  3. AC diming
AC diming
16 Posts 6 Posters 9.2k Views 4 Watching
  • T thomasdc
    hi!
    after long searching and trying i managed to Build an 'MySensors' AC dimming node.
    I bought this:
    http://www.ebay.com/itm/4CH-AC-Dimmer-Module-Controller-Board-ARDUINO-RASPBERRY-Compatible-50-60Hz-/121752461158?ssPageName=ADME:X:RTQ:US:1123
    and i use it to control my lightning.
    regards, Thomas
    It was working for 1 dimmer but now im am updating the code for '4' dimmers but i am having trouble with understanding...
    this is the code so far:
    this is based on the sketch from Quocanhcgd
    link: http://forum.mysensors.org/topic/1316/ac-dimmer-with-openhab
    Tested With Domoticz, working fine 220V 50Hz
    AC Light Control
    Uses up and down buttons to set levels
    makes use of a timer interrupt to set the level of dimming
    #include <TimerOne.h>
    #define SN "AC Dimmer control"
    #define SV "1.0"
    #define NODE_ID 30  //change to a number to assign a specific ID
    #define FADE_DELAY 18  // Delay in ms for each percentage fade up/down (10ms = 1s full-range dim)
    #define FADE_PERCENTAGE 5 //The percentage the fade level will be changed when a button is pressed
    volatile int i=0;               // Variable to use as a counter of dimming steps. It is volatile since it is passed between interrupts
    volatile int j=0;
    volatile int k=0;
    volatile int l=0;
    volatile boolean zero_cross=0;  // Flag to indicate we have crossed zero
    int AC_pin1 = 4;                 // Output to Opto Triac
    int AC_pin2 = 5;
    int AC_pin3 = 6;
    int AC_pin4 = 7;
    int freqStep = 75;              // This is the delay-per-brightness step in microseconds. It allows for 128 steps
                                    // If using 60 Hz grid frequency set this to 65
    //Tuy chinh lai
    static int currentLevel1 = 128;  // Current dim level...
    static int currentLevel2 = 128;  // Current dim level...
    static int currentLevel3 = 128;  // Current dim level...
    static int currentLevel4 = 128;  // Current dim level...
    uint8_t fadeLevel1 = 128; //used to store the fade level when using the buttons
    uint8_t fadeLevel2 = 128:
    uint8_t fadeLevel3 = 128;
    uint8_t fadeLevel4 = 128:
    MyMessage dimmer1Msg(AC_pin1, V_DIMMER);
    MyMessage light1Msg(AC_pin1, V_LIGHT);
    MyMessage dimmer2Msg(AC_pin2, V_DIMMER);
    MyMessage light2Msg(AC_pin2, V_LIGHT);
    MyMessage dimmer3Msg(AC_pin2, V_DIMMER);
    MyMessage light3Msg(AC_pin3, V_LIGHT);
    MyMessage dimmer4Msg(AC_pin4, V_DIMMER);
    MyMessage light4Msg(AC_pin4, V_LIGHT);
    void setup() {  // Begin setup
      /// - Setup Mysensors
      Serial.println( SN );
      gw.begin( incomingMessage,  NODE_ID, true);
      // Register the LED Dimmable Light with the gateway
        gw.present( AC_pin1, S_DIMMER );
        gw.present( AC_pin2, S_DIMMER );
        gw.present( AC_pin3, S_DIMMER );
        gw.present( AC_pin4, S_DIMMER );
      gw.sendSketchInfo(SN, SV);
      // Pull the gateway's current dim level - restore light level upon sendor node power-up
      gw.request( AC_pin1, V_DIMMER );
      gw.request( AC_pin2, V_DIMMER );
      gw.request( AC_pin3, V_DIMMER );
      gw.request( AC_pin4, V_DIMMER );
      //Setup AC PIN  // Set the Triac pin as output
       pinMode(AC_pin1, OUTPUT);
       pinMode(AC_pin2, OUTPUT);
       pinMode(AC_pin3, OUTPUT);
       pinMode(AC_pin4, OUTPUT);
      attachInterrupt(1, zero_cross_detect, RISING);    // Attach an Interupt to Pin 2 (interupt 0) for Zero Cross Detection
      Timer1.initialize(freqStep);                      // Initialize TimerOne library for the freq we need
      Timer1.attachInterrupt(dim_check, freqStep);      // Go to dim_check procedure every 75 uS (50Hz)  or 65 uS (60Hz)
      // Use the TimerOne Library to attach an interrupt
    void zero_cross_detect() {
      zero_cross = true;               // set flag for dim_check function that a zero cross has occured
      i=0;                             // stepcounter to 0.... as we start a new cycle
      digitalWrite(AC_pin1, LOW);
      digitalWrite(AC_pin2, LOW);
      digitalWrite(AC_pin3, LOW);
      digitalWrite(AC_pin4, LOW);
    // Turn on the TRIAC at the appropriate time
    // We arrive here every 75 (65) uS
    // First check if a flag has been set
    // Then check if the counter 'i' has reached the dimming level
    // if so.... switch on the TRIAC and reset the counter
    void dim_check1() {
      if(zero_cross == true) {
        if(i>=fadeLevel1) {
          digitalWrite(AC_pin1, HIGH);  // turn on light
          i=0;  // reset time step counter
          zero_cross=false;    // reset zero cross detection flag
        else {
          i++;  // increment time step counter
    void dim_check2() {
        if(j>=fadeLevel2) {
          digitalWrite(AC_pin2, HIGH);  // turn on light
          j=0;  // reset time step counter
        else {
          j++;  // increment time step counter
    void dim_check3() {
        if(k>=fadeLevel3) {
          digitalWrite(AC_pin3, HIGH);  // turn on light
          k=0;  // reset time step counter
        else {
          k++;  // increment time step counter
    void dim_check4() {
        if(l>=fadeLevel4) {
          digitalWrite(AC_pin4, HIGH);  // turn on light
          l=0;  // reset time step counter
        else {
          l++;  // increment time step counter
      if (message.type == V_LIGHT || message.type == V_DIMMER) {
        float percent_level;
        percent_level = 128 - (requestedLevel * 1.28);
        fadeToLevel( percent_level );
         Serial.print( "Changing level to " );
        Serial.print( ", from " );
        Serial.println( currentLevel );
       //  gw.send(lightMsg.set(currentLevel > 0 ? 1 : 0));
         // gw.send( dimmerMsg.set(currentLevel) );
     *  This method provides a graceful fade up/down effect
    void fadeToLevel( int toLevel ) {
      Serial.print("toLevel Value: ");
     Serial.println(toLevel);
      int delta = ( currentLevel - toLevel ) < 0 ? 1 : -1;
      Serial.print("delta Value: ");
     Serial.println(delta);
      while ( currentLevel != toLevel ) {
        currentLevel += delta;
     fadeLevel= ((int)currentLevel);
        delay( FADE_DELAY );
    I have trouble understanding this part:
    all 4 dimmers are type V_LIGHT and V_DIMMER
    how do i get the right dimmer value from the controller from each different dimmer?
    someone who can help me with the rest of the code?
    thanks!
    rvendrameR
    rvendrameR
    rvendrame
    @thomasdc , as simple as
     // Channel Number
      int i = message.sensor;
    ESP8266 GW + mySensors 2.3.2
    Alexa / Google Home
    • rvendrameR rvendrame
       // Channel Number
      thomasdc
      wrote on last edited by thomasdc
       // Channel Number
      Thank you very much for the reply!
      can you expain it a litle more?
      so i have 4 dimmers:
      how do i get the vallue for each dimmer?
      so how do i get an 'int i' for channel one, an 'int j' for channel two, and so on ?
      where do i put the code? is it just behind the:
      ? do i have to change something in the 'void incomming message' (see above)
      big thanks!
      • korttomaK
        korttomaK
        korttoma
        My RGBW sketch is basically 4 dimmers also, take a look in this thread:
        http://forum.mysensors.org/topic/1939/scripting-scenes-for-rgb-strip-best-way-to-control-mysensors-rgbw-node-from-vera/6
        • Tomas
        • korttomaK korttoma
          thomasdc
          thanks for the reply!
          I dont really get your code... you receive a byte from the controller? / you use a 'mode' to set your dimmers? my dimmers are 4 induvidual dimmers and dont have to work together ..
          • C
            C
            csa02221862
            Another way to go is to use something like this and just convert everything to 12/24v dc. You can upgrade your lighting as you go and much easier and safer than AC dimming. If coarse there is still the ceiling fan to deal with. I will probably do that with an IR blaster.
            • C
              C
              csa02221862
              Forgot the link.....
              http://www.12vmonster.com/products/ac-dc-12-volt-to-24-volt-12w-60x-5050-cluster-led-light-bulb-e26-e27-screw-fitting-lamp?variant=379155053
              • T
                thomasdc
                but anyway how to get the different dimmer value's from the controller stays the same ;) and i am still troubling on that :s
                • korttomaK
                  korttomaK
                  korttoma
                  Just ignor the mode related code, you probably dont need that. I allso have 4 individual dimmers they just happen to be connected to a RGBW Led strip. Same same but different.
                  • Tomas
                  • korttomaK
                    korttomaK
                    korttoma
                    Simplified the sketch code a bit. Here is an example how you can control 4 individual dimmers:
                    // Example sketch showing how to control RGBW LED Strip.
                    //IMPORTANTE NOTE!!! one of the "radio" pins has been moved from pin 9 to pin 4 because the White is connected to pin 9 because only 3,5,6 and 9 are PWM outputs!!!!
                    // This code should generate 4 Dimmer devices in Vera so you can control the RED, GREEN, BLUE and WHITE individualy
                    #define SN "RGBW"
                    #define SV "1.2"
                    #define NODE_ID AUTO
                    #define RED       3 // pin for red LED
                    #define GREEN     5 // pin for green
                    #define BLUE      6 // pin for blue
                    #define WHITE     9 // pin for white
                    #define RF24_CE_PIN		4	//<-- NOTE!!! (4,10) and NOT (9,10)
                    #define RF24_CS_PIN		10
                    #define RF24_PA_LEVEL	RF24_PA_MAX
                    MyTransportNRF24 transport(RF24_CE_PIN, RF24_CS_PIN, RF24_PA_LEVEL);
                    MySensor gw(transport);
                    	gw.begin(setDimmerStatus, NODE_ID);
                    	gw.present(RED, S_DIMMER);
                    	gw.present(GREEN, S_DIMMER);
                    	gw.present(BLUE, S_DIMMER);
                    	gw.present(WHITE, S_DIMMER);
                    	pinMode(RED, OUTPUT);
                    	pinMode(GREEN, OUTPUT);
                    	pinMode(BLUE, OUTPUT);
                    	pinMode(WHITE, OUTPUT);
                    	//Get values from RAM and write to outputs
                    	analogWrite(RED, 255 * gw.loadState(RED) / 100);
                    	analogWrite(GREEN, 255 * gw.loadState(GREEN) / 100);
                    	analogWrite(BLUE, 255 * gw.loadState(BLUE) / 100);
                    	analogWrite(WHITE, 255 * gw.loadState(WHITE) / 100);
                    void setDimmerStatus(const MyMessage &message)
                    	if (message.type == V_DIMMER)
                    		uint8_t incomingDimmerStatus = message.getByte();
                    		analogWrite(message.sensor, 255 * incomingDimmerStatus / 100);
                    		gw.saveState(message.sensor, message.getByte()); //Save value to RAM
                    • Tomas
                    • FotoFieberF
                      FotoFieberF
                      FotoFieber
                      Today I played with my AC dimmer
                      http://forum.mysensors.org/topic/1316/ac-dimmer-with-openhab/3
                      It is very similar to the one reference above (but maybe a little bit cheaper :) ).
                      Good news: it is working fine with normal light bulbs and halogen tubes.
                      Bad news: it doesn't work with the high voltage LED tubes I testetd.
                      Has anybody a recommendation for a dimmable LED tube (E27/E17 230 V) working with the setup from this thread?
                      • rvendrameR
                        rvendrameR
                        rvendrame
                        @FotoFieber , I use some 230V dimmable leds that I bought from IKEA in Germany about 1 year ago and and they work good. Some are Philips and some are IKEA-branded.
                        Most important is the 'dimmable' word on them. Most of current led drivers are not designed for AC dimming, as this increase the unit costs (usually the driver is more expensive than the leds itself)...
                        Alexa / Google Home
