  3. nRF24L01+PA+LNA capacitor is used at the power antenna
11 Posts 3 Posters 8.0k Views 3 Watching
  • V
    V
    vampircik
    Hello everybody. a capacitor is used to power the antenna?
    I have with this transmitter is not more than 100 meters in a straight line. 1000 stated that I need to do to increase the range? I use a 4.7 uF Capacitors staged parallel feeding antenna. arduino pro mini 8mhz 3.3v
    OitzuO 1 Reply Last reply
    • V vampircik
      OitzuO
      OitzuO
      Oitzu
      Search the forum. You probably have also the problem of the not well shielded pa+lna modul.
      • NuubiN
        NuubiN
        Nuubi
        Just in case...make sure you use capacitors to stabilize the power to the nRF circuit , not the actual antenna connection.
        • V
          V
          vampircik
          I is powered by a power supply. that is, the capacitor and may not need? on this board serial getaway need the capacitor?
          • OitzuO
            OitzuO
            Oitzu
            @vampircik the caps are needed to smooth your supply to the nrf module.
            You also need to make sure that your powersupply deliver enough mA for the nrf module.
            My tests conclude that in full power mode the nRF24L01+PA+LNA needs about 100-120mA.
            The onboard voltage regulator on the arduino pro mini 3.3V can probably not deliver that much.
            See also this thread http://forum.mysensors.org/topic/1877/2-x-nrf24l01-pa-lna-with-rf24_pa_max about the problems of a not well shielded nRF24L01+PA+LNA modules.
            • V
              V
              vampircik
              RelayActuator Using an example. he is originally small power radio. how can it be increased?
              • V
                V
                vampircik
                MyTransportNRF24 transport(RF24_CE_PIN, RF24_CS_PIN, RF24_PA_LEVEL_GW);
                //MyTransportRFM69 transport;
                • V vampircik
                  OitzuO
                  OitzuO
                  Oitzu
                  @vampircik you can replace RF24_PA_LEVEL_GW with RF24_PA_MIN, RF24_PA_LOW, RF24_PA_HIGH or RF24_PA_MAX.
                  • V
                    V
                    vampircik
                    As it is written in the sketch? I'm in this weak. It is necessary to have been more powerful.
                    • V
                      V
                      vampircik
                      MyTransportNRF24 transport(RF24_CE_PIN, RF24_CS_PIN, RF24_PA_MAX);
                      so it is necessary to register? all just sort of
                      • V
                        V
                        vampircik
                        RelayActuator__.ino
