  3. Home Assistant
  4. Home Assistant - How to recognize MySensors nodes
home assistant
64 Posts 7 Posters 55.1k Views 3 Watching
  • MufasaM
    MufasaM
    Mufasa
    wrote on last edited by Mufasa
    #61
    @martinhjelmare
    Just ran it again and it seams to have worked, Thanks a lot for the help!!
    • MufasaM Mufasa
      @martinhjelmare
      martinhjelmareM
      martinhjelmareM
      martinhjelmare
      @Mufasa
      If you declare your variable lightMsg in the for loop, it will be overwritten if you have more than one relay. I think you can use an array the same length as number of relays and store the msg variable in the slots of the array. Then use the array where you need your msg variables.
      • MufasaM
        MufasaM
        Mufasa
        @martinhjelmare
        Ok cool just sorted that out! Is there any way to change the names of the individual child sensors and the switch? For example to have a room name and the names of the lights in that room as each child.
        • MufasaM Mufasa
          @martinhjelmare
          martinhjelmareM
          martinhjelmareM
          martinhjelmare
          @Mufasa
          Yes, you can make custom names and groups of your devices.
          https://home-assistant.io/getting-started/devices/
          Also read the blog post on customizing icons from version 0.8.
