  3. Why MySensors isn't using interrupts for nrf24?
24 Posts 7 Posters 13.1k Views 2 Watching
    @Yveaux
    Yep, might be good to dequeue the NRF fifo as fast as possible.
    Same goes for dev-branch
    https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/core/MyTransport.cpp#L47
    Process should probably return true (when new message was available) and be "whiled" from here:
    https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/core/MySensorCore.cpp#L52
    Hmm.. don't recognize the listeningStarted flag.. As you say.. Might be some half done refactoring... Let's ping @thozza .
    YveauxY
    YveauxY
    Especially for a sleeping slave (which uses the same code as a gateway).
    tekkaT 1 Reply Last reply
    • YveauxY Yveaux
      tekkaT
      tekkaT
      tekka
      @Hek: In the dev branch, _process() is called in main(): https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/core/MyMainDefault.cpp#L12.
      As long as nodes are non-blocking and not sleeping, all queued messages are processed. However, for sleeping nodes we have to make sure the queue is processed before sending the node to sleep. The 800us delay code snippet (if correctly implemented) may help to stabilize the RF after switching to RX...
      • F
        F
        Fabien
        Ok so I continue my test with the same code. And you are right the sensebender send battery level every 30mins.
        For this test, I use exactly the same hardware and same wiring (including ethernet câble for both sketch). I will post result on monday (about 24h for each sketch).
        Serial sketch
         * The ArduinoGateway prints data received from sensors on the serial link.
         * The gateway accepts input on seral which will be sent out on radio network.
         * The GW code is designed for Arduino Nano 328p / 16MHz
         * Wire connections (OPTIONAL):
         * - Inclusion button should be connected between digital pin 3 and GND
         * - RX/TX/ERR leds need to be connected between +5V (anode) and digital pin 6/5/4 with resistor 270-330R in a series
         * LEDs (OPTIONAL):
         * - To use the feature, uncomment MY_LEDS_BLINKING_FEATURE in MyConfig.h
        #define MY_SOFTSPI
        #define MY_SOFT_SPI_SCK_PIN 7
        #define MY_SOFT_SPI_MISO_PIN 6
        #define MY_SOFT_SPI_MOSI_PIN 5
        #define MY_RF24_CE_PIN 3
        #define MY_RF24_CS_PIN 8
        // Enable serial gateway
        #define MY_GATEWAY_SERIAL
        // Flash leds on rx/tx/err
        //#define MY_LEDS_BLINKING_FEATURE
        // Set blinking period
        //#define MY_DEFAULT_LED_BLINK_PERIOD 300
        // Enable inclusion mode
        void presentation() {
        And Ethernet Sketch
         * LEDs (OPTIONAL):
        #define MY_GATEWAY_W5100
        #define MY_SOFTSPI
        #define MY_IP_ADDRESS 192,168,2,200   // If this is disabled, DHCP is used to retrieve address
        #define MY_PORT 5003
        //#define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 254
        //#define MY_GATEWAY_SERIAL
        #include <Ethernet.h>
        • F
          F
          Fabien
          After 2 days of test. I lost few packets (5 or 6 in 24 hours and usually humidity ...). I will perform another test after changing all my ethernet câbles.
