  3. Step-by-step procedure to connect the NRF24L01+ to the GPIO pins and use the Raspberry as a Serial Gateway (MySensors 1.x)
nrf24raspberry piraspberryraspberry nrf24l01 gpiogateway
168 Posts 47 Posters 212.7k Views 36 Watching
  • F flopp
    @mfalkvidd said:
    OTHER NOTES
    • The 3.3V power on the Raspberry Pi is rated for a maximum of 50mA. A regular NRF24L01+ only needs 15mA, but if you are using a power amplified version you might exceed what the Raspberry Pi can output. In that case, an external power supply might be required.
    Nice guide thanks.
    when using external power supply i think it is best to connect Ground from Rpi and ext power supply. Maybe write that in the guide?
    alexsh1A
    alexsh1A
    alexsh1
    @flopp the best would be to use Raspberry's 5V rail and reduce it to 3.3V via the LDO like @GertSanders did in his board.
    There is one member using 3.3V rail for powering PA+LNA Tranceiver without any issues - check out the latest open hardware. I have not tried it personally
    • alexsh1A alexsh1
      @alexsh1 I wouldn't want a guide to recommend a solution that is way outside the specifications even if users might not experience problems. Strange problems usually happen outside specs, they are a pain to troubleshoot and in this case might lead to frying someone's Raspberry Pi.
      @flopp thanks for your suggestion, I've amended to guide.
        Note: This guide is only applicable to MySensors 1.x. For MySensors 2, use this guide.
        I noticed that a step-by-step procedure to connect the NRF24L01 to the GPIO pins and use the Raspberry as a Serial Gateway was listed in the document for MySensors 1.6.
        Since I have three gateways configured this way, and I need to set up 3 more for covering different offices around the world, and I had already written the instructions in Swedish for Datormagazin, I thought I'd help out.
        This is the first draft. Any feedback is welcome.
        INTRODUCTION
        The radio module NRF24L01+ is cheap and power efficient, but it is unable to communicate with regular wifi. The bridge between NRF24L01+ nodes and the "computer world" is called a Gateway. You can use other types of gateways, but connecting the NRF24L01+ module directly to the Raspberry Pi is a simple and cheap alternative.
        Wiring Things Up
        Connect the NRF20L01+ radio module to the Raspberry Pi like this:
        Raspberry Pi NRF24L01+ Color
        6 / GND GND Black
        1 / 3.3V DC VCC Red
        22 / GPIO25 CE Orange
        24 / GPIO 8 CSN/CS Yellow
        23 / GPIO11 / SPI_CLK SCK Green
        19 / GPIO10 / SPI_MOSI MOSI Blue
        21 / GPIO9 / SPI_MISO MISO Violet
        The IRQ pin on NRF24L01 is not currently used.
        For a comprehensive view of the Raspberry Pi pins, see http://pinout.xyz/
        You should also connect a decoupling capacitor to the radio. See this guide.
        COMPILING THE GATEWAY
        Login to your Raspberry Pi (using SSH or open a terminal on the graphical console) and run these commands:
        git clone https://github.com/TMRh20/RF24.git
        cd RF24
        make all && sudo make install
        cd ..
        git clone https://github.com/mysensors/Raspberry.git
        cd Raspberry
        If you get the following error:
        pi@raspberrypi ~/RF24 $ make all && sudo make install
        g++ -Wall -fPIC -Ofast -mfpu=vfp -mfloat-abi=hard -mtune=arm1176jzf-s -march=armv7-a -D BCM2835_PERI_BASE=0x -c RF24.cpp
        gcc -Wall -fPIC -Ofast -mfpu=vfp -mfloat-abi=hard -mtune=arm1176jzf-s -march=armv7-a -D BCM2835_PERI_BASE=0x -c bcm2835.c
        bcm2835.c: In function ‘bcm2835_init’:
        bcm2835.c:1207:28: error: invalid suffix "x" on integer constant
        You've probably run into the problem discussed in this thread. People have had luck with different solutions. The simplest is to make the following change to ~/Raspberry/librf24-bcm/Makefile
        #IOBASE := $(shell cat /proc/iomem | grep bcm2708_vcio | cut -f 1 -d "-")
        IOBASE := 3F000000
        VERIFY THE GATEWAY
        Run sudo /usr/local/sbin/PiGatewaySerial. The output should look like this:
        pi@raspberrypi ~/Raspberry $ sudo /usr/local/sbin/PiGatewaySerial
        Starting PiGatewaySerial...
        Protocol version - 1.4
        Created PTY '/dev/pts/1'
        Gateway tty: /dev/ttyMySensorsGateway
        ================ SPI Configuration ================
        CSN Pin          = CE0 (PI Hardware Driven)
        CE Pin           = Custom GPIO25
        Clock Speed      = 8 Mhz
        ================ NRF Configuration ================
        STATUS           = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
        RX_ADDR_P0-1     = 0xe7e7e7e7e7 0xc2c2c2c2c2
        RX_ADDR_P2-5     = 0xff 0xc4 0xc5 0xc6
        TX_ADDR          = 0xe7e7e7e7e7
        RX_PW_P0-6       = 0x00 0x00 0x20 0x00 0x00 0x00
        EN_AA            = 0x3b
        EN_RXADDR        = 0x07
        RF_CH            = 0x4c
        RF_SETUP         = 0x23
        CONFIG           = 0x0e
        DYNPD/FEATURE    = 0x3f 0x06
        Data Rate        = 250KBPS
        Model            = nRF24L01+
        CRC Length       = 16 bits
        PA Power         = PA_LOW
        If the NRF24L01+ isn't correctly wired, the following error will be shown
        pi@raspberrypi ~ $ sudo /usr/local/sbin/PiGatewaySerial
        Created PTY '/dev/pts/2'
        check wires
        If this happens, double-check your wiring and correct any problems. Press Ctrl+Z and type
        sudo killall PiGatewaySerial
        to get rid of the non-functioning Gateway. Then run sudo /usr/local/sbin/PiGatewaySerial again
        If all is well, exit PiGatewaySerial by pressing Ctrl+C. Then run
        sudo /etc/init.d/PiGatewaySerial start
        to start the gateway as a background process. Verify that it started correctly by running
        sudo cat /dev/ttyMySensorsGateway
        You should see the message "Gateway startup complete". Exit by typing Ctrl+C.
        MAKE THE GATEWAY AUTOSTART
        To make sure the Gateway is started when your Raspberry Pi boots up, run the following command:
        sudo make enable-gwserial
        Enable the gateway for use with Domoticz
        Domoticz (and maybe other home automation systems) has trouble reading from the default path created by PiGatewaySerial. You might need to run the following command:
        sudo ln -s /dev/ttyMySensorsGateway /dev/ttyUSB20
        And change /etc/rc.local from this
        exit 0
        to this
        exit 0
        OTHER NOTES
        • The 3.3V power on the Raspberry Pi is rated for a maximum of 50mA. A regular NRF24L01+ only needs 15mA, but if you are using a power amplified version you might exceed what the Raspberry Pi can output. In that case, an external power supply might be required. If you use an external power source gnd must be connected to the Raspberry Pi's gnd.
        • Connecting the NRF24L01+ directly to your Raspberry Pi will prevent you from using the Raspberry Pi's gpio ports for other things, like a Z-wave board.
        • A user experienced slow data transfer compared to USB-to-Serial(ttl)<-->MySensors Gateway connection, especially on OTA firmware update. If you think this will cause a problem for you, an ethernet gateway might be a better alternative.
        As always, I stand on the shoulders of giants. Related posts:
        • http://forum.mysensors.org/topic/1151/tutorial-raspberry-pi-nrf24l01-direct-connection
        • http://forum.mysensors.org/topic/1974/domoticz-as-controller-and-a-gateway-for-mysensor-nodes-running-on-a-raspberry-pi-2
        TROUBLESHOOTING
        If you get this error
        pi@Domoticz3:~/Raspberry$ sudo /etc/init.d/PiGatewaySerial start
        [....] Starting PiGatewaySerial (via systemctl): PiGatewaySerial.serviceFailed to start PiGatewaySerial.service: Unit PiGatewaySerial.service failed to load: No such file or directory.
         failed!
        or this error
        sudo: /usr/local/sbin/PiGatewaySerial: command not found
        you have probably forgotten to run sudo make install. Read the instructions again, and follow them this time :-) User @sineverba reported that a reboot of the Pi after running make install helped.
        SeanMarshS
        SeanMarshS
        SeanMarsh
        @mfalkvidd I"m confused. I noticed the instructions below is for 1.5X or below and will not work with 2.0. The link for 2.0 that is posted doesn't make any sense to me at all. It also takes me to a thread where I start reading the information from the middle of a thread. I'm coming to the conclusion that it doesn't work yet..... Am I right?
        SUPER New here. sorry
        • SeanMarshS SeanMarsh
          @SeanMarsh I don't know anything more than what's stated in that thread, sorry. That's also why it is the last option of the alternatives. Go with a serial, wifi or ethernet gateway if you can.
          • tlpeterT
            tlpeterT
            tlpeter
            I also have a serial gateway next to my raspberry (3 in this case) with Domoticz on it.
            If there is an issue than at least a part is still running without breaking everything.
            I am using zwave at most and mysensors now for playing.
            I cannot break the current zwave implementation so for me a serial gateway is the best solution.
            For playing around you might just try as i imaging it could be fun to do it.
            • W
              W
              wergeld
              How can we update the gateway to v1.5? I just tried to rebuild from github today and I am getting really odd errors now that I did not get before:
              cc1: error: bad value (cortex-a7)
              What I could find online states I need to update the gcc compiler on my rPi - it is currently version 4 and latest is 5...but apt-get update gcc says I am already at latest version.
              I am trying to get my slimNodes up and running using v1.5 of mysensors.
              • T
                Toyman
                wrote on last edited by Toyman
                #147
                How can I use "PA power HIGH" with this setup?
                • R
                  R
                  Reza
                  i can not add device to domoticz controller with serial gateway(1.4)
                  MySensors Gateway USB
                  Version: 1.4 Setup
                  • R
                    R
                    Reza
                    is this true ?
                    pi@raspberrypi:~$ sudo make enable-gwserial
                    make: *** No rule to make target 'enable-gwserial'.  Stop.
                    T 1 Reply Last reply
                    • R Reza
                      is this true ?
                      Toyman
                      @Reza try:
                      cd Raspberry
                      R 1 Reply Last reply
                      • T Toyman
                        @Reza try:
                        cd Raspberry
                        R
                        R
                        Reza
                        @Toyman
                        thank you
                        • R
                          R
                          Reza
                          in domoticz i have this problem :
                          pi@raspberrypi:~$ sudo cat /dev/ttyMySensorsGateway
                          cat: /dev/ttyMySensorsGateway: No such file or directory
                          • rmtuckerR
                            rmtuckerR
                            rmtucker
                            How do I remove all that I have installed at the top of this thread so I can revert back to an arduino serial gateway?
                            • rmtuckerR rmtucker
                              #154
                              @rmtucker run "sudo make uninstall" when standing in the Raspberry folder
                              rmtuckerR 1 Reply Last reply
                                rmtuckerR
                                rmtuckerR
                                rmtucker
                                @mfalkvidd do you mean the root directory?
                                I have had this running for a number of months but I want to go back to the arduino serial setup without losing my domoticz controller or data.
                                  @rmtucker I mean the folder containing the files from the git repo.
                                  • T
                                    Toyman
                                    Is there a way to manually type messages to the nodes?
                                    • _Rooky__
                                      _Rooky__
                                      _Rooky_
                                      maybe someone could give me a hint. I installed everything and it looks like it is working, but no sensors are displayed in Domoticz. Any idea what's wrong?
                                      I used this sensor before with a ESP Wifi gateway and it was working fine. The DallasTemp Sensors got visible in Domoticz right after the gateway was added in the Hardware section.
                                      After installing the NRF24l01 on the Rasperry Pi 3 and follwing the instructions above, I added MySensorsGateway USB with /dev/ttyUSB20, but nothing happend.
                                      Would be nice, if I could get this smart thing working. Else I would need to go back to the ESP Wifi gateway.
                                      Domoticz log:
                                      2016-12-30 00:31:01.610 Domoticz V3.5877 (c)2012-2016 GizMoCuz
                                      2016-12-30 00:31:01.611 Build Hash: 15b013c, Date: 2016-11-10 16:44:33
                                      2016-12-30 00:31:01.611 System: Raspberry Pi
                                      2016-12-30 00:31:01.611 Startup Path: /home/pi/domoticz/
                                      2016-12-30 00:31:02.327 Sunrise: 08:18:00 SunSet:15:59:00
                                      2016-12-30 00:31:02.327 EventSystem: reset all events...
                                      2016-12-30 00:31:02.411 Active notification subsystems: (0/12)
                                      2016-12-30 00:31:02.448 WebServer(HTTP) started on address: :: with port 8080
                                      2016-12-30 00:31:02.479 WebServer(SSL) started on address: :: with port 443
                                      2016-12-30 00:31:02.481 Proxymanager started.
                                      2016-12-30 00:31:02.516 Starting shared server on: :::6144
                                      2016-12-30 00:31:02.516 TCPServer: shared server started...
                                      2016-12-30 00:31:02.517 RxQueue: queue worker started...
                                      2016-12-30 00:31:04.520 EventSystem: reset all events...
                                      2016-12-30 00:31:04.520 EventSystem: reset all device statuses...
                                      2016-12-30 00:31:04.521 EventSystem: Started
                                      2016-12-30 00:31:05.519 MySensors: Using serial port: /dev/ttyUSB20
                                      2016-12-30 00:33:06.145 Incoming connection from: 127.0.0.1
                                      pi@raspberrypi:~ $ sudo /usr/local/sbin/PiGatewaySerial
                                      Clock Speed = 8 Mhz
                                      RX_ADDR_P0-1 = 0xa8a8e1fc02 0xa8a8e1fc00
                                      TX_ADDR = 0xa8a8e1fc02
                                      RX_PW_P0-6 = 0x20 0x20 0x20 0x00 0x00 0x00
                                      EN_AA = 0x3b
                                      EN_RXADDR = 0x06
                                      RF_CH = 0x4c
                                      RF_SETUP = 0x23
                                      CONFIG = 0x0e
                                      Data Rate = 250KBPS
                                      Model = nRF24L01+
                                      PA Power = PA_LOW
                                      read: 2-2-0 s=255,c=3,t=24,pt=1,l=1:1
                                      read: 2-2-255 s=255,c=3,t=7,pt=0,l=0:
                                      send: 0-0-2-2 s=255,c=3,t=8,pt=1,l=1,st=ok:0
                                      pi@raspberrypi:~ $ sudo cat /dev/ttyMySensorsGateway
                                      2;255;3;0;24;1
                                      2;255;3;0;24;1
                                      2;255;3;0;24;1
                                      2;255;3;0;24;1
                                      2;255;3;0;24;1
                                      1;255;3;0;24;1
                                      2;255;3;0;24;1
                                      1;255;3;0;24;1
                                      2;255;3;0;24;1
                                      1;255;3;0;24;1
                                      2;255;3;0;24;1
                                      1;255;3;0;24;1
                                      2;255;3;0;24;1
                                      2;255;3;0;24;1
                                      2;255;3;0;24;1
                                      Traces from sensor node:
                                      TSM:INIT
                                      TSM:RADIO:OK
                                      TSP:ASSIGNID:OK (ID=2)
                                      TSM:FPAR
                                      TSP:MSG:SEND 2-2-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                                      TSP:MSG:READ 0-0-2 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                      TSP:MSG:PAR OK (ID=0, dist=1)
                                      TSM:FPAR:OK
                                      TSM:ID
                                      TSM:CHKID:OK (ID=2)
                                      TSM:UPL
                                      TSP:PING:SEND (dest=0)
                                      TSP:MSG:SEND 2-2-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
                                      TSP:CHKUPL:FAIL (hops=255)
                                      !TSM:UPL:FAIL
                                      TSM:FPAR
                                      TSM:FPAR
                                      TSM:FPAR:OK
                                      TSM:ID
                                      TSM:CHKID:OK (ID=2)
                                      TSM:UPL
                                      !TSM:UPL:FAIL
                                      TSM:FPAR
                                      TSM:FPAR:OK
                                      TSM:ID
                                      TSM:CHKID:OK (ID=2)
                                      TSM:UPL
                                      !TSM:UPL:FAIL
                                      TSM:FPAR
                                      TSM:FPAR:OK
                                      TSM:ID
                                      TSM:CHKID:OK (ID=2)
                                      TSM:UPL
                                      !TSM:UPL:FAIL
                                      • _Rooky__ _Rooky_
                                        Domoticz log:
                                        Clock Speed = 8 Mhz
                                        EN_AA = 0x3b
                                        EN_RXADDR = 0x06
                                        RF_CH = 0x4c
                                        RF_SETUP = 0x23
                                        CONFIG = 0x0e
                                        Data Rate = 250KBPS
                                        Model = nRF24L01+
                                        PA Power = PA_LOW
                                        2;255;3;0;24;1
                                        2;255;3;0;24;1
                                        2;255;3;0;24;1
                                        2;255;3;0;24;1
                                        2;255;3;0;24;1
                                        1;255;3;0;24;1
                                        2;255;3;0;24;1
                                        1;255;3;0;24;1
                                        2;255;3;0;24;1
                                        1;255;3;0;24;1
                                        2;255;3;0;24;1
                                        1;255;3;0;24;1
                                        2;255;3;0;24;1
                                        2;255;3;0;24;1
                                        2;255;3;0;24;1
                                        TSM:INIT
                                        TSM:RADIO:OK
                                        TSM:FPAR
                                        TSM:FPAR:OK
                                        TSM:ID
                                        TSM:CHKID:OK (ID=2)
                                        TSM:UPL
                                        !TSM:UPL:FAIL
                                        TSM:FPAR
                                        TSM:FPAR
                                        TSM:FPAR:OK
                                        TSM:ID
                                        TSM:CHKID:OK (ID=2)
                                        TSM:UPL
                                        !TSM:UPL:FAIL
                                        TSM:FPAR
                                        TSM:FPAR:OK
                                        TSM:ID
                                        TSM:CHKID:OK (ID=2)
                                        TSM:UPL
                                        !TSM:UPL:FAIL
                                        TSM:FPAR
                                        TSM:FPAR:OK
                                        TSM:ID
                                        TSM:CHKID:OK (ID=2)
                                        TSM:UPL
                                        !TSM:UPL:FAIL
                                        @_Rooky_ congratulations on your first post in the forum, welcome!
                                        The gateway uses MySensors 1.4 and the node uses version 2. These versions are not compatible.
                                        You probably want to use version 2 for the gateway as well. https://www.mysensors.org/build/raspberry describes how to create a gateway for version 2 (the gateway was completely rewritten for version 2)
                                        _Rooky__ 1 Reply Last reply
                                          _Rooky__
                                          _Rooky__
                                          _Rooky_
                                          @mfalkvidd many thanks for the very quick and polite reply.
                                          It is working now and this solution is much better way, than using an additional ESP as gateway.
                                          Even though I got on the wrong lane, I learned more details from your excellent guide, than from the "make", "make install" from the MySensors page ... and still got a lot to learn
