  3. Iboard - Cheap Single board Ethernet Arduino with Radio
iboard
74 Posts 27 Posters 68.1k Views 9 Watching
  • H Offline
    H Offline
    Hacker007
    Hi. I have tried nneeoos' solution fot SOFTSPI, but the code only compiles if I use DigitalIO library in my main INO file too (I tried MQTTGateway ethernet on Iboard). I have the latest librarys. After uploading I get "check wires".
    • T Offline
      T Offline
      tbully
      Hello. I too tried @nneeoo 's edits and am getting check wires.
      Here's my relevant RH24_Config settings:
        const uint8_t SOFT_SPI_MISO_PIN = 6;
        const uint8_t SOFT_SPI_MOSI_PIN = 5;
        const uint8_t SOFT_SPI_SCK_PIN = 7;
        const uint8_t SPI_MODE = 0;
      And here's my setup in my gateway sketch:
       #include <Ethernet.h>
       #define INCLUSION_MODE_TIME 1 // Number of minutes inclusion mode is enabled
       #define INCLUSION_MODE_PIN  3 // Digital pin used for inclusion mode button
       #define RADIO_CE_PIN        5  // radio chip enable
       #define RADIO_SPI_SS_PIN    6  // radio SPI serial select
       #define RADIO_ERROR_LED_PIN 10  // Error led pin
       #define RADIO_RX_LED_PIN    8  // Receive led pin
       #define RADIO_TX_LED_PIN    9  // the PCB, on board LED
       #define IP_PORT 5003        // The port you want to open
       IPAddress myIp (192, 168, 34, 169);
      T 1 Reply Last reply
      • T tbully
        T Offline
        T Offline
        tbully
        To be clear, I'm not afraid to do the hardware modification but it appears that @nneeoo got it to work without doing so. If that's true, I'd like to go that route........
        • T Offline
          T Offline
          tbully
          As an update....I gave up on the software method and just did the hardware modification.
          All is well now.
          One question: How did you guys do the LED and inclusion buttons? Did you carefully solder right to the Atmega chip or is there a better place to grab the needed pins?
          What pins did you use for TX/RX/ERR/Inclusion?
          • greglG Offline
            greglG Offline
            gregl
            Hi @tbully - i personally never bothered with leds/inclusion button.
            My gatway is underneath my staircase near vera and my wifi router, so other than when i make a change, i never see it - so leds wouldnt help me.
            When i do an inclusion i do so via software..so no button needed either...
            I would like a nice 3d printed case for it one day...still havent boxed the iboard up!
            • greglG gregl
              T Offline
              T Offline
              tbully
              Same here, @gregl . I appreciate your write-ups above. They really helped out. I'd like to find a printer and user @jtm312 's design but would like to know how he got the LEDs and Button wired up. Soldering directly to the chip could be difficult without a steady hand.
              • H Offline
                H Offline
                hugob
                wrote on last edited by hugob
                #47
                I am using the Itead iBoard as a gateway to a Vera Light for a few days now. Without any hardware modifications, only a few changes in header files required. I think the main issue is that you should map the inclusion button and led's to the Ax pins and use the full constructor (with 7 parameters). Beware of the last line in the first snippet. If you use the shortcut constructor (with three parameters), it will use defaults for the other parameters and your defs will be ignored.
                To verify my assumptions above, I included a led to the A2 pin and it is blinking as expected on arrival of a packet.
                The code below may look intimidating. But I posted the whole thing for easy reference. You can do the software changes in one minute.
                Hugo
                Snippet from EthernetGateway.ino:
                #define INCLUSION_MODE_PIN  14 //A0 // Digital pin used for inclusion mode button
                #define RADIO_CE_PIN        3 // radio chip enable
                #define RADIO_SPI_SS_PIN    8  // radio SPI serial select
                #define RADIO_ERROR_LED_PIN 15 //A1 // Error led pin
                #define RADIO_RX_LED_PIN    16 //A2 // Receive led pin
                #define RADIO_TX_LED_PIN    17 //A3 // the PCB, on board LED
                IPAddress myIp (192, 168, 178, 66);  // Configure your static ip-address here    COMPILE ERROR HERE? Use Arduino IDE 1.5.7 or later!
                byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };  // DEAD BEEF FEED
                // a R/W server on the port
                EthernetServer server = EthernetServer(IP_PORT);
                // No blink or button functionality. Use the vanilla constructor.
                //MyGateway gw(RADIO_CE_PIN, RADIO_SPI_SS_PIN, INCLUSION_MODE_TIME);
                // Uncomment this constructor if you have leds and include button attached to your gateway
                MyGateway gw(RADIO_CE_PIN, RADIO_SPI_SS_PIN, INCLUSION_MODE_TIME, INCLUSION_MODE_PIN, RADIO_RX_LED_PIN, RADIO_TX_LED_PIN, RADIO_ERROR_LED_PIN);
                Snippet from \Arduino\libraries\MySensors\utility\RF24_config.h
                #define MINIMAL
                  //#define SPI_UART  // Requires library from https://github.com/TMRh20/Sketches/tree/master/SPI_UART
                  #define SOFTSPI   // Requires library from https://github.com/greiman/DigitalIO
                  // Define _BV for non-Arduino platforms and for Arduino DUE
                #if defined (ARDUINO) && !defined (__arm__)
                	#if defined(__AVR_ATtiny25__) || defined(__AVR_ATtiny45__) || defined(__AVR_ATtiny85__) || defined(__AVR_ATtiny24__) || defined(__AVR_ATtiny44__) || defined(__AVR_ATtiny84__)
                		#define RF24_TINY
                		#define _SPI SPI
                	#else
                	  #if defined SPI_UART
                		#include <SPI_UART.h>
                		#define _SPI uspi
                	  #elif defined SOFTSPI
                	  // change these pins to your liking
                	  #define _SPI spi
                		  #else
                		#define _SPI SPI
                #else
                • greglG Offline
                  greglG Offline
                  gregl
                  @hugob - Finally got to try this last night late...Success!
                  I did also need to add to the EthernetGateway.ino this line to load the Softspi libs...
                  #include <DigitalIO.h>     <-added this too!
                  #include <MyGateway.h>
                  #include <stdarg.h>
                  I also needed to compile it under a newer IDE version due to memory..I used 1.6.5.
                  H 1 Reply Last reply
                  • greglG gregl
                    #include <stdarg.h>
                    H Offline
                    H Offline
                    hugob
                    @gregl
                    Good to hear that you can confirm that this is working. My unmodified IBoard gateway is working for months now without problems. But as I said in some other topic, this board needs a decent power supply.
                    So all you need for a MySensors Ethernet gateway is this board, a NRF24L01 Radio that plugs in into this board, and a power supply. No mess with cables like in http://www.mysensors.org/build/ethernet_gateway. This board has 7 IO ports in case you want the leds. For $17.50 this is a no brainer.
                    • H Offline
                      H Offline
                      hugob
                      OK, I did forget some minor drawback. You need a FTDI adapter to program this IBoard from the Arduino UI.
                      • S Offline
                        soward
                        I'm using this as a gateway w/ 1.5 also with no issue. I do have the LEDs hooked up as well, using an oversized 'recovered' power supply and the PA+LNA radio with no problems. All I need is a nice case...
                        D 1 Reply Last reply
                        • 5546dug5 Offline
                          5546dug5 Offline
                          5546dug
                          My iboard gw is up and running so far so good!
                          Using the basic sketch with no LEDs
                          Question I see only A0 to A5 I/o s where or how can I use t he sketches pins d6 -d9 pins?
                          I printed the my sensors 3d stl file for the gw and it fits great, but there are the holes for the 3 LEDs and re include button .
                          Any help would be good maybe just a senior moment eh?
                          • S soward
                            Dwalt
                            Print one
                            • F Offline
                              F Offline
                              Fabien
                              Switch today to MySensors 1.5 without any problem. Easy to setup softspi with MyConfig.h
                              • F Offline
                                F Offline
                                Fabien
                                And test OTA with a sensebender, work fine ! :smiley:
                                • H Offline
                                  H Offline
                                  hugob
                                  @5546dug
                                  In the original sketch, you map a variable to a Dn pin. E.g. INCLUSION_MODE_PIN is mapped to pin 3.
                                  The iBoard has no digital ports (Dn) on a connector, but only analog ports (An). Luckily, the analog ports can also be used as digital ports. The modified sketch maps the variables that were mapped to a Dn port in the oririginal sketch, to an An port in the modified sketch. This is the list:
                                  Original
                                  RADIO_ERROR_LED_PIN 7 // Error led pin
                                  Modified
                                  INCLUSION_MODE_PIN 14 // A0 Digital pin used for inclusion mode button
                                  RADIO_ERROR_LED_PIN 15 // A1 Error led pin
                                  RADIO_RX_LED_PIN 16 // A2 Receive led pin
                                  RADIO_TX_LED_PIN 17 // A3 the PCB, on board LED
                                  So for the iBoard, the receive LED has to be connected to pin 16 (A2). Etc.
                                  If you carefully look at the code, you will notice that also RADIO_SPI_SS_PIN changed from 6 to 8. That is because the header for the radio chip on the iBoard is connected to a different Arduino pin on the iBoard, than it is on the wiring diagram of the original gateway diagram. But this is just an internal issue. It should not bother you if you build the gateway.
                                  • 5546dug5 Offline
                                    5546dug5 Offline
                                    5546dug
                                    @hugob Thanks
                                    • E Offline
                                      E Offline
                                      envagyok
                                      Hi Guys!
                                      I have got a Wborad Ex board with built in wifi (rak410) from itead.
                                      http://wiki.iteadstudio.com/Wboard_Ex
                                      Unfortunately I can not find anywhere arduino code that would work of the board with wifi.
                                      Does anyone have the same board and could possibly help?
                                      Itead said it works on this demo, but without success .
                                      http://blog.iteadstudio.com/basic-testtutorial-for-itead-wifi-shield-rev2-by-david-morphett/
                                      Gabor
                                      hekH 1 Reply Last reply
                                      • E envagyok
                                        Hi Guys!
                                        Gabor
                                        hekH Offline
                                        hekH Offline
                                        @envagyok
                                        Maybe not the answer you want, but if you want a verified wifi-gateway solution, have a look at this:
                                        http://www.mysensors.org/build/esp8266_gateway
                                        • T Offline
                                          T Offline
                                          TommySharp
                                          I know this is a basic question but what do I need to buy to program this using USB from my PC? So far I've just tinkered with Nanos which have a usb port on it.... An ebay link would be great!
                                          K D 2 Replies Last reply
