  3. Attempt to combine three sketches failed.
4 Posts 3 Posters 1.6k Views 4 Watching
  • Cliff KarlssonC
    Cliff KarlssonC
    Cliff Karlsson
    I tried to merge BinarySwitchSleepSensor, Dallas temperature and batterymonitoring sketches into one but as predicted it ended in failure. Could someone look at the mess and correct me?
    This where I get an error:
      present(SECONDARY_CHILD_ID, S_TEMP);
    exit status 1
    expected constructor, destructor, or type conversion before '(' token
     * Interrupt driven binary switch example with dual interrupts
     * Author: Patrick 'Anticimex' Fallberg
     * Connect one button or door/window reed switch between
     * digitial I/O pin 3 (BUTTON_PIN below) and GND and the other
     * one in similar fashion on digital I/O pin 2.
     * This example is designed to fit Arduino Nano/Pro Mini
    #include <OneWire.h>
    #define SKETCH_NAME "Binary Sensor+temp"
    #define SKETCH_MAJOR_VER "1"
    #define SKETCH_MINOR_VER "0"
    #define PRIMARY_CHILD_ID 3
    #define SECONDARY_CHILD_ID 4
    #define PRIMARY_BUTTON_PIN 3   // Arduino Digital I/O pin for button/reed switch
    //#define SECONDARY_BUTTON_PIN 7 // Arduino Digital I/O pin for button/reed switch
    int numSensors=0;
    boolean metric = true;
    #if (PRIMARY_BUTTON_PIN < 2 || PRIMARY_BUTTON_PIN > 3)
    #error PRIMARY_BUTTON_PIN must be either 2 or 3 for interrupts to work
    //#if (SECONDARY_BUTTON_PIN < 2 || SECONDARY_BUTTON_PIN > 3)
    //#error SECONDARY_BUTTON_PIN must be either 2 or 3 for interrupts to work
    //#endif
    #if (PRIMARY_BUTTON_PIN == SECONDARY_BUTTON_PIN)
    #error PRIMARY_BUTTON_PIN and BUTTON_PIN2 cannot be the same
    #if (PRIMARY_CHILD_ID == SECONDARY_CHILD_ID)
    #error PRIMARY_CHILD_ID and SECONDARY_CHILD_ID cannot be the same
    MyMessage msg(PRIMARY_CHILD_ID, V_LIGHT);
    MyMessage msg2(SECONDARY_CHILD_ID, V_TEMP);
    unsigned long SLEEP_TIME = 600000;  // sleep time between reads (seconds * 1000 milliseconds)
    int oldBatteryPcnt = 0;
      sensors.begin();
       analogReference(INTERNAL1V1);
    #else
       analogReference(INTERNAL);
      // Setup the buttons
      pinMode(PRIMARY_BUTTON_PIN, INPUT);
     // pinMode(SECONDARY_BUTTON_PIN, INPUT);
      // Activate internal pull-ups
      digitalWrite(PRIMARY_BUTTON_PIN, HIGH);
     // digitalWrite(SECONDARY_BUTTON_PIN, HIGH);
    void presentation() {
      sendSketchInfo(SKETCH_NAME, SKETCH_MAJOR_VER "." SKETCH_MINOR_VER);
      // Register binary input sensor to sensor_node (they will be created as child devices)
    //numSensors = sensors.getDeviceCount();
      //for (int i=0; i<numSensors && i<MAX_ATTACHED_DS18B20; i++) {
      present(PRIMARY_CHILD_ID, S_LIGHT);
      uint8_t value;
      static uint8_t sentValue=2;
      static uint8_t sentValue2=2;
      sleep(5);
      value = digitalRead(PRIMARY_BUTTON_PIN);
      if (value != sentValue) {
         // Value has changed from last transmission, send the updated value
         send(msg.set(value==HIGH ? 1 : 0));
         sentValue = value;
    //  value = digitalRead(SECONDARY_BUTTON_PIN);
    //  if (value != sentValue2) {
    //     // Value has changed from last transmission, send the updated value
    //     send(msg2.set(value==HIGH ? 1 : 0));
    //     sentValue2 = value;
      sleep(conversionTime);
        float temperature = static_cast<float>(static_cast<int>((getConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
        #if COMPARE_TEMP == 1
        #else
          send(msg.setSensor(i).set(temperature,1));
    // get the battery Voltage
       #ifdef DEBUG
       Serial.println(sensorValue);
       #ifdef DEBUG
       float batteryV  = sensorValue * 0.003363075;
       Serial.print(batteryV);
       Serial.println(" V");
       Serial.print(batteryPcnt);
       Serial.println(" %");
         // Power up radio after sleep
         oldBatteryPcnt = batteryPcnt;
      // Sleep until something happens with the sensor
      sleep(PRIMARY_BUTTON_PIN-2, CHANGE, SLEEP_TIME);
    DidiD 1 Reply Last reply
      exit status 1
      int numSensors=0;
      //#endif
        sensors.begin();
      #else
        uint8_t value;
        sleep(5);
           sentValue = value;
          #else
         #ifdef DEBUG
         #ifdef DEBUG
      DidiD
      DidiD
      Didi
      This post is deleted!
        Remove the } before present(PRIMARY_CHILD_ID, S_LIGHT);
        } denotes end of the presentation function, but you haven't finished the presentation function yet.
          Pro tip1: the error is often a line before the line that the compiler complains about. So don't always focus on the highlighted line :)
          Pro tip2: Use Tools->Auto Format in the Arduino IDE to make the code more readable. In this case, auto format would probably have made the error more visible because the could would have looked like this after auto-format:
          int numSensors = 0;
          //#endif
            sensors.begin();
          #else
            uint8_t value;
            static uint8_t sentValue = 2;
            static uint8_t sentValue2 = 2;
            sleep(5);
              send(msg.set(value == HIGH ? 1 : 0));
              sentValue = value;
            for (int i = 0; i < numSensors && i < MAX_ATTACHED_DS18B20; i++) {
              float temperature = static_cast<float>(static_cast<int>((getConfig().isMetric ? sensors.getTempCByIndex(i) : sensors.getTempFByIndex(i)) * 10.)) / 10.;
          #else
                send(msg.setSensor(i).set(temperature, 1));
                lastTemperature[i] = temperature;
          #ifdef DEBUG
          #ifdef DEBUG
            sleep(PRIMARY_BUTTON_PIN - 2, CHANGE, SLEEP_TIME);
