  3. Domoticz
  4. best way to sync relay node plus button node with light
2 Posts 2 Posters 1.4k Views 1 Watching
  • T Offline
    T Offline
    TEStevens
    Right now I have:
    1 working relay node with 4 buttons and
    1 working button controller node with 4 buttons and 4 lights
    I would like the buttons to control the relays and the button lights match the state of the relays even if the relays were toggled via the domoticz interface.
    Right now I have the relays nodes set up as V_LIGHTS and my buttons as separate V_LIGHTS. Then in Blocky I did a long if/else statement if one of them changed to change the state of the other device. I think it would sometimes confuse blocky and I would start an endless cycle of toggling the buttons. (this was my first attempt with blocky)
    In the future I would like to add more of my button controllers to control the same set of relays.
    Is there a more elegant way to make the state of two separate devices equal.
    Thanks in advance
    Troy
    D 1 Reply Last reply
    • T TEStevens
      Right now I have:
      Thanks in advance
      Troy
      Dwalt
      @TEStevens This is two separate nodes, correct? As I understand what you described: you have a 4-relay node and you have a node with four buttons and four lights, are these LEDs on the node or switched lights?
      If this is a separate node from the relays, I would use S_SCENE_CONTROLLER for the buttons and S_LIGHT for the LEDs and use logic on your controller to send V_LIGHT commands to both the LEDs on the button node and to the relay node when a scene is switched 'on' or 'off' from any of your proposed "button controllers".
      12.2k
