  3. Home Assistant
  4. Home Assistant - How to recognize MySensors nodes
home assistant
64 Posts 7 Posters 55.1k Views 3 Watching
    @drock1985 said:
    Would it be possible to get a Home-Assistant dedicated sub-forum please?
    You got it.
    http://forum.mysensors.org/category/28/home-assistant
    • D
      D
      drock1985
      wrote on last edited by drock1985
      #42
      Thanks @hek very appreciated.
      EDIT: Sort of ran into an issue with the Dev MQTTW5100Gateway sketch.... Thought the output I was getting above was good, but in reality the Arduino IDE wasn't giving an error. I decided to run the gateway in my RPI and view the data through SSH via screen. It initializes and shows the same data as the Arduino IDE, but then seconds later it dies and gives an error about screen terminating. Happens every time.
      Going to try the ESP8266MQTTGateway: I'm got a hunch.
      My Projects
      2 Door Chime Sensor
      Washing Machine Monitor
      • D drock1985
        I've been trying to get MQTT working using the Dev branch here (http://forum.mysensors.org/topic/2352/guide-setting-up-and-testing-mqtt-client-gateway/) and have my configuration.yaml file looking like this for my W5100MQTT broker:
        #MySensors MQTT Test
        mqtt 1:
          broker: 192.168.86.198
          port: 1883
        #  client_id: home-assistant-1
          keepalive: 60
        #  username: USERNAME
        #  password: PASSWORD
        The Serial output from Arduino shows that I connected successfully
        0;0;3;0;9;Starting gateway (RNNGA-, 1.6.0-beta)
        0;0;3;0;9;Radio init successful.
        IP: 192.168.86.112
        0;0;3;0;9;Attempting MQTT connection...
        0;0;3;0;9;MQTT connected
        0;0;3;0;9;Init complete, id=0, parent=0, distance=0
        But, Home-Assistant isn't registering the broker, and I have this error in the Dev section:
        15-12-15 15:32:17 homeassistant.components.mqtt: Missing required configuration items in mqtt: broker
        15-12-15 15:32:17 homeassistant.bootstrap: component mqtt failed to initialize
        Does anyone have any ideas? @humblehacker @martinhjelmare @hek ?
        H
        H
        humblehacker
        wrote on last edited by humblehacker
        #43
        mqtt 1:
          port: 1883
          keepalive: 60
        Does the IP address you defined in the config.yaml point to your Mosquitto Broker or the Arduino-Ethernet Shield? If it points to the Arduino afaik the point of the MQTTCLIENT Gateway is that it can be run as a client if you've already got a Mosquitto broker. Otherwise you would either need to remove mosquitto or forward it to a different port than the default 1883. If this was the case then HASS would be looking for a broker where none exists which is why it is missing configuration items...
        D 1 Reply Last reply
        • H
          H
          humblehacker
          For the time being, I'm thinking of taking a different approach with my toggle switch... I'm thinking of simply defining the button output as a binary sensor which can then toggle between two predefined scenes. At least in my case, input only needs to go in one direction so there's no need to receive any data from the controller....
          • H humblehacker
            martinhjelmareM
            martinhjelmareM
            martinhjelmare
            @humblehacker
            FYI, my fifo_queue pull request has been merged with dev branch at pymysensors, so I'm hoping to be able to implement switch support for the mysensors component in homeassistant very soon.
            H 1 Reply Last reply
              @humblehacker
              H
              H
              humblehacker
              @martinhjelmare said:
              @humblehacker
              Thats great news! That should be a huge help with my plans for building an RGB Lighting controller based on the rotary_led_dimmer sketch! If I can ever figure out how to implement a simple toggle switch first...
              • H humblehacker
                mqtt 1:
                  port: 1883
                  keepalive: 60
                D
                D
                drock1985
                @humblehacker said:
                k
                mqtt 1:
                  port: 1883
                  keepalive: 60
                @humblehacker
                The configuration.yaml file I have pointed back to the local IP address, since Mosquitto and Home-Assistant are running on the same Pi.
                So, you are saying that it should really be pointed back to the MQTT Gateway then? Still confusing to me.
                My Projects
                2 Door Chime Sensor
                • H
                  H
                  humblehacker
                  Never mind then... As long as your using Mosquitto as your broker and the MQTT CLIENT Gateway (from the development branch) rather than the default MQTT Gateway sketch from- http://www.mysensors.org/build/mqtt_gateway then none of my earlier comments should apply... Basically I was saying that the default MYSensors MQTT Gateway is set up to function as a broker and would therefore conflict with any Mosquitto server running on the same port. The MQTT CLIENT Gateway (emphasis on CLIENT) from the development branch isnt set up as a broker so it shouldnt conflict with a Mosquitto installation.
                  • martinhjelmareM
                    martinhjelmareM
                    martinhjelmare
                    It's still important to be wary about which ip address you assign where, so I think it was a good point.
                    • D
                      D
                      drock1985
                      Well, I have Mosquitto and the Dev ClientMQTTESP gateway working, and is communicating fine. Now just trying to figure out the proper entry to add an item as.
                      My Projects
                      2 Door Chime Sensor
                      • D
                        D
                        drock1985
                        Ok, just got it all setup and working great now. Time to see how relays will work......
                        My Projects
                        2 Door Chime Sensor
                        • D
                          D
                          drock1985
                          Hey @martinhjelmare , I see HA was updated today; did your commits get added?
                          My Projects
                          2 Door Chime Sensor
                          • D drock1985
                            martinhjelmareM
                            martinhjelmareM
                            martinhjelmare
                            @drock1985
                            Hi!
                            No, I've submitted a pull request, but I need to fix some things, and maybe change some of it. But hopefully it wont take too long.
                            • MufasaM
                              MufasaM
                              Mufasa
                              I have been trying to set up a switch in home assistant but I have had no luck in getting it to show up in the dashboard. I am using @martinhjelmare mysensors-component-switch branch of home assistant and the following sketch. Does anyone have any idea why this is happening? ```
                               * Version 1.0 - Henrik Ekblad
                              #include <MySigningNone.h>
                              #include <MyTransportNRF24.h>
                              #include <MyTransportRFM69.h>
                              #include <MyHwATMega328.h>
                              //MyTransportRFM69 radio;
                              //MySigningNone signer;
                              MyHwATMega328 hw;
                              MySensor gw(radio, hw);
                              MyMessage lightMsg(RELAY_1, S_LIGHT);
                                gw.sendSketchInfo("Relay", "1.0");
                                // Fetch relay status
                                  gw.present(sensor, S_LIGHT);
                                  pinMode(pin, OUTPUT);
                                  digitalWrite(pin, gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
                                gw.send(lightMsg.set("0"));
                                gw.process();
                                if (message.type==V_LIGHT) {
                                   // Change relay state
                                   // Store state in eeprom
                                   // Write some debug info
                                   Serial.print(message.sensor);
                              • MufasaM Mufasa
                                MyHwATMega328 hw;
                                  gw.process();
                                martinhjelmareM
                                martinhjelmareM
                                martinhjelmare
                                @Mufasa
                                Hi!
                                First of all my branch is still under development, and right now I think there is a bug, which could make it unable to install. I'll have more time to fix things next week.
                                How does your home assistant config for mysensors look like?
                                Have you looked at the logs of home assistant after start?
                                • MufasaM
                                  MufasaM
                                  Mufasa
                                  @martinhjelmare
                                  Hey Martin, this is my config for the mysensors component
                                  mysensors:
                                    gateways:
                                      port: '/dev/ttyUSB0'
                                      persistance_file: '/home/pi/.homeassistant/mysensors.json'
                                    debug: true
                                    persistance: true
                                    version: '1.5'
                                  sensor:
                                    platform: mysensors
                                  switch:
                                    platform: mysensors
                                  Here is the log after start
                                  (hass-test)pi@raspberrypi:~/.homeassistant $ hass
                                  Config directory: /home/pi/.homeassistant
                                  WARNING:homeassistant.bootstrap:Colorlog package not found, console coloring disabled
                                  INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=turn_off, domain=homea
                                  ssistant>
                                  INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=turn_on, domain=homeas
                                  sistant>
                                  INFO:homeassistant.bootstrap:Home Assistant core initialized
                                  INFO:homeassistant.loader:Loaded switch from homeassistant.components.switch
                                  INFO:homeassistant.loader:Loaded discovery from homeassistant.components.discovery
                                  INFO:homeassistant.loader:Loaded conversation from homeassistant.components.conversation
                                  INFO:homeassistant.loader:Loaded sensor from homeassistant.components.sensor
                                  INFO:homeassistant.loader:Loaded history from homeassistant.components.history
                                  INFO:homeassistant.loader:Loaded recorder from homeassistant.components.recorder
                                  INFO:homeassistant.loader:Loaded http from homeassistant.components.http
                                  INFO:homeassistant.loader:Loaded logbook from homeassistant.components.logbook
                                  INFO:homeassistant.loader:Loaded sun from homeassistant.components.sun
                                  INFO:homeassistant.loader:Loaded mysensors from homeassistant.components.mysensors
                                  INFO:homeassistant.loader:Loaded frontend from homeassistant.components.frontend
                                  INFO:homeassistant.loader:Loaded api from homeassistant.components.api
                                  INFO:homeassistant.loader:Loaded updater from homeassistant.components.updater
                                  INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=recorder>
                                  INFO:homeassistant.loader:Loaded switch.mysensors from homeassistant.components.switch.mysensors
                                  INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=turn_off, domain=switc
                                  h>
                                  INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=turn_on, domain=switch
                                  INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=switch>
                                  INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=discovery>
                                  /home/pi/.homeassistant/lib/fuzzywuzzy/fuzz.py:33: UserWarning: Using slow pure-python SequenceMa
                                  tcher. Install python-Levenshtein to remove this warning
                                    warnings.warn('Using slow pure-python SequenceMatcher. Install python-Levenshtein to remove thi
                                  s warning')
                                  INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=process, domain=conver
                                  sation>
                                  INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=conversation>
                                  INFO:homeassistant.loader:Loaded sensor.mysensors from homeassistant.components.sensor.mysensors
                                  INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=sensor>
                                  INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=http>
                                  INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=history>
                                  INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=logbook>
                                  INFO:urllib3.connectionpool:Starting new HTTP connection (1): maps.googleapis.com
                                  INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state sun.sun=above_hori
                                  zon; friendly_name=Sun, next_rising=03:32:34 08-01-2016, next_setting=15:36:03 07-01-2016, elevat
                                  ion=47.84 @ 14:58:04 07-01-2016>, entity_id=sun.sun>
                                  INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=sun>
                                  INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=mysensors.sensors, di
                                  scovered=>
                                  INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=mysensors.switches, d
                                  iscovered=>
                                  INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=mysensors>
                                  INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=api>
                                  INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=frontend>
                                  INFO:urllib3.connectionpool:Starting new HTTPS connection (1): pypi.python.org
                                  INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state updater.updater=0.
                                  10.1; friendly_name=Update Available @ 14:58:06 07-01-2016>, entity_id=updater.updater>
                                  INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=updater>
                                  INFO:homeassistant.core:Starting Home Assistant (15 threads)
                                  INFO:homeassistant.core:Bus:Handling <Event homeassistant_start[L]>
                                  INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=stop, domain=homeassis
                                  tant>
                                  INFO:mysensors.mysensors:Trying to connect to /dev/ttyUSB0
                                  INFO:homeassistant.core:Timer:starting
                                  INFO:homeassistant.components.mysensors:update persistence: node 1
                                  INFO:homeassistant.components.http:Starting web interface at http://0.0.0.0:8123
                                  INFO:netdisco.service:Scanning
                                  INFO:mysensors.mysensors:/dev/ttyUSB0 is open...
                                  INFO:mysensors.mysensors:Connected to /dev/ttyUSB0
                                  INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:gateway started, id=0, parent=0, distance=0
                                  INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=255,c=0,t=18,pt=0,l=5,sg=0:1.5.1
                                  INFO:homeassistant.components.mysensors:update sensor_update: node 1
                                  INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                                  INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:send: 0-0-1-1 s=255,c=3,t=6,pt=0,l=1,sg=0,st=ok:M
                                  INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=255,c=3,t=11,pt=0,l=5,sg=0:Relay
                                  INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
                                  INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=1,c=0,t=3,pt=0,l=0,sg=0:
                                  INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=3,c=1,t=3,pt=0,l=1,sg=0:0
                                  INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.1.1
                                  ion=47.76 @ 14:58:04 07-01-2016>, old_state=<state sun.sun=above_horizon; friendly_name=Sun, next
                                  _rising=03:32:34 08-01-2016, next_setting=15:36:03 07-01-2016, elevation=47.84 @ 14:58:04 07-01-2
                                  martinhjelmareM 2 Replies Last reply
                                  • MufasaM Mufasa
                                    @martinhjelmare
                                    mysensors:
                                      gateways:
                                      debug: true
                                      persistance: true
                                      version: '1.5'
                                    sensor:
                                      platform: mysensors
                                    switch:
                                      platform: mysensors
                                    ssistant>
                                    sistant>
                                    h>
                                    s warning')
                                    sation>
                                    scovered=>
                                    iscovered=>
                                    tant>
                                    martinhjelmareM
                                    martinhjelmareM
                                    martinhjelmare
                                    #57
                                    @Mufasa
                                    The error is in your sketch. When you declare your message you should use child sensor id as first argument. Now you're using the pin number. So then you're sending the value from a child which hasn't been presented to home assistant.
                                    MyMessage msg(child-sensor-id, variable-type);
                                    • MufasaM Mufasa
                                      @martinhjelmare
                                      mysensors:
                                        gateways:
                                        debug: true
                                        persistance: true
                                        version: '1.5'
                                      sensor:
                                        platform: mysensors
                                      switch:
                                        platform: mysensors
                                      ssistant>
                                      sistant>
                                      h>
                                      s warning')
                                      sation>
                                      scovered=>
                                      iscovered=>
                                      tant>
                                      martinhjelmareM
                                      martinhjelmareM
                                      martinhjelmare
                                      @Mufasa
                                      Btw, you can remove sensor/switch platform mysensors in your config, if using the latest version of my branch.
                                      Everything else looks good in the config and the log, what I can tell.
                                      • MufasaM
                                        MufasaM
                                        Mufasa
                                        @martinhjelmare
                                        OK I have tried this but I'm am still having no luck, thank you for the quick replies.
                                          gw.begin(incomingMessage, 1, true);
                                            MyMessage lightMsg(sensor, S_LIGHT);
                                        • MufasaM
                                          MufasaM
                                          Mufasa
                                          @martinhjelmare
                                          Here is the part of the log
                                          INFO:urllib3.connectionpool:Starting new HTTPS connection (1): 192.168.1.29
                                          INFO:homeassistant.components.mysensors:No sketch_name: node 1
                                          INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=1,c=1,t=2,pt=0,l=1,sg=0:0
