  3. In wall light switch node - Custom PCB
custompcbinwallnodelight switchswitch
245 Posts 15 Posters 182.8k Views 23 Watching
  • scalzS scalz
    ahah. it was an onomatopia? a sort of "argh" or "gloups". I don't know how to translate it lol!
    for your vcc problem (seems now you have a true one), there is of course an answer but I have no idea for the moment...like I said if I have one I will tell you. I will try to re-look at your eagle files maybe tonight...
    Samuel235
    @scalz Ahh okay, i assumed it was to be honest but just in case it was some sort of technical term that i didn't understand i thought it was best i questioned it.
    Yeah, i have some power in the chip now it seems, thank you for shining some sort of light on one issue, whether it is the issue that is stopping it from working or not, its help at least. When i get home i will be spending some more time on troubleshooting the issue again. Hope to speak to you later :)
    MySensors 2.1.1
    • S
      Samuel235
      @scalz I've woken this morning quite ashamed at the fact last night/yesterday i must have been that sleep deprived when asking about continuity over a connected capacitor. They will only show continuity if they are blown/faulty, i now remember.
      MySensors 2.1.1
      • S
        Samuel235
        I'm seeking external help from a electronic forum. Someone has suggested that my 0.1uF caps could be too far away from the micro-controller itself. We're talking around 13-15mm away from the chip. What're you thoughts, would you say that is too far away from the chip?
        MySensors 2.1.1
        • S
          Samuel235
          With a little open-heart surgery, the board becomes alive! While I'm yet to actually burn any bootloader to the uC itself, I have no got the circuitry working.
          The known issues:
          • Capacitor on the SPI Header was incorrectly connected. I had wired it like a resistor/diode.
          • The VCC line from the SPI was connected to the uC through the resistor of the RESET circuit.
          • Battery holder is connected in reverse.
          I have attached images for anyone interested in following this project with actual pictures of the progression through the revisions of this node. I have now made some alterations in my documentations regarding Rev1, listed the known issues and made some possible improvements:
          • Remove one 47uF capacitor.
          • Move the 47uF capacitor closer to battery terminal, and have all power traces coming through that capacitor, reducing the chance of the battery being drained through large spikes in draw.
          • Add capacitor to FTDI VCC to stop spikes when connecting programming board.
          • Increase silkscreen labels for document data such as pinouts and node info.
          • Remove the 100uF capacitor on the nRF24l01+, add a 4.7uF footprint and 0.1uF footprint. Only populate if needed.
          • Turn around the switch terminals, room should allow this.
          • Bring the 0.1uF capacitors closer to the VCC inputs on the uC.
          This week I will be aiming to get the designs and re-routes for Rev2 sorted out, and then get them ordered, with express shipping this time hopefully. The 3 weeks of waiting killed me!
          Please give your feedback, if you have any.
          MySensors 2.1.1
          • S
            Samuel235
            I would like to ask if someone could just double check my Schematic and Board layout for me, just as a second pair of eyes before i send the gerber files over to ITead.cc in the morning. I'm pretty sure everything is as it should be, but would like a second pair of eyes to give it a scan over.
            Can't wait to get Rev2 up and running to deliver the upgrades that have been made!
            Thank you in advance :)
            MySensors 2.1.1
            m26872M 1 Reply Last reply
            • S Samuel235
              m26872M
              m26872M
              m26872
              @samuel235 Look again at your Reset-Dtr net wiring compared to example and reference. Also C8 is probably ment to be in parallell with the battery.
              S 3 Replies Last reply
              • m26872M m26872
                Samuel235
                @m26872 - I'll get that checked over tonight then. It was late last night when i finished it up. Thank you.
                Just a quick bit of information released from about ITead.cc this morning:
                MySensors 2.1.1
                • m26872M m26872
                  Samuel235
                  @m26872 - I just have to connect the right side (positive connection) to the batt + right?
                  Then for the reset line, i've been having some horrible issues with understanding the connection for this and i genuinly thought i had it here with this Rev. I will study that and take a look soon as i get home today.
                  MySensors 2.1.1
                  • m26872M m26872
                    Samuel235
                    I'm sorry @m26872, however i feel that my reset line is connected correctly. I have used Atmel's recommendation to verify this and everything is exactly the same as they suggest to use apart from the fact i do not have a diode in there, which they recommend.
                    Also C8 is probably meant to be in parallel with the battery.
                    I have the negative connection made to the GND plane, then the positive receives its power from the BATT and then out to the various components now.
                    Below is 3 images, one for the modified BATT & C8 connection, one for the recommended reset circuit from Atmel, and the other is my actual reset circuit.
                    C8 & BATT
                    Atmel's recommendation for reset circuit
                    My Actual reset circuit
                    Please could you inform me where I am going wrong with the reset pin because I simply can't see anything to my knowledge.
                    MySensors 2.1.1
                    • scalzS
                      scalzS
                      wrote on last edited by scalz
                      #90
                      I think you may add some net labels at RST, DTR. So it is less ambiguous to read ;)
                      Here a basic sparkfun arduino mini schematic so you can check :)
                      https://cdn.sparkfun.com/assets/0/7/5/5/1/51eec304ce395f104c000000.png
                      S 1 Reply Last reply
                      • scalzS scalz
                        Samuel235
                        @scalz - Labels have been added to make it easier to understand.
                        However, this is exactly how I wired Rev1, it didn't work until I hacked together the reset pin. I'm getting even more confused at to why my Rev1 didn't work now, I thought that by bypassing/altering the connections with some wires and it working would indicate that I had wired Rev1 incorrectly, I used the link you sent to me as reference while I was making Rev1.
                        However, i have done as you have suggested and attached images below. I've also attached my eagle files in case you wanted to trace any routes you can't see clearly on the images.
                        0_1453481212181_HominiSwitchNode.zip
                        MySensors 2.1.1
                        • m26872M
                          m26872M
                          m26872
                          Looks good now except that AVR ISP (JP1) pin 5 should connect straight to RESET and not to DTR.
                          • m26872M m26872
                            Samuel235
                            @m26872 - Does the FTDI need to go to RESET or DTR? I'm feeling DTR because all the FTDI programmers i'm using is labeled with DTR and not RESET, am i correct in assuming this?
                            MySensors 2.1.1
                            • S Samuel235
                              m26872M
                              m26872M
                              m26872
                              @samuel235 Yes.
                              • m26872M m26872
                                @samuel235 Yes.
                                Samuel235
                                #95
                                @m26872 - Perfect. Thank you for your assistance, I really appreciate it! I'll get these ordered tonight hopefully and then keep looking at the circuitry for my RESET and DTR line to memorize it and work out why its so hard to get into my brain xD.
                                Just one last confirm, since I'm not that confident with myself at the moment regarding this RESET line, if you don't mind.
                                MySensors 2.1.1
                                • S Samuel235
                                  m26872M
                                  m26872M
                                  m26872
                                  @samuel235 Reset and Dtr routing looks correct, but you still have DTR silkscreen label next to AVR ISP.
                                  • m26872M m26872
                                    Samuel235
                                    Indeed I do, the board itself isn't finished yet, I just wanted you to clarify the wiring was correct. Time to tidy it up, finish the annotating and get it finalized. However, thank you for pointing it out to me (Shows you're actually paying some attention to this). Thank you, yet again. The level of support and time you dedicate to helping others on here is outstanding. It is most certainly noticed!
                                    MySensors 2.1.1
                                    • S Samuel235
                                      m26872M
                                      m26872M
                                      m26872
                                      @samuel235 You're very welcome. We'll all benefit when you succeed.
                                      • S
                                        Samuel235
                                        UPDATE!
                                        Revision 2 boards have now been submitted for manufacturing. Standard shipping used, so expecting within the next 23 days. This is going to pain me!
                                        On the side note, I've enrolled for Open University and will be studying now for around 4 years. I'm doing a Computing and IT degree to follow on from my existing IT Qualifications (Microsoft and CompTIA). I do hope to incorperate this community and the projects i take on with you guys into my studying. I also do not expect this to effect the time and effort I'm able to spend with you guys here and developing our projects together.
                                        I will update you ASAP, when these boards get here :)
                                        MySensors 2.1.1
                                        • scalzS
                                          scalzS
                                          great :)
