  3. What kind of relay for in-wall application?
4 Posts 3 Posters 2.2k Views 3 Watching
  • Cliff KarlssonC Offline
    Cliff Karlsson
    Hi I am planning to use a relay behind a wall-socket to control lighting. But what kind of relay is the best to use for this as saftey is a big concern ?
    Omron SSR
    SSR 40DA
    Relay
    I would think that SSR relays would be safer, correct? I guess I could use the Omron relay for controling windows lights as it is rated at 2A but If I forget and plug in a toaster that would probably not be so great?
    That leaves me with the SSR 40DA witch is rather big but might fit. But Do I really need a heatsink for that relay if the largest load (toaster) would be 230V/4-5A witch is around 1000W?
    A 1 Reply Last reply
    • N Offline
      N Offline
      NotYetRated
      For insurance purposes, you don't want to install anything where "if I forget, burn" could be a factor. Perhaps a fuse to prevent such issues?
        Omron SSR
        SSR 40DA
        Relay
        A Offline
        A Offline
        AWI
        @Cliff-Karlsson A standard (EU, 230V) socket should be able to handle loads of around 2000-2500W. So the max current would be around 10A.
        SSR have (ballpark) voltage drop of around 1 to 1.5V. So with max load there is around 15W to handle for the SSR. About the heat of a traditional small light bulb. For your toaster 5-10 W. if ventilated this should be do-able (you better add some heat protection next to the fuse). Traditional Relays have much less dissipation but lack the Solid State advantages.
          Cliff Karlsson
          Ok, the heat issue was new to me regarding the ssr's. I already have one SSR-40DA and its quite big as it is without a heatsink. I think I wil go with the standar relays instead. But What kind of fuses should I get to make it as sefe as possible. A Thermal fuse
          Do I need some more fuse? if so a ebay/aliexpress link would be great.
