  2. Feature Requests
  3. Tank\Vessel Level
Tank\Vessel Level
5 Posts 3 Posters 2.5k Views 1 Watching
  • K
    K
    kopite
    Hi
    I would like to propose a tank\level sensor using an HC-SR04 ultrasonic Distance sensor
    Node would return a % based on a set High & Set low thresholds
    J 1 Reply Last reply
    • bjacobseB
      bjacobseB
      bjacobse
      I think it's best that the sensor is "dump" and only provides the actual reading of the distance value, which sends the measured value to a "master" then the master will decide. The "master" could have a configuration file that defines min/max values of the range, so the master can validate the measured value. Then the "master" can provide% just as you prefer/can write codes that shows the graph
      • K kopite
        Hi
        J
        J
        jkandasa
        @kopite said:
        Hi
        This might help you https://github.com/mycontroller-org/ArduinoSketches/blob/master/WaterLevelSensor/WaterLevelSensor.ino
        • K
          K
          kopite
          Thanks @jkandasa, that's looks exactly what I am after.
          Does this code integrate to the various controllers without issue?
          I am running Vera & Domoticz
          • K kopite
            J
            J
            jkandasa
            @kopite I developed this code for MyController.org But it should work for any controller which supports MySensors.
