  3. In wall light switch node - Custom PCB
custompcbinwallnodelight switchswitch
245 Posts 15 Posters 176.2k Views 23 Watching
  • S Offline
    Samuel235
    I'm currently waiting on some more components to get this module up and running with thanks to @GertSanders providing the bootloader. All being well we will have it completed in the next month to be running with the radio and allowing ISP and FTDI/Serial uploads with the radio all connected.
    Does anyone have any feature requests for this module other than simple battery monitoring?
    MySensors 2.1.1
    • jeylitesJ Offline
      jeylitesJ Offline
      jeylites
      Just wondering, any of you guys looked into touch switches like below 0_1461627979698_HT1j2QTFGhXXXagOFbXh.jpg
      S 1 Reply Last reply
      • jeylitesJ jeylites
        Samuel235
        @jeylites, i was going to make a thread on these exact switches soon to discuss the possibility of interfacing them as they run on RF. Keep your eyes open for the thread asap ;).
        I would like to make my own switch front with pressure capacitance at some point but thats for another day.
        MySensors 2.1.1
        • S Offline
          Samuel235
          UPDATE - Feature upgrades
          I have had the materials arrive to attempt to get the latest fixes sorted for this board. Hopefully this will allow us to serial upload while the radio is soldered permanently onto the board. I will update soon as i have attempted this. Keep you posted!
          MySensors 2.1.1
          • S Samuel235
            wrote on last edited by scalz
            #225
            I didn't read this. interesting..one of my current project in progress is exactly this! Designing a special shield for glass plate etc :) the same for controlling one switch or more ;)
            I have few Livolo that I have disassembled and looked how it works inside. but I'm not fan of 433mhz radio (or that would need some rflink). I'm actually trying to decidde the best way, if I want to hack it, or if I will do my own switch with glass plate I found. because I would like dimming, rfm69, authentication and my shield...
            • S scalz
              Samuel235
              @scalz, If i'm honest I would like to see both. I love to see hacks being perfected, especially in products with such a clean finish as these but then again i also love seeing brand news products being brought to life. Either one you do, i'll be sure to support your ideas!
              MySensors 2.1.1
              • S Offline
                Samuel235
                Having some very intermittent issues regarding uploading to this board using an FTDI adapter, 2 in fact. I have tried two adapters now and neither are giving me solid results. I have checked all solder joints and all seems fine. Time to start troubleshooting further. I'm uploading to this board using fuse settings of Low: E2 and High: DE, with a brownout detection point of 1v8. The error that i get 9/10 times is just that the programmer is out of sync. I will report back with my findings.
                MySensors 2.1.1
                • S Offline
                  Samuel235
                  UPDATE
                  We have a working node. We're now able to serial upload and monitor the module with thanks to @GertSanders and his bootloader.
                  So the node currently has 2 switch inputs and that would be the maximum for the hardware interrupt, i may do some investigating to get another port for interrupt to enable us to have 3 switches on the one node.
                  MySensors 2.1.1
                  G 1 Reply Last reply
                  • S Samuel235
                    UPDATE
                    G Offline
                    G Offline
                    GertSanders
                    @Samuel235
                    Well, lets all thank the lead designer of the Optiboot boot loader: Bill Westfield !
                    Without his code and repository my compilations would not give any results.
                    • G GertSanders
                      @Samuel235
                      Samuel235
                      @GertSanders, get him here and lets all buy him cake and beer!
                      MySensors 2.1.1
                      • X Offline
                        X Offline
                        Xander
                        For more than two switches see: http://www.gammon.com.au/forum/?id=11091
                        I would add a hardware debouncing (R/C) to avoid the problems mentioned in the article.
                        S K 2 Replies Last reply
                        • X Xander
                          Samuel235
                          @Xander Thank you. I may try implimenting this into Rev 3
                          MySensors 2.1.1
                          • X Xander
                            K Offline
                            K Offline
                            Koresh
                            It's very good trick, but this circuit allows use of only tact switches. If you are interested - check my schematic (https://www.openhardware.io/view/102/Wall-Switch-Insertable-Node). It allows use of on\off switches too. I've drawn it after a little brainstorm :) I'm not sure it is optimal, but it works very nice.
                            • K Koresh
                              Samuel235
                              @Koresh I had a quick look earlier, i will study it in more depth later. Thank you!
                              MySensors 2.1.1
                              • S Offline
                                Samuel235
                                @Koresh, thank you for linking me your module, i'm finally getting around to looking into some depth in this. First of all, i would like to ask something regarding the Exclusive-OR Gates;
                                I know how the gates work, in this case it uses Exclusive-OR (XOR) Gates, in simple terms, if the inputs are different the output will be HIGH, if the inputs are the same it will be LOW. The input you have connected to GND, could you tell me why that has to be connected to VCC with a resistor, could you not just connect that to GND?
                                I really like your use of the Schmitt Triggers here, makes the signal nice and sharp on the falling edges for the logic gates to work with.
                                Thanks!
                                MySensors 2.1.1
                                • S Offline
                                  Samuel235
                                  We're currently working on locating the issue that we have with the light switch not being synced with OpenHab correctly. It works as intended but you have to double click to get the light on. We have located the issue lying within OpenHab's item configuration issues. Will post the resulting configuration needed to get this node working 100% perfectly.
                                  MySensors 2.1.1
                                  • A Offline
                                    A Offline
                                    artipi
                                    Hi Samuel,
                                    thanks for your great work.
                                    I'm currently starting with my first steps in Home Automation.
                                    I'm trying to control our lights in our flat. Our light switches are push switches with 12V. (dont know the right Translation to English. In German its called "Taster" - with no ON/OFF state, just a Push)
                                    Is this board useable for my switches? So can i connect the 12V to your board somehow and send the 12V "press button" to the main Fuse Box?
                                    Thank you,
                                    Arthur.
                                    • A artipi
                                      Hi Samuel,
                                      Thank you,
                                      Arthur.
                                      Samuel235
                                      @artipi - As I'm not completely sure about the German wiring system I can't give you a answer that would be strictly abiding your rules. However, I will attempt to answer from my own personal opinion:
                                      I'm not sure what you're sending the 12v back to the main fuse box for, this will simply send a 1/on or 0/off to your MySensors gateway. What you do with that signal is completely up to you. You could have a relay connected to mysensors gateway and then switch that relay with this light switch node. So, i suppose you could actually get a line on your fuse box switch with this but it would have to be sending signals to the gateway first, not directly to the fuse box.
                                      Sorry if I haven't understood your intent correctly.
                                      MySensors 2.1.1
                                      A 1 Reply Last reply
                                      • S Samuel235
                                        A Offline
                                        A Offline
                                        artipi
                                        @Samuel235 - Thanks for the fast reaction:).
                                        Ok, now i understand your switch node.
                                        I think i need something with a 12V Relay. So i can send a command (ON/OFF) to a relay node that will act like my light switch.
                                        • A artipi
                                          Samuel235
                                          @artipi - That sounds very likely what you need. A double relay situation. However, if it was me, i would question what you need to switch it at the fuse box for. I would run the line to the lights from the fuse box and then switch it behind the like using a relay like i do (and will be releasing my relay node tonight on here and openhardware.io). Then that is switched using this wireless switch node.
                                          However, the regulations in german wiring may be so that you have to do all switching inside of the fuse box.
                                          MySensors 2.1.1
                                          12.2k
