how to get the different dimmer value's from the controller stays the same ;) and i am still troubling on that :s
                          • K Offline
                            K Offline
                            korttoma
                            Just ignor the mode related code, you probably dont need that. I allso have 4 individual dimmers they just happen to be connected to a RGBW Led strip. Same same but different.
                            • Tomas
                            • K Offline
                              K Offline
                              korttoma
                              Simplified the sketch code a bit. Here is an example how you can control 4 individual dimmers:
                              // Example sketch showing how to control RGBW LED Strip.
                              //IMPORTANTE NOTE!!! one of the "radio" pins has been moved from pin 9 to pin 4 because the White is connected to pin 9 because only 3,5,6 and 9 are PWM outputs!!!!
                              // This code should generate 4 Dimmer devices in Vera so you can control the RED, GREEN, BLUE and WHITE individualy
                              #define SN "RGBW"
                              #define SV "1.2"
                              #define NODE_ID AUTO
                              #define RED       3 // pin for red LED
                              #define GREEN     5 // pin for green
                              #define BLUE      6 // pin for blue
                              #define WHITE     9 // pin for white
                              #define RF24_CE_PIN		4	//<-- NOTE!!! (4,10) and NOT (9,10)
                              #define RF24_CS_PIN		10
                              #define RF24_PA_LEVEL	RF24_PA_MAX
                              MyTransportNRF24 transport(RF24_CE_PIN, RF24_CS_PIN, RF24_PA_LEVEL);
                              MySensor gw(transport);
                              	gw.begin(setDimmerStatus, NODE_ID);
                              	gw.present(RED, S_DIMMER);
                              	gw.present(GREEN, S_DIMMER);
                              	gw.present(BLUE, S_DIMMER);
                              	gw.present(WHITE, S_DIMMER);
                              	pinMode(RED, OUTPUT);
                              	pinMode(GREEN, OUTPUT);
                              	pinMode(BLUE, OUTPUT);
                              	pinMode(WHITE, OUTPUT);
                              	//Get values from RAM and write to outputs
                              	analogWrite(RED, 255 * gw.loadState(RED) / 100);
                              	analogWrite(GREEN, 255 * gw.loadState(GREEN) / 100);
                              	analogWrite(BLUE, 255 * gw.loadState(BLUE) / 100);
                              	analogWrite(WHITE, 255 * gw.loadState(WHITE) / 100);
                              	gw.process();
                              void setDimmerStatus(const MyMessage &message)
                              	if (message.type == V_DIMMER)
                              		uint8_t incomingDimmerStatus = message.getByte();
                              		analogWrite(message.sensor, 255 * incomingDimmerStatus / 100);
                              		gw.saveState(message.sensor, message.getByte()); //Save value to RAM
                              • Tomas
                              • F Offline
                                F Offline
                                FotoFieber
                                Today I played with my AC dimmer
                                http://forum.mysensors.org/topic/1316/ac-dimmer-with-openhab/3
                                It is very similar to the one reference above (but maybe a little bit cheaper :) ).
                                Good news: it is working fine with normal light bulbs and halogen tubes.
                                Bad news: it doesn't work with the high voltage LED tubes I testetd.
                                Has anybody a recommendation for a dimmable LED tube (E27/E17 230 V) working with the setup from this thread?
                                • R Offline
                                  R Offline
                                  rvendrame
                                  @FotoFieber , I use some 230V dimmable leds that I bought from IKEA in Germany about 1 year ago and and they work good. Some are Philips and some are IKEA-branded.
                                  Most important is the 'dimmable' word on them. Most of current led drivers are not designed for AC dimming, as this increase the unit costs (usually the driver is more expensive than the leds itself)...
                                  Alexa / Google Home
