  3. RFID Garage door opener
47 Posts 23 Posters 42.7k Views 26 Watching
  • codergirl56C codergirl56
    @BartE thanks for getting back to me. I've looked through the examples on the MFRC522 library. I think the main thing I'm struggling with is setting up and initializing the N24L01 module and the RFID on the same arduino uno. My plan is to have one N24L01 and RFID on one arduino module, and a second N24L01 on a second arduino. I want the RFID to read the UID off of PICC cards and be able to wirelessly transmit the UID between the N24L01 modules. I think it's simpler than the code you have written here, but I'm struggling to simplify the code you have to only what I need. Could you possibly walk through what each function in your program is used for? Thanks in advance.
    BartEB
    BartEB
    BartE
    @codergirl56 Oke i will give it a try:
    Basic IO pin set up
            Serial.begin(BAUD);     // Initialize serial communications with the PC
            pinMode(GARAGEPIN, OUTPUT);     // Initialise in/output ports
            pinMode(SECONDRELAY, OUTPUT);     // Initialise in/output ports
    This part initializes the SPI I/O pins used by the RFID reader so it release the SPI bus for thr NFR radio
            // Make sure MFRC will be disabled on the SPI bus
            pinMode(RST_PIN, OUTPUT);
            digitalWrite(RST_PIN, LOW);
            pinMode(SS_PIN, OUTPUT);
            digitalWrite(SS_PIN, LOW);
    Init LED and button I/O-pin
            pinMode(LED_PIN, OUTPUT);
            digitalWrite(LED_PIN, LOW);
            // Setup the button
            pinMode(SWITCH_PIN, INPUT_PULLUP);
            debouncer.attach(SWITCH_PIN);
            debouncer.interval(5);
    Init radion module
            // Init mysensors library
            gw.begin(incomingMessage, 5);
            gw.sendSketchInfo("RFID Garage", "1.2"); delay(RF_INIT_DELAY);
            gw.present(CHILD_ID_LOCK, S_LOCK);      delay(RF_INIT_DELAY);
            gw.present(CHILD_ID_LOCK2, S_LOCK);      delay(RF_INIT_DELAY);
            gw.present(CHILD_ID_ALARM, S_MOTION);   delay(RF_INIT_DELAY);
    Read eeprom settings
            recallEeprom();
    nit SPI bus for MFRC RFID sensor
            SPI.begin();            // Init SPI bus
            mfrc522.PCD_Init();     // Init MFRC522
            ShowReaderDetails();            // Show details of PCD - MFRC522 Card Reader details
            gw.send(lockArmMsg.set(armed));
            Serial.println(F("Init done..."));
            timer++;
            delay(HEARTBEAT);
            gw.process();
            debouncer.update();
            // Get the update value
            int switchValue = debouncer.read();
            if (switchValue != oldSwitchValue) {
              // Send in the new value
              Serial.print (F("Switch "));
              Serial.println (switchValue);
              if (switchValue && programmode) {
                   lastTime     = millis() / 1000;
              if (!switchValue && programmode && lastTime > 0) {
                   if ( (millis() / 1000) - lastTime > 3) {
                        Serial.println(F("Reset all cards"));
                        countValidCards  = 0;
                        blinkFast(50);
                   } else {
                      Serial.println(F("Program off"));
                      programmode = false;
                      storeEeprom();
              if (!switchValue)   {
                  programTimer = 0;
              oldSwitchValue = switchValue;
            if (programmode && ((timer % (ONE_SEC / HEARTBEAT)) == 0 ))  {
                ledon = !ledon;
                digitalWrite(LED_PIN, ledon);
                programTimer++;
                // Stop program mode after 20 sec inactivity
                if (programTimer > PROG_WAIT)  {
                   digitalWrite(LED_PIN, false);
                   Serial.println(F("Program expired"));
            if ((timer % (200 / HEARTBEAT)) == 0 )   {
                 // Look for new cards
                 if ( ! mfrc522.PICC_IsNewCardPresent()) {
                      if (releasecnt > 0)   {
                          releasecnt--;
                          if (!releasecnt)  {
                              olduid.size = 0;
                              Serial.println(F("release"));
                return;
                releasecnt = 5;
    Check if a RFID card is held at the RFID reader if not: skip the rest and start over with loop()
               // Select one of the cards
               if ( ! mfrc522.PICC_ReadCardSerial()) {
                  return;
               // Dump debug info about the card; PICC_HaltA() is automatically called
               //mfrc522.PICC_DumpToSerial(&(mfrc522.uid));
    Check if this card is the same as the previous loop if not enter the IF loop
               if (!olduid.size || !sameUid(&(mfrc522.uid), &olduid))  {
                    ShowCardData(&(mfrc522.uid));
                    copyUid(&(mfrc522.uid), &olduid);
                    if ( isValidCard(&olduid) )   {
                         OpenDoor(programmode);
                    } else  {
    Check if the master card was presented and the button was pressed enter program mode
                       if (sameUid(&(mfrc522.uid), &masterkey)) {
                           // Only switch in program mode when mastercard is found AND the program button is pressed
                           if (switchValue)  {
                             Serial.println(F("Program mode"));
                             programmode = true;
                             programTimer = 0;
                             lastTime     = 0;
                           } else {
                             OpenDoor2(programmode);
                       } else {
    If not the master card and this card in not known and we're in program mode add this as a new card
                           if (programmode) {
                             Serial.println(F("new card"));
                             programTimer = 0;
                             if (countValidCards < MAX_CARDS)
                                // Add card to list...
                                copyUid(&(mfrc522.uid), &validCards[countValidCards]);
                                countValidCards++;
                                blinkFast(15);
                           } else {
                             Serial.println(F("Invalid card"));
                             if (armed) {
                                gw.send(wrongMsg.set(1));
                                delay(2000);
                                gw.send(wrongMsg.set(0));
    These are support functions
    void ShowCardData(MFRC522::Uid* uid)
        Serial.print(F("Card UID:"));
        for (byte i = 0; i < uid->size; i++) {
            if(uid->uidByte[i] < 0x10) {
                Serial.print(F(" 0"));
            } else {
                Serial.print(F(" "));
            Serial.print(uid->uidByte[i], HEX);
        Serial.println();
    void copyUid(MFRC522::Uid* src, MFRC522::Uid* dest)
        dest->size = src->size;
        dest->sak  = src->sak;
        for (byte i = 0; i < src->size; i++) {
        dest->uidByte[i] = src->uidByte[i];
    bool sameUid(MFRC522::Uid* old, MFRC522::Uid* check)
        if (old->size != check->size) {
           return false;
        for (byte i = 0; i < old->size; i++) {
            if (old->uidByte[i] != check->uidByte[i]) {
                return false;
        return true;
    bool isValidCard(MFRC522::Uid* uid)
          for (byte i = 0; i < countValidCards; i++)  {
              if (validCards[i].size != uid->size)  {
                  break;
              for (int j = 0; j < uid->size; j++) {
                  if (validCards[i].uidByte[j] != uid->uidByte[j])  {
                      break;
                  if (j == (uid->size - 1)) {
                      return true;
          return false;
    void storeEeprom()
        byte address = 0;
        gw.saveState(address++, countValidCards);
           gw.saveState(address++, validCards[i].size);
           for (byte j = 0; j < 10; j++) {
              gw.saveState(address++, validCards[i].uidByte[j]);
    void recallEeprom()
        byte address = 0;
        countValidCards = gw.loadState(address++);
        if (countValidCards > MAX_CARDS) {
           Serial.println(F("Not a valid EEPROM reading set to default"));
           storeEeprom();
           return;
           validCards[i].size = gw.loadState(address++);
              validCards[i].uidByte[j] = gw.loadState(address++);
    void blinkFast(int times)
        for (int i = 0; i < times; i++) {
           ledon = !ledon;
           delay(100);
    void OpenDoor(bool fakeOpen)
        Serial.println(F("Open door!"));
        gw.send(lockMsg.set(false));
        if (!fakeOpen) {
          digitalWrite(LED_PIN, HIGH);
          digitalWrite(GARAGEPIN, HIGH);
        delay(1000);
        if (!fakeOpen) {
          digitalWrite(GARAGEPIN, LOW);
        gw.send(lockMsg.set(true));
    void OpenDoor2(bool fakeOpen)
        Serial.println(F("Open door 2!"));
        gw.send(lock2Msg.set(false));
        if (!fakeOpen) {
          digitalWrite(SECONDRELAY, HIGH);
        delay(1000);
        if (!fakeOpen) {
          digitalWrite(SECONDRELAY, LOW);
        gw.send(lock2Msg.set(true));
    void ShowReaderDetails() {
        // Get the MFRC522 software version
        byte v = mfrc522.PCD_ReadRegister(mfrc522.VersionReg);
        Serial.print(F("MFRC522 Software Version: 0x"));
        Serial.print(v, HEX);
        if (v == 0x91) {
            Serial.print(F(" = v1.0"));
            } else if (v == 0x92) {
            Serial.print(F(" = v2.0"));
            } else {
            Serial.print(F(" (unknown)"));
        Serial.println("");
            // When 0x00 or 0xFF is returned, communication probably failed
        if ((v == 0x00) || (v == 0xFF)) {
            Serial.println(F("WARNING: Communication failure, is the MFRC522 properly connected?"));
       if (message.type == V_LOCK_STATUS) {
         // Change relay state
         if (!message.getBool())  {
            switch (message.sensor)
               case CHILD_ID_LOCK:
                  OpenDoor(false);
                  break;
               case CHILD_ID_LOCK2:
                  OpenDoor2(false);
                  break;
         // Write some debug info
         Serial.print(F("Lock:  "));
         Serial.print(message.sensor);
         Serial.print(F(" status: "));
       else
         if (message.type == V_ARMED)  {
           armed = message.getBool();
           Serial.print(F("Arm status: "));
         else
           Serial.print(F("Incoming msg type: "));
           Serial.print(message.type);
           Serial.print(F(" id: "));
           Serial.print(F(" content: "));
           Serial.println(message.getInt());
    • BartEB BartE
      @SVLoneStar That should work, did you try the sketch shown in the topic?
      The function recallEeprom(); reads the EEPROM content and after closing the program mode this function storeEeprom();
      writes the EEPROM. Please add some debug info (Serial.print) and validate that these functions actually are called on
      • recallEeprom(); --> on start up
      • storeEeprom(); --> ending program mode.
      ChakkieC
      ChakkieC
      Chakkie
      @BartE
      Hi BartE, I have the same issue regarding tags lost after power off. I run the debug instruction using Serial print as you mentioned. I found out that the storeEeprom line did not run after closing the program mode. I think this is why the tags are lost after power cycle.
      send: 210-210-0-0 s=255,c=3,t=15,pt=2,l=2,sg=0,st=ok:0
      send: 210-210-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,st=ok:1.5.4
      send: 210-210-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
      read: 0-0-210 s=255,c=3,t=6,pt=0,l=1,sg=0:M
      sensor started, id=210, parent=0, distance=1
      send: 210-210-0-0 s=255,c=3,t=11,pt=0,l=9,sg=0,st=ok:RFID Lock
      send: 210-210-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.1
      send: 210-210-0-0 s=2,c=0,t=19,pt=0,l=0,sg=0,st=ok:
      send: 210-210-0-0 s=1,c=0,t=1,pt=0,l=0,sg=0,st=ok:
      RecallEeprom
      MFRC522 Software Version: 0x92 = v2.0
      send: 210-210-0-0 s=1,c=1,t=15,pt=2,l=2,sg=0,st=ok:1
      Init done...
      Switch 1
      Card UID: 26 13 80 41
      Invalid card
      send: 210-210-0-0 s=1,c=1,t=16,pt=2,l=2,sg=0,st=ok:1
      send: 210-210-0-0 s=1,c=1,t=16,pt=2,l=2,sg=0,st=ok:0
      release
      Card UID: xx xx xx xx
      Program mode
      release
      new card
      release
      Program expired
      Raspberry Pi 2
      Domoticz
      RFXCOM
      ZWAVE Aeon stick
      Coming soon Arduino mysensors GW
      • BartEB BartE
        ChakkieC
        ChakkieC
        Chakkie
        @BartE
        I've just solved the issue regarding tags lost after power off.
        Simply add the line "StoreEeprom();" after the program mode function
                    ledon = !ledon;
                    programTimer++;
                       storeEeprom();
                       Serial.println(F("Store Card to EEPROM"));  ```
        Raspberry Pi 2
        Domoticz
        RFXCOM
        ZWAVE Aeon stick
        BartEB 1 Reply Last reply
        • ChakkieC Chakkie
          @BartE
                      ledon = !ledon;
                      programTimer++;
                         storeEeprom();
          BartEB
          BartEB
          BartE
          @Chakkie sorry for the slow response (i was on a pre summer holiday)
          Thx for analyzing this report. The fix you did made is not what i meant with program expired.
          The idea is that you start program mode by pressing the program button and holding the master card.
          And now one can add one or more new RFID cards and when your oke press the program button for a short period to END the program mode and store the new cards.
          If you wait too long the program mode will expire and the new cards are NOT stored. Off course you can change this behavior by adding this line as you suggested.
          • Michel - ItM
            Michel - ItM
            Michel - It
            wrote on last edited by Michel - It
            #25
            hello to all guys, I noticed some problems, if the power goes away there is a flaw in the system. I modified the source as needed to me, now you turn the sensor on domoticz when you turn on and off when you turn off. I modified the project to create an alarm homemade I configured via lua script the motion sensors. I mounted on the bell so as to turn on and off when I go out or within the home. thank you all
            0_1464953572731_rfidCompreto.jpg 0_1464953579700_rfidmoduloporta-180x180.jpg 0_1464953586849_rfidcentralina-180x180.jpg
            • electromakerE
              electromakerE
              electromaker
              Hi Everyone,
              I have tested this code http://etabetastudio.blogspot.it/2016/07/tutorial-lettore-rfid-rc522-arduino-idea.html to test RFID RC-522 with Arduino 2009 and all is ok, also to registred RFID card on EEPROM...
              I hope to help uo...bye
              • Mercury69M
                Mercury69M
                Mercury69
                Dear All,
                I'm a newbie and I found in MySensors website the project for RFID Lock Sensors that use PN532 RFID Reader, but as I already have with me a RC-522 RFID reader, searching on the forum I found this post that I thinked it will suit my case.
                I assembled the various hardware parts as described on first post, but when I copied the sketch code in my arduino IDE, I'm not able to get it work.
                I get some error message that is not so clear for me.
                It's seems the sketch is for a previous version of MySensors Library or Arduino IDE, but I'm not sure of this.
                As I use Arduino IDE 1.6.12 that has included MySensors Library 2.0.0, is the Sketch you included in the first post already valid for that setup ?
                It' will be possible to have a valid sketch working with new setup or eventually to know how to proceed to make the actual one working ?
                Thank you in advance for your attention.
                Rod MacPhersonR 1 Reply Last reply
                • Mercury69M Mercury69
                  Dear All,
                  Rod MacPhersonR
                  Rod MacPhersonR
                  Rod MacPherson
                  @Mercury69
                  It was written prior to the MySensors 2.0 update.
                  You can convert pre- 2.0 sketches by following the instructions on https://forum.mysensors.org/topic/4276/converting-a-sketch-from-1-5-x-to-2-0-x
                  If you need a hand just post here with your question, I'll try to help, but it's really not too bad once you get started. I'm in the process of converting all of my code to 2.0 as well.
                  Mercury69M 1 Reply Last reply
                  • Rod MacPhersonR Rod MacPherson
                    @Mercury69
                    Mercury69M
                    Mercury69M
                    Mercury69
                    @Rod-MacPherson
                    Dear Rod, thank you for the suggestion you gave me.
                    Following the instruction you indicated me, I was able to make the sketch working with new MySensors 2.0 library.
                    Considering that I'm not a programmer, it was quite easy to make the sketch working.
                    Thank you again for your suggestion and off course thank you to BartE for the good original work he did.
                    If someone need new sketch working with library 2.0, feel free to ask me.
                    Michel - ItM J 2 Replies Last reply
                      @Rod-MacPherson
                      Michel - ItM
                      Michel - ItM
                      Michel - It
                      @Mercury69 you can post the sketch ?
                        @Rod-MacPherson
                        J
                        J
                        jeti
                        @Mercury69 I would also love to have a look at your scetch!
                        • miroM
                          miroM
                          miro
                          @Mercury69
                          Please, I would also like to see your code if it possible.
                          • cadetC
                            cadetC
                            cadet
                            Hi Rod
                            Can you modify your code for 2.0 lib ?
                            Thank you
                            Andrey
                              wrote on last edited by gohan
                              #34
                              Here is the new code for lib 2.0, but I am having some problem with initialization of rc522. I connected RST tu D7 and SDA to D8. Any idea what to look for?
                              * This is a MFRC522 library example; see https://github.com/miguelbalboa/rfid
                              * for further details and other examples.
                              * NOTE: The library file MFRC522.h has a lot of useful info. Please read it.
                              * Released into the public domain.
                              * Example sketch/program showing how to read data from a PICC (that is: a RFID
                              * Tag or Card) using a MFRC522 based RFID Reader on the Arduino SPI interface.
                              * When the Arduino and the MFRC522 module are connected (see the pin layout
                              * below), load this sketch into Arduino IDE then verify/compile and upload it.
                              * To see the output: use Tools, Serial Monitor of the IDE (hit Ctrl+Shft+M).
                              * When you present a PICC (that is: a RFID Tag or Card) at reading distance
                              * of the MFRC522 Reader/PCD, the serial output will show the ID/UID, type and
                              * any data blocks it can read. Note: you may see "Timeout in communication"
                              * messages when removing the PICC from reading distance too early.
                              * If your reader supports it, this sketch/program will read all the PICCs
                              * presented (that is: multiple tag reading). So if you stack two or more
                              * PICCs on top of each other and present them to the reader, it will first
                              * output all details of the first and then the next PICC. Note that this
                              * may take some time as all data blocks are dumped, so keep the PICCs at
                              * reading distance until complete.
                              * Typical pin layout used:
                              *             MFRC522      Arduino       Arduino   Arduino    Arduino          Arduino
                              *             Reader/PCD   Uno           Mega      Nano v3    Leonardo/Micro   Pro Micro
                              * Signal      Pin          Pin           Pin       Pin        Pin              Pin
                              * RST/Reset   RST          9             5         D9         RESET/ICSP-5     RST
                              * SPI SS      SDA(SS)      10            53        D10        10               10
                              * SPI MOSI    MOSI         11 / ICSP-4   51        D11        ICSP-4           16
                              * SPI MISO    MISO         12 / ICSP-1   50        D12        ICSP-1           14
                              * SPI SCK     SCK          13 / ICSP-3   52        D13        ICSP-3           15
                              RFID Garagedoor opener by Bart Eversdijk
                              This sketch is to open a Garage door with an mifare RIFD-tag
                              For an Arduino Nano v3
                              Connection wiring :
                              - nrf24l01+ as descibed on the MySensors website
                              - MFRC522 reader/writer as described above EXCEPT for pin D9 and D10:  connect RST i.s.o. pin D9 to pin D7 and connect SDA(SS) i.s.o. pin D10 to pin D8
                              - LED with 470ohm resistor between GMD and pin A3
                              - push button between GND and pin D5
                              - 5v relays coil between GND and  pin D4 -> switch pins of the relays should be connected in parallel with your garage door push button.
                              Features:
                              This project can record up to 18 RFID-"tags"
                              These card IDs are stored in to EEPROM by keeping them next to the RFID reader when the system in program mode. (Slow blinking LED) When a card is accepted as new card the LED will blink fast for a short time.
                              To keep the master-tags (choose your own) next to the RFID reader when pressing the push button. To clear all cards (except the master card) press the push button in program mode for 6 seconds. The LED will now fast blink for a couple of seconds.
                              Your garage your can be opened by keep a registered RFID tag next to the reader or by clicking the open icon on lock node presented by this plugin.
                              By by-passing the alarm node presented by this plug in the RFID will be temporarily disabled.
                              When an incorrect (not registered) RFID tag is scanned the alarm is triggered to detect illegal scan attempts
                              #include <MFRC522.h>
                              #include <Bounce2.h>
                              #define RF_INIT_DELAY   125
                              #define ONE_SEC         1000
                              #define MAX_CARDS       18
                              #define PROG_WAIT       10
                              #define HEARTBEAT       10
                              #define BAUD            115200
                              /*Pin definitions*/
                              #define LED_PIN         A3
                              #define GARAGEPIN       4
                              #define SWITCH_PIN      5
                              #define RST_PIN		7		//  MFRC
                              #define SS_PIN		8		//  MFRC
                              MFRC522      mfrc522(SS_PIN, RST_PIN);	// Create MFRC522 instance
                              MFRC522::Uid olduid;
                              MFRC522::Uid masterkey = { 10,{ 0,0,0,0, 0,0,0,0, 0,0 },  0 };
                              byte       countValidCards = 0;
                              MFRC522::Uid validCards[MAX_CARDS];
                              void       ShowCardData(MFRC522::Uid* uid);
                              bool       sameUid(MFRC522::Uid* old, MFRC522::Uid* check);
                              void       copyUid(MFRC522::Uid* src, MFRC522::Uid* dest);
                              bool       isValidCard(MFRC522::Uid* uid);
                              int        releasecnt = 0;
                              #define    CHILD_ID_ALARM    1
                              #define    CHILD_ID_LOCK     2
                              Bounce     debouncer = Bounce();
                              int        oldSwitchValue = -1;
                              int        switchValue = 0;
                              long       timer = -1;
                              bool       programmode = false;
                              bool       ledon;
                              int        programTimer = 0;
                              bool       armed = true;
                              unsigned long lastTime = 0;
                              MyMessage  lockMsg(CHILD_ID_LOCK, V_LOCK_STATUS);
                              MyMessage  lockArmMsg(CHILD_ID_ALARM, V_ARMED);
                              MyMessage  wrongMsg(CHILD_ID_ALARM, V_TRIPPED);
                              	// Setup the button
                              	pinMode(SWITCH_PIN, INPUT);
                              	// Activate internal pull-up
                              	digitalWrite(SWITCH_PIN, HIGH);
                              	sendSketchInfo("RFID Garage", "1.1"); delay(RF_INIT_DELAY);
                              	recallEeprom();
                              	// Init MFRC RFID sensor
                              	timer++;
                              	delay(HEARTBEAT);
                              	debouncer.update();
                              		Serial.print(F("Switch "));
                              		Serial.println(switchValue);
                              			if ((millis() / 1000) - lastTime > 3) {
                              				blinkFast(50);
                              			else {
                              				storeEeprom();
                              		if (!switchValue) {
                              			programTimer = 0;
                              	if (programmode && ((timer % (ONE_SEC / HEARTBEAT)) == 0)) {
                              		ledon = !ledon;
                              		programTimer++;
                              	if ((timer % (200 / HEARTBEAT)) == 0) {
                              		if (!mfrc522.PICC_IsNewCardPresent()) {
                              				releasecnt--;
                              				if (!releasecnt) {
                              					olduid.size = 0;
                              			return;
                              		releasecnt = 5;
                              		if (!mfrc522.PICC_ReadCardSerial()) {
                              			return;
                              			if (isValidCard(&olduid)) {
                              			else {
                              					if (switchValue) {
                              						programmode = true;
                              						programTimer = 0;
                              						lastTime = 0;
                              				else {
                              					if (programmode) {
                              						programTimer = 0;
                              							countValidCards++;
                              							blinkFast(15);
                              					else {
                              						if (armed) {
                              							delay(2000);
                              void ShowCardData(MFRC522::Uid* uid) {
                              		if (uid->uidByte[i] < 0x10) {
                              		else {
                              	Serial.println();
                              		return false;
                              			return false;
                              	return true;
                              			break;
                              				break;
                              				return true;
                              	return false;
                              void storeEeprom()
                              	byte address = 0;
                              void recallEeprom()
                              	byte address = 0;
                              	countValidCards = loadState(address++);
                              		storeEeprom();
                              		return;
                              		validCards[i].size = loadState(address++);
                              			validCards[i].uidByte[j] = loadState(address++);
                              		ledon = !ledon;
                              		delay(100);
                              	if (!fakeOpen) {
                              	delay(1000);
                              	if (!fakeOpen) {
                              	if (v == 0x91) {
                              	else {
                              	Serial.println("");
                              			OpenDoor(false);
                              		Serial.print(F("Lock status: "));
                              	else
                              		else
                              BartEB 2 Replies Last reply
                                Connection wiring :
                                Features:
                                #define BAUD            115200
                                /*Pin definitions*/
                                #define LED_PIN         A3
                                #define GARAGEPIN       4
                                int        releasecnt = 0;
                                long       timer = -1;
                                bool       ledon;
                                bool       armed = true;
                                	// Setup the button
                                	recallEeprom();
                                	timer++;
                                	delay(HEARTBEAT);
                                	debouncer.update();
                                				blinkFast(50);
                                			else {
                                				storeEeprom();
                                		if (!switchValue) {
                                			programTimer = 0;
                                		ledon = !ledon;
                                		programTimer++;
                                				releasecnt--;
                                				if (!releasecnt) {
                                					olduid.size = 0;
                                			return;
                                		releasecnt = 5;
                                			return;
                                			else {
                                					if (switchValue) {
                                						programmode = true;
                                						programTimer = 0;
                                						lastTime = 0;
                                				else {
                                					if (programmode) {
                                						programTimer = 0;
                                							countValidCards++;
                                							blinkFast(15);
                                					else {
                                						if (armed) {
                                							delay(2000);
                                		else {
                                	Serial.println();
                                		return false;
                                			return false;
                                	return true;
                                			break;
                                				break;
                                				return true;
                                	return false;
                                void storeEeprom()
                                	byte address = 0;
                                void recallEeprom()
                                	byte address = 0;
                                		storeEeprom();
                                		return;
                                		ledon = !ledon;
                                		delay(100);
                                	if (!fakeOpen) {
                                	delay(1000);
                                	if (!fakeOpen) {
                                	if (v == 0x91) {
                                	else {
                                	Serial.println("");
                                			OpenDoor(false);
                                	else
                                		else
                                BartEB
                                BartEB
                                BartE
                                wrote on last edited by BartE
                                #35
                                @gohan the MIFARE chip needs to be disabled from the SPI bus before the radio is initialized
                                so put this piece of code in the before() function
                                void before() {
                                	// Make sure MFRC is disabled from the SPI bus
                                The MySensors library will iniitialize the MyS before the setup() function but after the before()
                                these lines
                                Should be part of
                                void presentation() {
                                and the function:
                                should be renamed to
                                gohanG 1 Reply Last reply
                                • BartEB BartE
                                  void before() {
                                  these lines
                                  Should be part of
                                  and the function:
                                  It didn't change much, here is the log
                                  3 MCO:BGN:BFR
                                  4 TSM:INIT
                                  5 TSF:WUR:MS=0
                                  13 TSM:INIT:TSP OK
                                  14 TSM:INIT:STATID=4
                                  16 TSF:SID:OK,ID=4
                                  18 TSM:FPAR
                                  59 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                  803 TSF:MSG:READ,0-0-4,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                  808 TSF:MSG:FPAR OK,ID=0,D=1
                                  2067 TSM:FPAR:OK
                                  2068 TSM:ID
                                  2069 TSM:ID:OK
                                  2071 TSM:UPL
                                  2075 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                                  2082 TSF:MSG:READ,0-0-4,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                                  2087 TSF:MSG:PONG RECV,HP=1
                                  2089 TSM:UPL:OK
                                  2092 TSM:READY:ID=4,PAR=0,DIS=1
                                  2135 !TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=NACK:0100
                                  4143 TSF:MSG:SEND,4-4-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=1,st=OK:2.1.1
                                  4152 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                                  4250 TSF:MSG:READ,0-0-4,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                                  4261 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=11,pt=0,l=11,sg=0,ft=0,st=OK:RFID Garage
                                  4272 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.1
                                  4406 TSF:MSG:SEND,4-4-0-0,s=2,c=0,t=19,pt=0,l=0,sg=0,ft=0,st=OK:
                                  4539 TSF:MSG:SEND,4-4-0-0,s=1,c=0,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
                                  4670 MCO:REG:REQ
                                  4674 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                                  4685 TSF:MSG:READ,0-0-4,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                                  4690 MCO:PIM:NODE REG=1
                                  4692 MCO:BGN:STP
                                  MFRC522 Software Version: 0x0 (unknown)
                                  4755 TSF:MSG:SEND,4-4-0-0,s=1,c=1,t=15,pt=1,l=1,sg=0,ft=0,st=OK:1
                                  Init done...
                                  4761 MCO:BGN:INIT OK,TSP=1
                                  Switch 1
                                  Here is also the code with the changes you suggested
                                  Connection wiring :
                                  Features:
                                  // Enable debug prints
                                  #define MY_NODE_ID 4
                                  #define MY_RF24_CHANNEL	10
                                  #define BAUD            115200
                                  /*Pin definitions*/
                                  #define LED_PIN         A3
                                  #define GARAGEPIN       4
                                  MFRC522::Uid masterkey = { 4,{ 0xC6,0x35,0x5D,0x8E},  0 };
                                  int        releasecnt = 0;
                                  long       timer = -1;
                                  bool       ledon;
                                  bool       armed = true;
                                  void before() {
                                  	/*pinMode(RST_PIN, OUTPUT);
                                  	digitalWrite(SS_PIN, LOW);*/
                                  	// Setup the button
                                  	/*sendSketchInfo("RFID Garage", "1.1"); delay(RF_INIT_DELAY);
                                  	present(CHILD_ID_ALARM, S_MOTION);   delay(RF_INIT_DELAY);*/
                                  	recallEeprom();
                                  	timer++;
                                  	delay(HEARTBEAT);
                                  	debouncer.update();
                                  				blinkFast(50);
                                  			else {
                                  				storeEeprom();
                                  		if (!switchValue) {
                                  			programTimer = 0;
                                  		ledon = !ledon;
                                  		programTimer++;
                                  				releasecnt--;
                                  				if (!releasecnt) {
                                  					olduid.size = 0;
                                  			return;
                                  		releasecnt = 5;
                                  			return;
                                  			else {
                                  					if (switchValue) {
                                  						programmode = true;
                                  						programTimer = 0;
                                  						lastTime = 0;
                                  				else {
                                  					if (programmode) {
                                  						programTimer = 0;
                                  							countValidCards++;
                                  							blinkFast(15);
                                  					else {
                                  						if (armed) {
                                  							delay(2000);
                                  		else {
                                  	Serial.println();
                                  		return false;
                                  			return false;
                                  	return true;
                                  			break;
                                  				break;
                                  				return true;
                                  	return false;
                                  void storeEeprom()
                                  	byte address = 0;
                                  void recallEeprom()
                                  	byte address = 0;
                                  		storeEeprom();
                                  		return;
                                  		ledon = !ledon;
                                  		delay(100);
                                  	if (!fakeOpen) {
                                  	delay(1000);
                                  	if (!fakeOpen) {
                                  	if (v == 0x91) {
                                  	else {
                                  	Serial.println("");
                                  			OpenDoor(false);
                                  	else
                                  		else
                                    Connection wiring :
                                    Features:
                                    #define BAUD            115200
                                    /*Pin definitions*/
                                    #define LED_PIN         A3
                                    #define GARAGEPIN       4
                                    int        releasecnt = 0;
                                    long       timer = -1;
                                    bool       ledon;
                                    bool       armed = true;
                                    	// Setup the button
                                    	recallEeprom();
                                    	timer++;
                                    	delay(HEARTBEAT);
                                    	debouncer.update();
                                    				blinkFast(50);
                                    			else {
                                    				storeEeprom();
                                    		if (!switchValue) {
                                    			programTimer = 0;
                                    		ledon = !ledon;
                                    		programTimer++;
                                    				releasecnt--;
                                    				if (!releasecnt) {
                                    					olduid.size = 0;
                                    			return;
                                    		releasecnt = 5;
                                    			return;
                                    			else {
                                    					if (switchValue) {
                                    						programmode = true;
                                    						programTimer = 0;
                                    						lastTime = 0;
                                    				else {
                                    					if (programmode) {
                                    						programTimer = 0;
                                    							countValidCards++;
                                    							blinkFast(15);
                                    					else {
                                    						if (armed) {
                                    							delay(2000);
                                    		else {
                                    	Serial.println();
                                    		return false;
                                    			return false;
                                    	return true;
                                    			break;
                                    				break;
                                    				return true;
                                    	return false;
                                    void storeEeprom()
                                    	byte address = 0;
                                    void recallEeprom()
                                    	byte address = 0;
                                    		storeEeprom();
                                    		return;
                                    		ledon = !ledon;
                                    		delay(100);
                                    	if (!fakeOpen) {
                                    	delay(1000);
                                    	if (!fakeOpen) {
                                    	if (v == 0x91) {
                                    	else {
                                    	Serial.println("");
                                    			OpenDoor(false);
                                    	else
                                    		else
                                    BartEB
                                    BartEB
                                    BartE
                                    @gohan did you try running the MRRC522 demo application only?
                                    So eliminating all MySensors stuff. To check the wiring.(make sure the pin 7 an 8 definition are correct.)
                                      If I unplug the nrf24 and use the original wiring with the demo sketch I can read the tags. I checked with multimeter from arduino to the rfid pins and they are OK. But I'll be ordering the newer board that supports nfc
                                      • T
                                        thomas84
                                        Hello all,
                                        I am very new to arduino and all this stuff. This rfid garage opener ist exactly what i am lookibg for as my first project. But i have problems compiling the code with arduino ide. I get error notifications regarding the .h files. Do I have to include them in my arduino ide folders? Can someone please tell me where to find them? And where i have to save them?
                                        It would be very nice if someone helps me!
                                        marceltrapmanM gohanG mfalkviddM 3 Replies Last reply
                                        • T thomas84
                                          Hello all,
                                          marceltrapmanM
                                          marceltrapmanM
                                          marceltrapman
                                          It would help if you share your error messages.
                                          In general I would say, read the messages and (try to) interpret them (google?).
                                          Fulltime Servoy Developer
