  3. Sensebender Micro not work
2 Posts 2 Posters 1.1k Views 2 Watching
  • V
    V
    vampircik
    Hello everybody. I have a problem, do not want to work the boards.He writes Снимок экрана (7).png
      mvader
      things to check / do
      1. verify radio is good
      2. verify radio is connected correctly
      3. if header soldered in, verify nothing is touching / solder work is clean/good
      4. upgrade to arduino 1.6.5
      5. verify mysensors is library v1.5
      6. if you set up a gateway recently, verify you turned softspi back off and didn't leave it on.
      your issue likely lies in one of those areas.
