  2. Feature Requests
  3. gw.send for float
gw.send for float
6 Posts 4 Posters 4.5k Views 2 Watching
  • epierreE
    epierreE
    epierre
    I have many gases sensors, especially for harmful gases, that report very small concentration, which is thus a float.
    Today gw.send only allows an int, which is troublesome for I have to multiply per 1k to have an int.
    That would mean that the controller would have to convert back to float to be on the right scale.
    Would that extension be possible ?
    z-wave - Vera -> Domoticz
    AWIA 1 Reply Last reply
    • epierreE epierre
      AWIA
      AWIA
      AWI
      @epierre almost all my sensors use gw.send to send floats. It is in the API, or do I misunderstand you?
      • epierreE
        epierreE
        epierre
        in 1.5 I just have the int definition of it, maybe is that linked to the S_AIR_QUALITY maybe ?
        gw.present(CHILD_ID_CO, S_AIR_QUALITY);
        gw.send(msg_co.set("ppm"));
        YveauxY 1 Reply Last reply
        • epierreE epierre
          YveauxY
          YveauxY
          @epierre Did you try something like:
          float myval = 0.1234;
          gw.send( MyMessage(CHILD_ID_CO, V_VAR1).set(myval) );
            You should be able to do something like line 57 in this sketch https://codebender.cc/sketch:177182#Soil moisture for houseplants - multi-sensor internal pull-up.ino
            • epierreE
              epierreE
              epierre
              @mfalkvidd thanks a lot !
