  3. RFID Garage door opener
47 Posts 23 Posters 42.7k Views 26 Watching
  • S SVLoneStar
    Hello BartE,
    I have the same issue as cyberfilou...
    Sketch works beautifully...but if I power off the Arduino (Pro Mini in my case) and power it on again, all stored cards are gone. Any ideas what could cause this, and how to prevent it?
    Thx a lot, Stefan
    BartEB
    BartEB
    BartE
    @SVLoneStar That is weird.
    Do you get this message each time you boot the Arduino? "Not a valid EEPROM reading set to default"
    What is the UID size (how many bytes) of the recorded cards?
      SVLoneStar
      Hi BartE - thanks for your reply!
      I do not receive any error regarding invalid EEPROM - not while writing, not at boot time.
      My cards are shown in this format: D4 04 E2 E9
      I register a Master Card like this (and it works until reboot):
      MFRC522::Uid masterkey = { 4, {0xD4,0x04,0xE2,0xE9}, 0 };
      BartEB 1 Reply Last reply
      • AnticimexA
        AnticimexA
        Anticimex
        Cool stuff! You probably what some signing in there as well :) would be a shame if someone snooped the open command from your controller and decided to pay a visit.
        • S SVLoneStar
          BartEB
          BartEB
          BartE
          @SVLoneStar That should work, did you try the sketch shown in the topic?
          The function recallEeprom(); reads the EEPROM content and after closing the program mode this function storeEeprom();
          writes the EEPROM. Please add some debug info (Serial.print) and validate that these functions actually are called on
          • recallEeprom(); --> on start up
          • storeEeprom(); --> ending program mode.
          ChakkieC 2 Replies Last reply
          • AnticimexA Anticimex
            BartEB
            BartEB
            BartE
            @Anticimex yes your right but when i wrote this sketch signing was not in the released branch.
            • Rod MacPhersonR
              Rod MacPhersonR
              Rod MacPherson
              Nice work. I have yet to pick up an RFID reader to give that part of it a try, but I've modified it a little to have reed sensors for the 2 doors so that I can easily see if the door is open on my phone, and get notifications when the door opens at an unexpected time, like when the controller is set to vacation mode, or at times of night when we would not normally be coming and going.
              I'll be watching for someone to post up a signing version.
              Here's my 2 relay, 2 door sensor version.
               RFID Garagedoor opener by Bart Eversdijk
               Modified to add door sensors by Rod MacPherson
               This sketch is to open a Garage door with an mifare RIFD-tag
                For an Arduino Nano v3
                Connection wiring :
                  - nrf24l01+ as descibed on the MySensors website
                  - MFRC522 reader/writer MOSI, MISO, SCK, 3.3V and GND as they are on the nrf24101+, but connect RST to pin D7 and connect SDA(SS) to pin D8
                  - LED with 470ohm resistor between GND and pin A3
                  - push button between GND and pin D5
                  - 5v relays coil between GND and  pin D4 -> switch pins of the relays should be connected in parallel with your garage door push button.
                  - second relay for second door on pin D3
                Features:
                This project can record up to 18 RFID-"tags"
                These card IDs are stored in to EEPROM by keeping them next to the RFID reader when the system in program mode. (Slow blinking LED) When a card is accepted as new card the LED will blink fast for a short time.
                To keep the master-tags (choose your own) next to the RFID reader when pressing the push button. To clear all cards (except the master card) press the push button in program mode for 6 seconds. The LED will now fast blink for a couple of seconds.
                Your garage your can be opened by keep a registered RFID tag next to the reader or by clicking the open icon on lock node presented by this plugin.
                By by-passing the alarm node presented by this plug in the RFID will be temporarily disabled.
                When an incorrect (not registered) RFID tag is scanned the alarm is triggered to detect illegal scan attempts
              #include <MFRC522.h>
              #define RF_INIT_DELAY   125
              #define ONE_SEC         1000
              #define MAX_CARDS       18
              #define PROG_WAIT       10
              #define HEARTBEAT       10
              #define BAUD            115200
              /*Pin definitions*/
              #define LED_PIN         A3
              #define SECONDRELAY     3
              #define GARAGEPIN       4
              #define SWITCH_PIN      5
              #define RST_PIN         7       //  MFRC
              #define SS_PIN          8       //  MFRC
              #define DOOR_PIN_L  A0  // Arduino Digital I/O pin for button/reed switch
              #define DOOR_PIN_R  A1  // Arduino Digital I/O pin for button/reed switch
              MFRC522      mfrc522(SS_PIN, RST_PIN);  // Create MFRC522 instance
              MFRC522::Uid olduid;
              MFRC522::Uid masterkey = { 10, {0,0,0,0, 0,0,0,0, 0,0 },  0 };
              byte       countValidCards  = 0;
              MFRC522::Uid validCards[MAX_CARDS];
              void       ShowCardData(MFRC522::Uid* uid);
              bool       sameUid(MFRC522::Uid* old, MFRC522::Uid* check);
              void       copyUid(MFRC522::Uid* src, MFRC522::Uid* dest);
              bool       isValidCard(MFRC522::Uid* uid);
              int        releasecnt = 0;
              #define    CHILD_ID_ALARM    1
              #define    CHILD_ID_LOCK     2
              #define    CHILD_ID_LOCK2    3
              #define    CHILD_ID_DOOR_L    4
              #define    CHILD_ID_DOOR_R    5
              MySensor   gw;
              Bounce     debouncer = Bounce();
              Bounce     debouncerDoorR = Bounce();
              Bounce     debouncerDoorL = Bounce();
              int oldValueR=-1;
              int oldValueL=-1;
              int        oldSwitchValue=-1;
              int        switchValue = 0;
              long       timer = -1;
              bool       programmode = false;
              bool       ledon;
              int        programTimer = 0;
              bool       armed = true;
              unsigned long lastTime = 0;
              MyMessage  lockMsg(CHILD_ID_LOCK,          V_LOCK_STATUS);
              MyMessage  lock2Msg(CHILD_ID_LOCK2,          V_LOCK_STATUS);
              MyMessage  lockArmMsg(CHILD_ID_ALARM,      V_ARMED);
              MyMessage  wrongMsg(CHILD_ID_ALARM,        V_TRIPPED);
              MyMessage  doorRmsg(CHILD_ID_DOOR_R, V_TRIPPED);
              MyMessage  doorLmsg(CHILD_ID_DOOR_L, V_TRIPPED);
                      Serial.begin(BAUD);     // Initialize serial communications with the PC
                      pinMode(GARAGEPIN, OUTPUT);     // Initialise in/output ports
                      pinMode(SECONDRELAY, OUTPUT);     // Initialise in/output ports
                      // Make sure MFRC will be disabled on the SPI bus
                      pinMode(RST_PIN, OUTPUT);
                      digitalWrite(RST_PIN, LOW);
                      pinMode(SS_PIN, OUTPUT);
                      digitalWrite(SS_PIN, LOW);
                      pinMode(LED_PIN, OUTPUT);
                      digitalWrite(LED_PIN, LOW);
                      // Setup the button
                      pinMode(SWITCH_PIN, INPUT_PULLUP);
                      debouncer.attach(SWITCH_PIN);
                      debouncer.interval(5);
                      // Setup the right door sensor
                      pinMode(DOOR_PIN_R,INPUT);
                      // Activate internal pull-up
                      digitalWrite(DOOR_PIN_R,HIGH);
                      debouncerDoorR.attach(DOOR_PIN_R);
                      debouncerDoorR.interval(5);
                      // Setup the left door sensor
                      pinMode(DOOR_PIN_L,INPUT);
                      digitalWrite(DOOR_PIN_L,HIGH);
                      debouncerDoorL.attach(DOOR_PIN_L);
                      debouncerDoorL.interval(5);
                      // Init mysensors library
                      gw.begin(incomingMessage, 5);
                      gw.sendSketchInfo("RFID Garage", "1.2"); delay(RF_INIT_DELAY);
                      gw.present(CHILD_ID_LOCK, S_LOCK);      delay(RF_INIT_DELAY);
                      gw.present(CHILD_ID_LOCK2, S_LOCK);      delay(RF_INIT_DELAY);
                      gw.present(CHILD_ID_ALARM, S_MOTION);   delay(RF_INIT_DELAY);
                      gw.present(CHILD_ID_DOOR_R, S_DOOR);
                      gw.present(CHILD_ID_DOOR_L, S_DOOR);
                      recallEeprom();
                      // Init MFRC RFID sensor
                      SPI.begin();            // Init SPI bus
                      mfrc522.PCD_Init();     // Init MFRC522
                      ShowReaderDetails();            // Show details of PCD - MFRC522 Card Reader details
                      gw.send(lockArmMsg.set(armed));
                      Serial.println(F("Init done..."));
                      timer++;
                      delay(HEARTBEAT);
                      debouncer.update();
                      debouncerDoorL.update();
                      // Get the update value for Left
                      int valueL = debouncerDoorL.read();
                      if (valueL != oldValueL) {
                         // Send in the new value for Left
                         gw.send(doorLmsg.set(valueL==HIGH ? 1 : 0));
                         oldValueL = valueL;
                      debouncerDoorR.update();
                      // Get the update value for Right
                      int valueR = debouncerDoorR.read();
                      if (valueR != oldValueR) {
                         // Send in the new value for Right
                         gw.send(doorRmsg.set(valueR==HIGH ? 1 : 0));
                         oldValueR = valueR;
                      int switchValue = debouncer.read();
                      if (switchValue != oldSwitchValue) {
                        Serial.print (F("Switch "));
                        Serial.println (switchValue);
                        if (switchValue && programmode) {
                             lastTime     = millis() / 1000;
                        if (!switchValue && programmode && lastTime > 0) {
                             if ( (millis() / 1000) - lastTime > 3) {
                                  Serial.println(F("Reset all cards"));
                                  blinkFast(50);
                                Serial.println(F("Program off"));
                                storeEeprom();
                        if (!switchValue)   {
                            programTimer = 0;
                        oldSwitchValue = switchValue;
                      if (programmode && ((timer % (ONE_SEC / HEARTBEAT)) == 0 ))  {
                          ledon = !ledon;
                          digitalWrite(LED_PIN, ledon);
                          programTimer++;
                          // Stop program mode after 20 sec inactivity
                          if (programTimer > PROG_WAIT)  {
                             digitalWrite(LED_PIN, false);
                             Serial.println(F("Program expired"));
                      if ((timer % (200 / HEARTBEAT)) == 0 )   {
                           // Look for new cards
                           if ( ! mfrc522.PICC_IsNewCardPresent()) {
                                if (releasecnt > 0)   {
                                    releasecnt--;
                                    if (!releasecnt)  {
                                        olduid.size = 0;
                                        Serial.println(F("release"));
                          return;
                          releasecnt = 5;
                         // Select one of the cards
                         if ( ! mfrc522.PICC_ReadCardSerial()) {
                            return;
                         // Dump debug info about the card; PICC_HaltA() is automatically called
                         //mfrc522.PICC_DumpToSerial(&(mfrc522.uid));
                         if (!olduid.size || !sameUid(&(mfrc522.uid), &olduid))  {
                              ShowCardData(&(mfrc522.uid));
                              copyUid(&(mfrc522.uid), &olduid);
                              if ( isValidCard(&olduid) )   {
                                   OpenDoor(programmode);
                              } else  {
                                 if (sameUid(&(mfrc522.uid), &masterkey)) {
                                     // Only switch in program mode when mastercard is found AND the program button is pressed
                                     if (switchValue)  {
                                       Serial.println(F("Program mode"));
                                       programmode = true;
                                       programTimer = 0;
                                       lastTime     = 0;
                                       OpenDoor2(programmode);
                                     if (programmode) {
                                       Serial.println(F("new card"));
                                       programTimer = 0;
                                       if (countValidCards < MAX_CARDS)
                                          // Add card to list...
                                          copyUid(&(mfrc522.uid), &validCards[countValidCards]);
                                          countValidCards++;
                                          blinkFast(15);
                                       Serial.println(F("Invalid card"));
                                       if (armed) {
                                          gw.send(wrongMsg.set(1));
                                          delay(2000);
                                          gw.send(wrongMsg.set(0));
                  Serial.print(F("Card UID:"));
                  for (byte i = 0; i < uid->size; i++) {
                      if(uid->uidByte[i] < 0x10) {
                          Serial.print(F(" 0"));
                          Serial.print(F(" "));
                      Serial.print(uid->uidByte[i], HEX);
                  Serial.println();
                  dest->size = src->size;
                  dest->sak  = src->sak;
                  for (byte i = 0; i < src->size; i++) {
                  dest->uidByte[i] = src->uidByte[i];
                  if (old->size != check->size) {
                     return false;
                  for (byte i = 0; i < old->size; i++) {
                      if (old->uidByte[i] != check->uidByte[i]) {
                          return false;
                  return true;
                    for (byte i = 0; i < countValidCards; i++)  {
                        if (validCards[i].size != uid->size)  {
                        for (int j = 0; j < uid->size; j++) {
                            if (validCards[i].uidByte[j] != uid->uidByte[j])  {
                            if (j == (uid->size - 1)) {
                                return true;
                    return false;
              void storeEeprom()
                  byte address = 0;
                  gw.saveState(address++, countValidCards);
                     gw.saveState(address++, validCards[i].size);
                     for (byte j = 0; j < 10; j++) {
                        gw.saveState(address++, validCards[i].uidByte[j]);
              void recallEeprom()
                  byte address = 0;
                  countValidCards = gw.loadState(address++);
                  if (countValidCards > MAX_CARDS) {
                     Serial.println(F("Not a valid EEPROM reading set to default"));
                     storeEeprom();
                     return;
                     validCards[i].size = gw.loadState(address++);
                        validCards[i].uidByte[j] = gw.loadState(address++);
              void blinkFast(int times)
                  for (int i = 0; i < times; i++) {
                     ledon = !ledon;
                     delay(100);
              void OpenDoor(bool fakeOpen)
                  Serial.println(F("Open door!"));
                  gw.send(lockMsg.set(false));
                  if (!fakeOpen) {
                    digitalWrite(LED_PIN, HIGH);
                    digitalWrite(GARAGEPIN, HIGH);
                  delay(1000);
                  if (!fakeOpen) {
                    digitalWrite(GARAGEPIN, LOW);
                  gw.send(lockMsg.set(true));
              void OpenDoor2(bool fakeOpen)
                  Serial.println(F("Open door 2!"));
                  gw.send(lock2Msg.set(false));
                  if (!fakeOpen) {
                    digitalWrite(SECONDRELAY, HIGH);
                  delay(1000);
                  if (!fakeOpen) {
                    digitalWrite(SECONDRELAY, LOW);
                  gw.send(lock2Msg.set(true));
              void ShowReaderDetails() {
                  // Get the MFRC522 software version
                  byte v = mfrc522.PCD_ReadRegister(mfrc522.VersionReg);
                  Serial.print(F("MFRC522 Software Version: 0x"));
                  Serial.print(v, HEX);
                  if (v == 0x91) {
                      Serial.print(F(" = v1.0"));
                      } else if (v == 0x92) {
                      Serial.print(F(" = v2.0"));
                      Serial.print(F(" (unknown)"));
                  Serial.println("");
                      // When 0x00 or 0xFF is returned, communication probably failed
                  if ((v == 0x00) || (v == 0xFF)) {
                      Serial.println(F("WARNING: Communication failure, is the MFRC522 properly connected?"));
              void incomingMessage(const MyMessage &message)
                 if (message.type == V_LOCK_STATUS) {
                   // Change relay state
                   if (!message.getBool())  {
                      switch (message.sensor)
                         case CHILD_ID_LOCK:
                            OpenDoor(false);
                         case CHILD_ID_LOCK2:
                            OpenDoor2(false);
                   Serial.print(F("Lock:  "));
                   Serial.print(F(" status: "));
                   if (message.type == V_ARMED)  {
                     armed = message.getBool();
                     Serial.print(F("Arm status: "));
                     Serial.print(F("Incoming msg type: "));
                     Serial.print(message.type);
                     Serial.print(F(" id: "));
                     Serial.print(F(" content: "));
              • codergirl56C
                codergirl56C
                codergirl56
                Hi @BartE - thanks for putting this together! It has been very helpful.
                I am working on a project with two wireless MFRC522 modules and RFID Reader. I want to be able to read PICC cards with the RFID reader and send it the UID between the modules. So essentially a more bare version of the code you have written with the garage door opening code. I was wondering if you could help me out in simplifying the code to just reading the UID off the PICC cards and outputting that date between the RCF522 modules.
                Thanks in advance.
                • codergirl56C codergirl56
                  Thanks in advance.
                  BartEB
                  BartEB
                  BartE
                  @codergirl56 there are a number of examples in the MFRC522 library which might help you.
                  You can find them here: https://github.com/miguelbalboa/rfid
                  Please feel free to ask questions if the examples does not help you further
                  codergirl56C 1 Reply Last reply
                  • BartEB BartE
                    codergirl56C
                    codergirl56C
                    codergirl56
                    @BartE thanks for getting back to me. I've looked through the examples on the MFRC522 library. I think the main thing I'm struggling with is setting up and initializing the N24L01 module and the RFID on the same arduino uno. My plan is to have one N24L01 and RFID on one arduino module, and a second N24L01 on a second arduino. I want the RFID to read the UID off of PICC cards and be able to wirelessly transmit the UID between the N24L01 modules. I think it's simpler than the code you have written here, but I'm struggling to simplify the code you have to only what I need. Could you possibly walk through what each function in your program is used for? Thanks in advance.
                      BartEB
                      BartEB
                      BartE
                      @codergirl56 Oke i will give it a try:
                      Basic IO pin set up
                      This part initializes the SPI I/O pins used by the RFID reader so it release the SPI bus for thr NFR radio
                      Init LED and button I/O-pin
                              // Setup the button
                      Init radion module
                      Read eeprom settings
                              recallEeprom();
                      nit SPI bus for MFRC RFID sensor
                              timer++;
                              delay(HEARTBEAT);
                              debouncer.update();
                                          blinkFast(50);
                                        storeEeprom();
                                if (!switchValue)   {
                                    programTimer = 0;
                                  ledon = !ledon;
                                  programTimer++;
                                            releasecnt--;
                                            if (!releasecnt)  {
                                                olduid.size = 0;
                                  return;
                                  releasecnt = 5;
                      Check if a RFID card is held at the RFID reader if not: skip the rest and start over with loop()
                                    return;
                      Check if this card is the same as the previous loop if not enter the IF loop
                                      } else  {
                      Check if the master card was presented and the button was pressed enter program mode
                                             if (switchValue)  {
                                               programmode = true;
                                               programTimer = 0;
                                               lastTime     = 0;
                      If not the master card and this card in not known and we're in program mode add this as a new card
                                             if (programmode) {
                                               programTimer = 0;
                                                  countValidCards++;
                                                  blinkFast(15);
                                               if (armed) {
                                                  delay(2000);
                      These are support functions
                          Serial.println();
                             return false;
                                  return false;
                          return true;
                                        return true;
                            return false;
                      void storeEeprom()
                          byte address = 0;
                      void recallEeprom()
                          byte address = 0;
                             storeEeprom();
                             return;
                             ledon = !ledon;
                             delay(100);
                          if (!fakeOpen) {
                          delay(1000);
                          if (!fakeOpen) {
                          if (!fakeOpen) {
                          delay(1000);
                          if (!fakeOpen) {
                          if (v == 0x91) {
                          Serial.println("");
                                 case CHILD_ID_LOCK:
                                    OpenDoor(false);
                                    OpenDoor2(false);
                      • BartEB BartE
                        ChakkieC
                        ChakkieC
                        Chakkie
                        @BartE
                        Hi BartE, I have the same issue regarding tags lost after power off. I run the debug instruction using Serial print as you mentioned. I found out that the storeEeprom line did not run after closing the program mode. I think this is why the tags are lost after power cycle.
                        send: 210-210-0-0 s=255,c=3,t=15,pt=2,l=2,sg=0,st=ok:0
                        send: 210-210-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,st=ok:1.5.4
                        send: 210-210-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
                        read: 0-0-210 s=255,c=3,t=6,pt=0,l=1,sg=0:M
                        sensor started, id=210, parent=0, distance=1
                        send: 210-210-0-0 s=255,c=3,t=11,pt=0,l=9,sg=0,st=ok:RFID Lock
                        send: 210-210-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.1
                        send: 210-210-0-0 s=2,c=0,t=19,pt=0,l=0,sg=0,st=ok:
                        send: 210-210-0-0 s=1,c=0,t=1,pt=0,l=0,sg=0,st=ok:
                        RecallEeprom
                        MFRC522 Software Version: 0x92 = v2.0
                        send: 210-210-0-0 s=1,c=1,t=15,pt=2,l=2,sg=0,st=ok:1
                        Init done...
                        Switch 1
                        Card UID: 26 13 80 41
                        Invalid card
                        send: 210-210-0-0 s=1,c=1,t=16,pt=2,l=2,sg=0,st=ok:1
                        send: 210-210-0-0 s=1,c=1,t=16,pt=2,l=2,sg=0,st=ok:0
                        release
                        Card UID: xx xx xx xx
                        Program mode
                        release
                        new card
                        release
                        Program expired
                        Raspberry Pi 2
                        Domoticz
                        RFXCOM
                        ZWAVE Aeon stick
                        Coming soon Arduino mysensors GW
                        • BartEB BartE
                          ChakkieC
                          ChakkieC
                          Chakkie
                          @BartE
                          I've just solved the issue regarding tags lost after power off.
                          Simply add the line "StoreEeprom();" after the program mode function
                                      ledon = !ledon;
                                      programTimer++;
                                         storeEeprom();
                                         Serial.println(F("Store Card to EEPROM"));  ```
                          Raspberry Pi 2
                          Domoticz
                          RFXCOM
                          ZWAVE Aeon stick
                          • ChakkieC Chakkie
                            @BartE
                                        ledon = !ledon;
                                        programTimer++;
                                           storeEeprom();
                            BartEB
                            BartEB
                            BartE
                            @Chakkie sorry for the slow response (i was on a pre summer holiday)
                            Thx for analyzing this report. The fix you did made is not what i meant with program expired.
                            The idea is that you start program mode by pressing the program button and holding the master card.
                            And now one can add one or more new RFID cards and when your oke press the program button for a short period to END the program mode and store the new cards.
                            If you wait too long the program mode will expire and the new cards are NOT stored. Off course you can change this behavior by adding this line as you suggested.
                            • Michel - ItM
                              Michel - ItM
                              Michel - It
                              wrote on last edited by Michel - It
                              #25
                              hello to all guys, I noticed some problems, if the power goes away there is a flaw in the system. I modified the source as needed to me, now you turn the sensor on domoticz when you turn on and off when you turn off. I modified the project to create an alarm homemade I configured via lua script the motion sensors. I mounted on the bell so as to turn on and off when I go out or within the home. thank you all
                              0_1464953572731_rfidCompreto.jpg 0_1464953579700_rfidmoduloporta-180x180.jpg 0_1464953586849_rfidcentralina-180x180.jpg
                              • electromakerE
                                electromakerE
                                electromaker
                                Hi Everyone,
                                I have tested this code http://etabetastudio.blogspot.it/2016/07/tutorial-lettore-rfid-rc522-arduino-idea.html to test RFID RC-522 with Arduino 2009 and all is ok, also to registred RFID card on EEPROM...
                                I hope to help uo...bye
                                • Mercury69M
                                  Mercury69M
                                  Mercury69
                                  Dear All,
                                  I'm a newbie and I found in MySensors website the project for RFID Lock Sensors that use PN532 RFID Reader, but as I already have with me a RC-522 RFID reader, searching on the forum I found this post that I thinked it will suit my case.
                                  I assembled the various hardware parts as described on first post, but when I copied the sketch code in my arduino IDE, I'm not able to get it work.
                                  I get some error message that is not so clear for me.
                                  It's seems the sketch is for a previous version of MySensors Library or Arduino IDE, but I'm not sure of this.
                                  As I use Arduino IDE 1.6.12 that has included MySensors Library 2.0.0, is the Sketch you included in the first post already valid for that setup ?
                                  It' will be possible to have a valid sketch working with new setup or eventually to know how to proceed to make the actual one working ?
                                  Thank you in advance for your attention.
                                  Rod MacPhersonR 1 Reply Last reply
                                  • Mercury69M Mercury69
                                    Dear All,
                                    Rod MacPhersonR
                                    Rod MacPhersonR
                                    Rod MacPherson
                                    @Mercury69
                                    It was written prior to the MySensors 2.0 update.
                                    You can convert pre- 2.0 sketches by following the instructions on https://forum.mysensors.org/topic/4276/converting-a-sketch-from-1-5-x-to-2-0-x
                                    If you need a hand just post here with your question, I'll try to help, but it's really not too bad once you get started. I'm in the process of converting all of my code to 2.0 as well.
                                    Mercury69M 1 Reply Last reply
                                    • Rod MacPhersonR Rod MacPherson
                                      @Mercury69
                                      Mercury69M
                                      Mercury69M
                                      Mercury69
                                      @Rod-MacPherson
                                      Dear Rod, thank you for the suggestion you gave me.
                                      Following the instruction you indicated me, I was able to make the sketch working with new MySensors 2.0 library.
                                      Considering that I'm not a programmer, it was quite easy to make the sketch working.
                                      Thank you again for your suggestion and off course thank you to BartE for the good original work he did.
                                      If someone need new sketch working with library 2.0, feel free to ask me.
                                      Michel - ItM J 2 Replies Last reply
                                        @Rod-MacPherson
                                        Michel - ItM
                                        Michel - ItM
                                        Michel - It
                                        @Mercury69 you can post the sketch ?
                                          @Rod-MacPherson
                                          J
                                          J
                                          jeti
                                          @Mercury69 I would also love to have a look at your scetch!
