  3. Guide: Setting up and testing MQTT Client Gateway
78 Posts 18 Posters 64.9k Views 18 Watching
  • S Samuel235
    @hek said:
    You can run the MQTT gateway on an Arduino+W5100 ethernet module or the ESP8266. Connect radio and ethernet module exactly like for the normal gateway.
    Have we managed to get a MQTT Gateway working on a Arduino with an ENC28J60 module rather than a w5100?
    @samuel235
    I didn't bother trying. The ENC-library is gigantic and the MQTT implementation used does not support the ENC-module.
    S 2 Replies Last reply
    • S Samuel235
      ahmedadelhosniA
      ahmedadelhosniA
      ahmedadelhosni
      @samuel235 I don't really encourage you to use ENC. I spent months trying to make it stable and I failed. There are several manufactures and as far as I know that there are several software workarounds to fix problem in the silicon chips. I turned to use W5100 and it is much better till now.
      N.B.: Some people managed to run ENC with good stability but as I have said, there may be different manufacturers so I got confused and tried the W5100.
      • S
        Samuel235
        @ahmedadelhosni I have now turned to the W5100 shield myself. Works a charm, super smooth!
        MySensors 2.1.1
        • V
          V
          vickey
          I tried to make MQTT client gateway but it is giving following error while compiling
          C:\Users\Ahmed\AppData\Local\Temp\build8359488613260197686.tmp/arduino.ar(core_esp8266_postmortem.c.o): In function `abort':
          C:\Users\Ahmed\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0-rc2\cores\esp8266/core_esp8266_postmortem.c:177: multiple definition of `abort'
          GatewayESP8266MQTTClient.cpp.o:C:\Users\Ahmed\Documents\Arduino\libraries\MySensors/core/MyMainESP8266.cpp:46: first defined here
          collect2.exe: error: ld returned 1 exit status
          Error compiling.
          Any suggestions @hek ?
            @vickey
            Sorry haven't seen this error. Which ESP board version do you have installed in the IDE? (See Board manager).
            Please do no double post on the forum! Only creates annoyance.
            • V
              V
              vickey
              @hek I am using Stable ESP8266 version 2.0.0 from stable release
              • C
                C
                ciprian
                If it helps:
                in ESP8266 ver. 2.0.0 was added abort in
                here
                cores/esp8266/core_esp8266_postmortem.c:
                void abort() __attribute__((noreturn));
                void abort(){
                    // cause exception
                    s_abort_called = true;
                    do {
                        *((int*)0) = 0;
                    } while(true);
                i comment the lines in MySensors/core/MyMainESP8266.cpp and it compiled ok.
                  @ciprian
                  This has been fixed since a while back.
                  • dakkyD
                    dakkyD
                    dakky
                    wrote on last edited by dakky
                    #29
                    Hello.
                    I tried the development branch because I prefer having my gateway not as message broker.
                    I had some problems resulting in conflicting entries for the gateway in MyConfig.h and the sketch. MyConfig.h always wins :D for the release it might be more transparent for the user if there is only one location, where the gateway settings are defined: example or MyConfig.h
                    So much for the feedback, now to the problems:
                    I use the w5100 version of the sketch with a static IP.
                    In the serial monitor i see:
                    0;0;3;0;9;Starting gateway (RNNGA-, 1.6.0-beta)
                    0;0;3;0;9;Radio init successful.
                    IP: 0.40.68.10
                    0;0;3;0;9;Attempting MQTT connection...
                    0;0;3;0;9;Init complete, id=0, parent=0, distance=0
                    in the log of the moquitto server i see:
                    1450112394: New connection from 192.168.100.10 on port 1883.
                    1450112394: Socket error on client <unknown>, disconnecting.
                    1450112409: New connection from 192.168.100.10 on port 1883.
                    The gateway tries to open a lot of connections and all of them seem to die after a short while
                    Any idea?
                    Controller: Raspberry Pi 2 :: Openhab2 :: with @TimO MySensors Binding
                    Gateway: Arduino MEGA 2560 R3 :: W5100 :: Ethernet GW
                    Software: MySensors 2.0development
                      Mike Cayouette
                      @dakky The gateway tries to open a lot of connections and all of them seem to die after a short while
                      I had a similar problem a while back, not with the mysensors dev branch, but while using the subpub MQTT library on a ESP8266. After upgrading my MQTT (mosquitto) server to version 1.3.5 it corrected to the problem. You may want to take a look at the version you are running.
                      Mike
                      • dakkyD
                        dakkyD
                        dakky
                        #31
                        Thx 4 replying ;)
                        mosquitto version 1.4.5 (build date Sun, 08 Nov 2015 21:43:12 +0000)
                        unfortunetly this seems not to be the problem :(
                        EDIT: i updated the PubSubClient lib to version 2.4 instead of the delivered 1.9. Same behavior
                        Another EDIT: mosquitto itself seems to work fine: OpenHab successfully connects to the broker and delivers its messages
                        • D
                          D
                          drock1985
                          I'm trying to set up the MQTT gateway to work with Home-Assistant; since the serial gateway plugin lacks in binary switches (ex relays, and other things).
                          I have the MQTT sketch installed on a Nano with W5100 module, and serial output from the Arduino is good. But when I add a sensor to the Gateway, there is no communication.
                          Here is my output from Arduino, where would I go next?
                          IP: 192.168.86.112
                          0;0;3;0;9;MQTT connected
                          ad: 0-0-0 s=0,c=0,t=0,pt=0,l=0,sg=0:
                          0;0;3;0;9;ver mismatch
                          0;0;3;0;9;MQTT connected```
                          My Projects
                          2 Door Chime Sensor
                          Washing Machine Monitor
                          • dakkyD
                            dakkyD
                            dakky
                            Any idea?
                            Narghs!
                            Seems to be a hardware problem. I changed the w5100 module with an w5100 arduino shield and now it works fine:
                            IP: 192.168.100.10
                            I'm still interested in the reason. Hardware broken or wiring fail?
                            • pinging the arduino worked
                            • i can see the connections on the broker
                            => basic networking seems to work, but "delivering content" failed. Any guesses?
                            Strange fact: with the "broken" hardware:
                            IP: 0.40.68.10
                            with the shield:
                            IP: 192.168.100.10
                            Same sketch, 192.168.100.10 is the correct Ip (obviously) ;)
                            Greeting
                            Dakky
                            ahmedadelhosniA 1 Reply Last reply
                            • dakkyD dakky
                              Any idea?
                              Narghs!
                              IP: 192.168.100.10
                              IP: 0.40.68.10
                              with the shield:
                              IP: 192.168.100.10
                              Greeting
                              Dakky
                              ahmedadelhosniA
                              ahmedadelhosniA
                              ahmedadelhosni
                              @dakky I guess I had that problem once or twice before but I don't pay attention to it as there was other bugs which were more important.
                              I remember that I just reset the nano and it worked at once. Glad that it worked for you but as you have said, knowing the root cause it important.
                              Will try to reproduce it again when I have time.
                              • dakkyD
                                dakkyD
                                dakky
                                #35
                                Another question:
                                I don't have any experience with the classic setup (broker on gateway). But does
                                The topic resembles the serial protocol. You must define you preferred subscribe and publish prefix in the sketch. The topic is build like this:
                                MY_MQTT_PUBLISH_TOPIC_PREFIX/FROM-NODE-ID/SENSOR-ID/CMD-TYPE/ACK-FLAG/SUB-TYPE
                                mean, that the consuming controllers configuration (openhab in my case) has to be changed?
                                From
                                sensor-gw1-out/99/3/V_TRIPPED
                                To
                                sensor-gw1-out/99/3/1/0/16
                                in order to represent what is really pushed to the mqtt broker? Because thats what is posted to the broker?
                                  moskovskiy82
                                  A little bit cofused. Can this sketch be uploaded to ESP12 set as in the "ESP8266 WiFi Gateway"? Without the arduino?
                                  After uploading it to esp all i get
                                  load 0x4010f000, len 1264, room 16
                                  tail 0
                                  chksum 0x42
                                  csum 0x42
                                  ~ld
                                    moskovskiy82
                                    Can more detailed instructions be given on the development branch? As i understand this is not a simple copy the code from here https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/examples/GatewayESP8266MQTTClient/GatewayESP8266MQTTClient.ino paste into arduino IDE compile and upload process?
                                      @moskovskiy82
                                      Yes, after the MySensors library has been installed you should be able to compile/upload the sketch and run it.
                                        moskovskiy82
                                        Well i had to move all the libs from production branch and extract clean only the development branch in arduino IDE to get it to work.
                                        Afterwards had to do the same thing back to production to compile the humidity sensor as it gave me the following error during compilation
                                        Arduino: 1.6.5 (Windows 7), Board: "Arduino Pro or Pro Mini, ATmega328 (5V, 16 MHz)"
                                        In file included from Mysensors_DHT_Wireless.ino:31:0:
                                        \My Documents\Arduino\libraries\MySensors/MySensor.h:201:3: error: #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
                                        Mysensors_DHT_Wireless:39: error: 'MySensor' does not name a type
                                        Mysensors_DHT_Wireless.ino: In function 'void setup()':
                                        Mysensors_DHT_Wireless:50: error: 'gw' was not declared in this scope
                                        Mysensors_DHT_Wireless.ino: In function 'void loop()':
                                        Mysensors_DHT_Wireless:75: error: 'gw' was not declared in this scope
                                        Mysensors_DHT_Wireless:85: error: 'gw' was not declared in this scope
                                        Mysensors_DHT_Wireless:90: error: 'gw' was not declared in this scope
                                          moskovskiy82
                                          Is there some miscompatability betweed development/production branches?
                                          My humidity sensor reports in the serial console just fine.
                                          req id
                                          send: 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,sg=0,st=ok:
                                          req id
                                          T: 24.60
                                          req id
                                          H: 87.00
                                          On the gateway i see the following
                                          0;255;3;0;9;read: 255-255-0 s=255,c=3,t=3,pt=0,l=0,sg=0:
                                          0;255;3;0;9;Sending message on topic: mygateway1-out/255/255/3/0/3
                                          But in mosquitto...
                                          mygateway1-out/255/255/3/0/3 (null)
