  3. Sleep() doesn't "power down" the controller
3 Posts 3 Posters 1.9k Views 1 Watching
  • R Offline
    R Offline
    RoBra81
    I'm creating my first sensor which shall be a sensor monitoring multiple window sash. For that I want't to configure multiple pins as interrupt and set the arduino sleeping until one sash changes its state. Interrupts are working fine but since I'd like to power the sensor using batteries I measured the current and stated that even when thinking the sensor shall sleep it needs about 2mA (cut off power LED) :disappointed:
    Since I read that it should be within µA-area I'm asking what I'm doing wrong?
    Here my sketch:
     * Interrupt driven binary switch example with dual interrupts
     * Author: Patrick 'Anticimex' Fallberg
     * Connect one button or door/window reed switch between
     * digitial I/O pin 3 (BUTTON_PIN below) and GND and the other
     * one in similar fashion on digital I/O pin 2.
     * This example is designed to fit Arduino Nano/Pro Mini
    #include <EnableInterrupt.h>
    #define SKETCH_NAME "Multiple Window Sensor"
    #define SKETCH_MAJOR_VER "1"
    #define SKETCH_MINOR_VER "0"
    #define FIRST_WINDOW_ID 1
    #define SECOND_WINDOW_ID 2
    #define THIRD_WINDOW_ID 3
    #define FORTH_WINDOW_ID 4
    #define FIRST_WINDOW_PIN 4   // Arduino Digital I/O pin for button/reed switch
    #define SECOND_WINDOW_PIN 5 // Arduino Digital I/O pin for button/reed switch
    #define THIRD_WINDOW_PIN 6   // Arduino Digital I/O pin for button/reed switch
    #define FORTH_WINDOW_PIN 7 // Arduino Digital I/O pin for button/reed switch
    MySensor sensor_node;
    MyMessage first_window_msg(FIRST_WINDOW_ID, V_TRIPPED);
    MyMessage second_window_msg(SECOND_WINDOW_ID, V_TRIPPED);
    MyMessage third_window_msg(THIRD_WINDOW_ID, V_TRIPPED);
    MyMessage forth_window_msg(FORTH_WINDOW_ID, V_TRIPPED);
    void interruptFunctionFirstWindow() {
      sensor_node.sleep(5);
      sensor_node.send(first_window_msg.set(digitalRead(FIRST_WINDOW_PIN)));
    void interruptFunctionSecondWindow() {
      sensor_node.send(second_window_msg.set(digitalRead(SECOND_WINDOW_PIN)));
    void interruptFunctionThirdWindow() {
      sensor_node.send(third_window_msg.set(digitalRead(THIRD_WINDOW_PIN)));
    void interruptFunctionForthWindow() {
      sensor_node.send(forth_window_msg.set(digitalRead(FORTH_WINDOW_PIN)));
      sensor_node.begin();
      // Setup the buttons
      pinMode(FIRST_WINDOW_PIN, INPUT_PULLUP);
      pinMode(SECOND_WINDOW_PIN, INPUT_PULLUP);
      pinMode(THIRD_WINDOW_PIN, INPUT_PULLUP);
      pinMode(FORTH_WINDOW_PIN, INPUT_PULLUP);
      sensor_node.sendSketchInfo(SKETCH_NAME, SKETCH_MAJOR_VER"."SKETCH_MINOR_VER);
      // Register binary input sensor to sensor_node (they will be created as child devices)
      sensor_node.present(FIRST_WINDOW_ID, S_DOOR);
      sensor_node.present(SECOND_WINDOW_ID, S_DOOR);
      sensor_node.present(THIRD_WINDOW_ID, S_DOOR);
      sensor_node.present(FORTH_WINDOW_ID, S_DOOR);
      enableInterrupt(FIRST_WINDOW_PIN, interruptFunctionFirstWindow, CHANGE);
      enableInterrupt(SECOND_WINDOW_PIN, interruptFunctionSecondWindow, CHANGE);
      enableInterrupt(THIRD_WINDOW_PIN, interruptFunctionFirstWindow, CHANGE);
      enableInterrupt(FORTH_WINDOW_PIN, interruptFunctionSecondWindow, CHANGE);
      sensor_node.sleep(0, CHANGE, 1, CHANGE, 0);
    Could anybody help me finding the problem?
    Thanks in advance
    Ronny
    D A 2 Replies Last reply
    • R RoBra81
      Here my sketch:
      Thanks in advance
      Ronny
      Dwalt
      @RoBra81
      Which Arduino model are you using? Pro-mini? You mentioned cutting the LED, did you also remove the power regulator?
      • R RoBra81
        Here my sketch:
        Thanks in advance
        Ronny
        A Offline
        A Offline
        AWI
        @RoBra81 When (one of) your contacts is closed there will be a current flowing through the (internal) pull-up's of the Arduino. This is around 0.25 mA per active switch! depending on the type of Arduino and supply voltage. AVR has 20k-50k pull-up resistors.
